pbtraveller
ich habe Schwierigkeiten mit der Einwahl per pppoe. Der Account ist ein Telekom-Account. Meine Kiste ist eine alte Soekris-Box mit FreeBSD 10.0-RELEASE-p7 i386. pppoe stellt überhaupt keine Verbindung her. Meine Konfiguration sieht folgendermaßen aus:
/etc/rc.conf:
ppp_enable="YES"
ppp_nat="YES"
ppp_profile="telekom"
ppp_telekom_mode="ddial"
/etc/ppp/ppp.conf
default:
set log Phase Chat LCP IPCP CCP tun command
set ifaddr 10.0.0.1/0 10.0.0.2/0
set speed sync
telekom:
set log Phase Chat LCP IPCP CCP Warning Error Alert tun command
set device PPPoE:vr0
set authname benutzername...#0001@t-online.de
set authkey kennwort
set dial
set login
set mtu 1492
set mru 1492
add default HISADDR
/var/log/ppp.log wirft folgendes aus:
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Command: telekom: set mtu 1492
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Command: telekom: set mru 1492
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Command: telekom: set speed sync
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Command: telekom: accept lqr
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Command: telekom: disable deflate
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Command: telekom: add default HISADDR
Aug 2 19:14:07 littlegate ppp[3243]: tun0: Warning: Add route failed: 0.0.0.0: errno: Value too large to be stored in data type
Aug 2 19:14:07 littlegate ppp[3250]: tun0: Phase: PPP Started (ddial mode).
Aug 2 19:14:07 littlegate ppp[3250]: tun0: Phase: bundle: Establish
Aug 2 19:14:07 littlegate ppp[3250]: tun0: Phase: deflink: closed -> opening
Aug 2 19:14:07 littlegate ppp[3250]: tun0: Phase: deflink: Connected!
Aug 2 19:14:07 littlegate ppp[3250]: tun0: Phase: deflink: opening -> dial
Aug 2 19:14:07 littlegate ppp[3250]: tun0: Phase: deflink: dial -> carrier
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: deflink: Disconnected!
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: deflink: carrier -> hangup
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: deflink: Connect time: 5 secs: 0 octets in, 0 octets out
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: deflink: 0 packets in, 0 packets out
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: total 0 bytes/sec, peak 0 bytes/sec on Sat Aug 2 19:14:07 2014
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: deflink: hangup -> opening
Aug 2 19:14:12 littlegate ppp[3250]: tun0: Phase: deflink: Enter pause (30) for redialing.
Hat jemand ne idee, warum die Verbindung beendet wird, bevor sie überhaupt richtig aufgebaut wurde?
Vielen Dank für Eure Hilfe
/etc/rc.conf:
ppp_enable="YES"
ppp_nat="YES"
/etc/ppp/ppp.conf
default:
set speed sync
telekom:
set dial
set login
set mtu 1492
set mru 1492
add default HISADDR
