parcival39
Hallo zusammen,
poudriere bildet nicht net/rsync, gibt aber keinerlei Fehlermeldung aus.
Irgend eine Idee ?
Danke für jede Hilfe
Stefan
poudriere bulk -j 100_i386 net/rsync
====>> Creating the reference jail... done
====>> Mounting system devices for 100_i386-default
====>> Mounting ports/packages/distfiles
====>> Using packages from previously failed build
====>> Mounting packages from: /opt/poudriere/data/packages/100_i386-default
====>> Mounting /var/db/ports from: /usr/local/etc/poudriere.d/options
====>> Logs: /opt/poudriere/data/logs/bulk/100_i386-default/2014-03-27_15h32m13s
====>> Appending to make.conf: /usr/local/etc/poudriere.d/100_i386-make.conf
/etc/resolv.conf -> /opt/poudriere/data/build/100_i386-default/ref/etc/resolv.conf
====>> Starting jail 100_i386-default
====>> Loading MOVED
====>> Calculating ports order and dependencies
====>> Sanity checking the repository
====>> Deleting stale symlinks
====>> Deleting empty directories
====>> Cleaning the build queue
====>> Recording filesystem state for prepkg... done
====>> No package built, no need to update the repository
====>> Committing packages to repository
====>> Removing old packages
====>> Cleaning up
====>> Umounting file systems
====>> [100_i386-default] 0 packages built, 0 failures, 0 ignored, 0 skipped
Irgend eine Idee ?
Stefan
