The following controllers are supported by the mpt driver:
· LSI Logic 53c1030, LSI Logic LSI2x320-X (Single and Dual Ultra320
SCSI)
· LSI Logic AS1064, LSI Logic AS1068 (SAS/SATA)
· LSI Logic FC909 (1Gb/s Fibre Channel)
· LSI Logic FC909A (Dual 1Gb/s Fibre Channel)
· LSI Logic FC919, LSI Logic 7102XP-LC (Single 2Gb/s Fibre Channel)
· LSI Logic FC929, LSI Logic FC929X, LSI Logic 7202XP-LC (Dual 2Gb/s
Fibre Channel)
· LSI Logic FC949X (Dual 4Gb/s Fibre Channel)
The SCSI controller chips supported by the mpt driver can be found
onboard on many systems including:
· Dell PowerEdge 1750 thru 2850
· IBM eServer xSeries 335
Cards supported by the isp driver include:
ISP1000
SBus Fast Wide, Ultra Fast Wide cards, Single Ended or Dif-
ferential cards.
ISP1020
Qlogic 1020 Fast Wide and Differential Fast Wide PCI cards.
ISP1040
Qlogic 1040 Ultra Wide and Differential Ultra Wide PCI
cards. Also known as the DEC KZPBA-CA (single ended) and
KZPBA-CB (HVD differential).
Qlogic 1240
Qlogic 1240 Dual Bus Ultra Wide and Differential Ultra Wide
PCI cards.
Qlogic 1020
Qlogic 1020 SCSI cards.
Qlogic 1040
Qlogic 1040 Ultra SCSI cards.
Qlogic 1080
Qlogic 1280 LVD Ultra2 Wide PCI cards.
Qlogic 1280
Qlogic 1280 Dual Bus LVD Ultra2 Wide PCI cards.
Qlogic 12160
Qlogic 12160 Dual Bus LVD Ultra3 Wide PCI cards.
Qlogic 210X
Qlogic 2100 and 2100A Copper and Optical Fibre Channel
Arbitrated Loop (single, dual).
Qlogic 220X
Qlogic 2200 Copper and Optical Fibre Channel Arbitrated
Loop PCI cards (single, dual, quad).
Qlogic 2300
Qlogic 2300 Optical Fibre Channel PCI cards.
Qlogic 2312
Qlogic 2312 Optical Fibre Channel PCI cards.
Qlogic 234X
Qlogic 234X Optical Fibre Channel PCI cards (2312 chipset,
single and dual attach).
Qlogic 2322
Qlogic 2322 Optical Fibre Channel PCI cards.
Qlogic 200
Dell Branded version of the QLogic 2312 Fibre Channel PCI
cards.
