LoadModule asis_module libexec/apache22/mod_asis.so
LoadModule info_module libexec/apache22/mod_info.so
LoadModule cgi_module libexec/apache22/mod_cgi.so
LoadModule dav_fs_module libexec/apache22/mod_dav_fs.so
LoadModule vhost_alias_module libexec/apache22/mod_vhost_alias.so
LoadModule negotiation_module libexec/apache22/mod_negotiation.so
LoadModule dir_module libexec/apache22/mod_dir.so
LoadModule imagemap_module libexec/apache22/mod_imagemap.so
LoadModule actions_module libexec/apache22/mod_actions.so
LoadModule speling_module libexec/apache22/mod_speling.so
LoadModule userdir_module libexec/apache22/mod_userdir.so
LoadModule alias_module libexec/apache22/mod_alias.so
LoadModule rewrite_module libexec/apache22/mod_rewrite.so
LoadModule php5_module libexec/apache22/libphp5.so
<IfModule !mpm_netware_module>
<IfModule !mpm_winnt_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User www
Group www
</IfModule>
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition. These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed. This address appears on some server-generated pages, such
^[ (escape) menu ^y search prompt ^k delete line ^p prev li ^g prev page
^o ascii code ^x search ^l undelete line ^n next li ^v next page
^u end of file ^a begin of line ^w delete word ^b back 1 char
^t begin of file ^e end of line ^r restore word ^f forward 1 char
^c command ^d delete char ^j undelete char ^z next word
L: 471 C: 1 ===================================================================
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
#Include etc/apache22/extra/httpd-mpm.conf
# Multi-language error messages
#Include etc/apache22/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
#Include etc/apache22/extra/httpd-autoindex.conf
# Language settings
Include etc/apache22/extra/httpd-languages.conf
# User home directories
#Include etc/apache22/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include etc/apache22/extra/httpd-info.conf
# Virtual hosts
#Include etc/apache22/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include etc/apache22/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include etc/apache22/extra/httpd-dav.conf
# Various default settings
#Include etc/apache22/extra/httpd-default.conf
# Secure (SSL/TLS) connections
#Include etc/apache22/extra/httpd-ssl.conf
# Note: The following must must be present to support
# starting without SSL on platforms with no /dev/random equivalent
# but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
#AddModule mod_php5.c
<IfModule mod_php5.c>
DirectoryIndex index.php index.html
</IfModule>
#php
AddType application/x-httpd-php .php
AddType application/x-httpd-php-source .phps
Include etc/apache22/Includes/*.conf
