Braeuchte etwas hilfe bei einem obskuren X problem.
SierraX
ich hatte heute mein OpenBSD 6.4 auf dem GPD Win 2 upgedated und X auch schon eine weile nicht mehr benutzt.
Deshalb bin ich mir nicht sicher, seit wann dieses Problem existiert...
Wenn ich als user versuche mit startx versuche X zu starten, bricht er nach einer Weile ab. Und schreibt mir das folgende ins log
[    64.492]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[    64.510] X Protocol Version 11, Revision 0
[    64.518] Build Operating System: OpenBSD 6.4 amd64
[    64.522] Current Operating System: OpenBSD gpdwin2.sx-lab2.net 6.4 GENERIC.MP#437 amd64
[    64.526] Build Date: 12 November 2018  08:26:33PM
[    64.529]
[    64.533] Current version of pixman: 0.34.0
[    64.536]    Before reporting problems, check http://wiki.x.org
[    64.536] Markers: (--) probed, (**) from config file, (==) default setting,
[    64.551] (==) Log file: "/home/sierrax/.local/share/xorg/Xorg.0.log", Time: Tue Nov 13 19:52:01 2018
[    64.556] (==) Using system config directory "/usr/X11R6/share/X11/xorg.conf.d"
[    64.557] (==) No Layout section.  Using the first Screen section.
[    64.557] (==) No screen section available. Using defaults.
[    64.557] (**) |-->Screen "Default Screen Section" (0)
[    64.557] (**) |   |-->Monitor "<default monitor>"
[    64.558] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    64.558] (==) Automatically adding devices
[    64.558] (==) Automatically enabling devices
[    64.558] (==) Not automatically adding GPU devices
[    64.559] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    64.565] (==) FontPath set to:
        /usr/X11R6/lib/X11/fonts/misc/,
        /usr/X11R6/lib/X11/fonts/TTF/,
        /usr/X11R6/lib/X11/fonts/OTF/,
        /usr/X11R6/lib/X11/fonts/Type1/,
        /usr/X11R6/lib/X11/fonts/100dpi/,
        /usr/X11R6/lib/X11/fonts/75dpi/
[    64.565] (==) ModulePath set to "/usr/X11R6/lib/modules"
[    64.565] (II) The server relies on wscons to provide the list of input devices.
        If no devices become available, reconfigure wscons or disable AutoAddDevices.
[    64.565] (II) Loader magic: 0x269d06ce000
[    64.565] (II) Module ABI versions:
[    64.565]    X.Org ANSI C Emulation: 0.4
[    64.565]    X.Org Video Driver: 23.0
[    64.565]    X.Org XInput driver : 24.1
[    64.565]    X.Org Server Extension : 10.0
[    64.566] (WW) checkDevMem: failed to open /dev/xf86 and /dev/mem
        (Permission denied)
        Check that you have set 'machdep.allowaperture=1'
        in /etc/sysctl.conf and reboot your machine
        refer to xf86(4) for details
[    64.566]    linear framebuffer access unavailable
[    64.566] (II) LoadModule: "glx"
[    64.568] (II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
[    64.583] (II) Module glx: vendor="X.Org Foundation"
[    64.583]    compiled for 1.19.6, module version = 1.0.0
[    64.583]    ABI class: X.Org Server Extension, version 10.0
[    64.583] (==) Assigned the driver to the xf86ConfigLayout
[    64.583] (EE) No drivers available.
[    64.583] (EE)
Fatal server error:
[    64.587] (EE) no screens found(EE)
[    64.590] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[    64.594] (EE) Please also check the log file at "/home/sierrax/.local/share/xorg/Xorg.0.log" for additional information.
[    64.597] (EE)
[    64.602] (EE) Server terminated with error (1). Closing log file.
Es muss imho irgendwas mit den User rechten zu tun haben... ein doas startx funktioniert naemlich.
SierraX
dank dir für die schnelle Hilfe...
also doch ein rechte Problem... aber leider nix das ich ändern könnte oder in absehbarer Zukunft geändert würde ...
f..k ey ich will keinen wm...
