Conky+Lua findet cairo nicht
Gronau
ich hab versucht Conky nach diesem Tutorial zu konfigurieren, aber beim Starten findet Conky cairo anscheinend nicht:
Conky: llua_load: /home/jens/.conky/clock_rings.lua:200: module 'cairo' not found:
        no field package.preload['cairo']
        no file './cairo.lua'
        no file '/usr/local/share/lua/5.1/cairo.lua'
        no file '/usr/local/share/lua/5.1/cairo/init.lua'
        no file '/usr/local/lib/lua/5.1/cairo.lua'
        no file '/usr/local/lib/lua/5.1/cairo/init.lua'
        no file '/usr/local/lib/conky/libcairo.so'
        no file './cairo.so'
        no file '/usr/local/lib/lua/5.1/cairo.so'
        no file '/usr/local/lib/lua/5.1/loadall.so'
Conky: unknown variable weather
cat: /etc/issue.net: No such file or directory
Conky: desktop window (15a) is root window
Conky: window type - override
Conky: drawing to created window (0x1200001)
Conky: drawing to double buffer
Conky: llua_do_call: function conky_clock_rings execution failed: attempt to call a nil value
Laut conky -v ist Cairo und Lua aber einkompiliert:
conky -v
Conky 1.8.1 compiled Thu Sep 20 23:25:39 CEST 2012 for FreeBSD 9.0-RELEASE (amd64)
Compiled in features:
System config file: /usr/local/etc/conky/conky.conf
Package library path: /usr/local/lib/conky
 X11:
  * Xdamage extension
  * XDBE (double buffer extension)
  * Xft
  * ARGB visual
 Music detection:
  * MOC
 General:
  * math
  * config-output
  * Imlib2
  * iostats
  * Lua
  Lua bindings:
   * Cairo
   * Imlib2
Hat jemand eine Idee was ich falsch mache?
Wenn ich das probiere, findet er die libcairo.so nicht :(
/bin/sh ../libtool --tag=CC    --mode=link cc -I/usr/local/include/cairo -D_REENTRANT -I/usr/local/include/glib-2.0 -I/usr/local/include/pixman-1 -I/usr/local/include/freetype2 -I/usr/local/include/libpng15 -D_THREAD_SAFE -I/usr/local/include -I/usr/local/include/cairo -D_REENTRANT -I/usr/local/include/glib-2.0 -I/usr/local/include/pixman-1 -I/usr/local/include/freetype2 -I/usr/local/include/libpng15 -D_THREAD_SAFE -I/usr/local/include -O2 -pipe -march=core2 -fno-strict-aliasing  -I/usr/local/include/lua51  -O2 -pipe -march=core2 -fno-strict-aliasing  -L/usr/local/lib -o libcairo.la -rpath  /usr/local/lib/conky libcairo_la-libcairo.lo -L/usr/local/lib -lcairo -pthread -lcairo -pthread -L/usr/local/lib -lX11 -ltolua++-5.1   -L/usr/local/lib/lua51 -llua -lm -ltolua++-5.1
libtool: link: rm -fr  .libs/libcairo.a .libs/libcairo.la .libs/libcairo.lai .libs/libcairo.so .libs/libcairo.so.0
libtool: link: cc -shared  .libs/libcairo_la-libcairo.o   -Wl,-rpath -Wl,/usr/ports/sysutils/conky/work/conky-1.8.1/lua/.libs -Wl,-rpath -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/local/lib/conky -Wl,-rpath -Wl,/usr/local/lib -L/usr/local/lib /usr/ports/sysutils/conky/work/conky-1.8.1/lua/.libs/libcairo.so -L/usr/local/lib/lua51 /usr/local/lib/libX11.so -llua -lm -ltolua++-5.1  -march=core2 -march=core2 -pthread -pthread   -pthread -Wl,-soname -Wl,libcairo.so.0 -o .libs/libcairo.so.0
cc: /usr/ports/sysutils/conky/work/conky-1.8.1/lua/.libs/libcairo.so: No such file or directory
*** Error code 1
Stop in /usr/ports/sysutils/conky/work/conky-1.8.1/lua.
*** Error code 1
