controller oder festplatte? was ist def.
happy
Hallo ihr lieben,
folgendes Problem.
Der rechner freirt ein nach ner weile, wenn er auf einem raidconntroller fsck standartmässig beim booten macht.
Man kann peer SSH conneten bekommt aber kein Promt zu sehen , ping geht auch noch.
hir ausschnitt aus dmesg.
Copyright (c) 1992-2003 The FreeBSD Project.
FreeBSD 5.1-RELEASE-p11 #3: Sat Dec 20 15:28:20 CET 2003
    [email]root@evelin.carrier66.net[/email]:/usr/obj/usr/src/sys/EVELIN
Preloaded elf kernel "/boot/kernel/kernel" at 0xc06e8000.
Preloaded elf module "/boot/kernel/acpi.ko" at 0xc06e8244.
Timecounter "i8254"  frequency 1193182 Hz
Timecounter "TSC"  frequency 2394013404 Hz
CPU: Intel(R) Pentium(R) 4 CPU 2.40GHz (2394.01-MHz 686-class CPU)
  Origin = "GenuineIntel"  Id = 0xf27  Stepping = 7
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
real memory  = 532660224 (507 MB)
avail memory = 509911040 (486 MB)
Pentium Pro MTRR support enabled
npx0: INT 16 interface
acpi0: <ASUS   P4S533MX> on motherboard
pcibios: BIOS version 2.10
Using $PIR table, 7 entries at 0xc00f15c0
acpi0: power button is handled as a fixed feature programming model.
Timecounter "ACPI-fast"  frequency 3579545 Hz
acpi_timer0: <24-bit timer at 3.579545MHz> port 0xe408-0xe40b on acpi0
acpi_cpu0: <CPU> on acpi0
acpi_cpu1: <CPU> on acpi0
pci0: <ACPI PCI bus> on pcib0
agp0: <SIS Generic host to PCI bridge> mem 0xef000000-0xef3fffff at device 0.0 on pci0
pci1: <ACPI PCI bus> on pcib1
isab0: <PCI-ISA bridge> at device 2.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <SiS 962 UDMA133 controller> port 0xa400-0xa40f,0xa800-0xa803,0xb000-0xb007,0xb400-0xb403,0xb800-0xb807 irq 11 at device 2.5 on pci0
ata0: at 0x1f0 irq 14 on atapci0
ata1: at 0x170 irq 15 on atapci0
fxp0: <Intel 82557/8/9 EtherExpress Pro/100(B) Ethernet> port 0x8400-0x843f mem 0xeb800000-0xeb81ffff,0xec000000-0xec000fff irq 10 at device 15.0 on pci0
fxp0: Ethernet address 00:02:b3:da:29:7d
miibus0: <MII bus> on fxp0
inphy0: <i82555 10/100 media interface> on miibus0
inphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
atkbd0: <AT Keyboard> flags 0x1 irq 1 on atkbdc0
kbd0 at atkbd0
orm0: <Option ROMs> at iomem 0xcc000-0xcd7ff,0xc0000-0xcbfff on isa0
pmtimer0 on isa0
fdc0: cannot reserve I/O port range (6 ports)
ppc0: parallel port not found.
sio0: configured irq 4 not in bitmap of probed irqs 0
sio0: port may not be enabled
sio0: type 8250 or not responding
sio1: port may not be enabled
ipfw2 initialized, divert disabled, rule-based forwarding enabled, default to accept, logging disabled
DUMMYNET initialized (011031)
IP Filter: v3.4.31 initialized.  Default = pass all, Logging = enabled
acpi_cpu: throttling enabled, 8 steps (100% to 12.5%), currently 100.0%
ad0: 114473MB <WDC WD1200JB-32FUA0> [232581/16/63] at ata0-master UDMA100
ad1: 114473MB <ST3120022A> [232581/16/63] at ata0-slave UDMA100
ad2: 117246MB <Maxtor 6Y120L0> [238216/16/63] at ata1-master UDMA133
ad3: 117246MB <Maxtor 6Y120L0> [238216/16/63] at ata1-slave UDMA133
Mounting root from ufs:/dev/ad0s1a
WARNING: / was not properly dismounted
WARNING: /tmp was not properly dismounted
WARNING: /usr was not properly dismounted
/usr: mount pending error: blocks 324 files 78
/usr: superblock summary recomputed
WARNING: /var was not properly dismounted
/var: mount pending error: blocks 556 files 4
und weiter gehts unter andrem mit
Fatal trap 12: page fault while in kernel mode
fault virtual address   = 0x14
fault code              = supervisor read, page not present
instruction pointer     = 0x8:0xc41c3dc3
stack pointer           = 0x10:0xd8dd8b98
frame pointer           = 0x10:0xd8dd8cb0
code segment            = base 0x0, limit 0xfffff, type 0x1b
                        = DPL 0, pres 1, def32 1, gran 1
processor eflags        = interrupt enabled, resume, IOPL = 0
current process         = 517 (df)
trap number             = 12
panic: page fault
syncing disks, buffers remaining... 2933 2934 2930 2931 2926 2929 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926 2926
giving up on 2802 buffers
Uptime: 1m42s
Dumping 507 MB
ata0: resetting devices ..
done
 16 32 48 64 80 96 112 128 144 160 176 192 208 224 240 256 272 288 304 320 336 352 368 384 400 416 432 448 464 480 496Copyright (c)
habe damals mit "Concatenated-Disk (CCD)" ein softraid gebastellt in der /var/log/messages tauchen manchmal fehler auf wie diese
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 2 block 206702992 (ccd block 826811904)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 3 block 206702992 (ccd block 826811904)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 2 block 206703056 (ccd block 826812160)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 3 block 206703056 (ccd block 826812160)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 2 block 206703184 (ccd block 826812672)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 3 block 206703184 (ccd block 826812672)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 2 block 206703248 (ccd block 826812928)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 3 block 206703248 (ccd block 826812928)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 2 block 206703376 (ccd block 826813440)
Feb 19 11:54:09 evelin kernel: ccd0: error 6 on component 3 block 206703376 (ccd block 826813440)
ich weis, das schaut aus nach defekten festplatten , aber die fatal trap 12 verwirt mich, jetzt weiss ich nicht, sind das die platten oder der komischer controller.
oder soll ich vinum als softraid nehmen?
Hallo Happy,
hast Du probeweise mal acpi abgeschaltet?
acpi hat sich oft als Störenfried erwiesen.
Grüße
Jürgen
