devel/boost-libs lässt sich nicht installieren
Sickboy
Müßiggänger
ich versuche gerade Gimp aus den Ports zu installieren (portmaster -d graphics/gimp). Leider scheitert es an devel/boost-libs:
{standard input}: Assembler messages:
{standard input}:13590: Warning: end of file not at end of a line; newline inserted
c++: Internal error: Killed: 9 (program cc1plus)
Please submit a full bug report.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
    "c++"  -ftemplate-depth-128 -O2 -pipe -fno-strict-aliasing -Wno-long-long -finline-functions -Wno-inline -Wall -pthread  -DBOOST_ALL_NO_LIB=1 -DBOOST_THREAD_USE_LIB=1 -DNDEBUG  -I"." -c -o "bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_cpp_exprgrammar.o" "libs/wave/src/instantiate_cpp_exprgrammar.cpp"
...failed gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_cpp_exprgrammar.o...
...removing bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_cpp_exprgrammar.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_cpp_grammar.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_defined_grammar.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_cpp_literalgrs.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_re2c_lexer.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_predef_macros.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/token_ids.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/wave_config_constant.o
common.mkdir bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/cpplexer
common.mkdir bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/cpplexer/re2clex
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/cpplexer/re2clex/aq.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/instantiate_re2c_lexer_str.o
gcc.compile.c++ bin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi/cpplexer/re2clex/cpp_re.o
...skipped <pbin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi>libboost_wave.a(clean) for lack of <pbin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi>instantiate_cpp_exprgrammar.o...
...skipped <pbin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi>libboost_wave.a for lack of <pbin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi>instantiate_cpp_exprgrammar.o...
...skipped <pstage/lib>libboost_wave.a for lack of <pbin.v2/libs/wave/build/gcc-4.2.1/release/link-static/threading-multi>libboost_wave.a...
...failed updating 3 targets...
...skipped 8 targets...
...updated 616 targets...
*** Error code 1
*** Error code 1
Stop in /usr/ports/devel/boost-libs.
*** Error code 1
===>>> make failed for devel/boost-libs
===>>> Aborting update
===>>> Update for devel/boost-libs failed
===>>> Update for graphics/libopenraw failed
===>>> Update for graphics/gegl failed
===>>> Update for graphics/gimp-app failed
System: 8.2-RELEASE-p2 (amd64)
Weiß jemand Rat?
Ich habe jetzt einfach mittels --force-config die Config überarbeitet und ohne boost-libs-Abhängigkeit installiert.
