Copyright (c) 1992-2011 The FreeBSD Project.
FreeBSD 9.0-CURRENT #5: Mon Jun 27 07:05:57 CST 2011
root@trinity.the-wire.de:/usr/obj/usr/src/sys/TRINKERNEL i386
CPU: Genuine Intel(R) CPU U2500 @ 1.20GHz (1197.34-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0x6e8 Family = 6 Model = e Stepping = 8
Features=0xbfe9fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0xc1a9<SSE3,MON,VMX,EST,TM2,xTPR,PDCM>
AMD Features=0x100000<NX>
TSC: P-state invariant, performance statistics
real memory = 1610612736 (1536 MB)
avail memory = 1545191424 (1473 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <DELL M07 >
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.0> irqs 0-23 on motherboard
Cuse4BSD v0.1.14 @ /dev/cuse
kbd1 at kbdmux0
acpi0: <DELL M07 > on motherboard
acpi0: reservation of 0, 9fc00 (3) failed
acpi0: reservation of 100000, 5f591400 (3) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
acpi_acad0: <AC Adapter> on acpi0
battery0: <ACPI Control Method Battery> on acpi0
acpi_lid0: <Control Method Lid Switch> on acpi0
acpi_button1: <Sleep Button> on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xeff8-0xefff mem 0xdff00000-0xdff7ffff,0xc0000000-0xcfffffff,0xdfec0000-0xdfefffff irq 16 at device 2.0 on pci0
agp0: <Intel 82945GM (945GM GMCH) SVGA controller> on vgapci0
agp0: aperture size is 256M, detected 7932k stolen memory
vgapci1: <VGA-compatible display> mem 0xdff80000-0xdfffffff at device 2.1 on pci0
hdac0: <Intel 82801G High Definition Audio Controller> mem 0xdfebc000-0xdfebffff irq 21 at device 27.0 on pci0
pcib1: <ACPI PCI-PCI bridge> at device 28.0 on pci0
pci11: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> at device 28.1 on pci0
pci12: <ACPI PCI bus> on pcib2
siba_bwn0: <Broadcom BCM4311 802.11b/g Wireless> mem 0xdfdfc000-0xdfdfffff irq 17 at device 0.0 on pci12
siba_bwn0: unsupported coreid (USB 1.1 Host)
bwn0 on siba_bwn0
bwn0: WLAN (chipid 0x4311 rev 10) PHY (analog 4 type 2 rev 8) RADIO (manuf 0x17f ver 0x2050 rev 2)
bwn0: DMA (32 bits)
bwn0: Using 1 MSI messages
pcib3: <ACPI PCI-PCI bridge> at device 28.2 on pci0
pci9: <ACPI PCI bus> on pcib3
bge0: <Broadcom NetXtreme Gigabit Ethernet Controller, ASIC rev. 0x006002> mem 0xdfcf0000-0xdfcfffff irq 18 at device 0.0 on pci9
bge0: CHIP ID 0x00006002; ASIC REV 0x06; CHIP REV 0x60; PCI-E
miibus0: <MII bus> on bge0
brgphy0: <BCM5752 1000BASE-T media interface> PHY 1 on miibus0
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Ethernet address: 00:15:c5:4e:90:28
uhci0: <Intel 82801G (ICH7) USB controller USB-A> port 0xbf80-0xbf9f irq 20 at device 29.0 on pci0
usbus0: <Intel 82801G (ICH7) USB controller USB-A> on uhci0
uhci1: <Intel 82801G (ICH7) USB controller USB-B> port 0xbf60-0xbf7f irq 21 at device 29.1 on pci0
usbus1: <Intel 82801G (ICH7) USB controller USB-B> on uhci1
uhci2: <Intel 82801G (ICH7) USB controller USB-C> port 0xbf40-0xbf5f irq 22 at device 29.2 on pci0
usbus2: <Intel 82801G (ICH7) USB controller USB-C> on uhci2
uhci3: <Intel 82801G (ICH7) USB controller USB-D> port 0xbf20-0xbf3f irq 23 at device 29.3 on pci0
usbus3: <Intel 82801G (ICH7) USB controller USB-D> on uhci3
ehci0: <Intel 82801GB/R (ICH7) USB 2.0 controller> mem 0xffa80000-0xffa803ff irq 20 at device 29.7 on pci0
usbus4: EHCI version 1.0
usbus4: <Intel 82801GB/R (ICH7) USB 2.0 controller> on ehci0
pcib4: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci2: <ACPI PCI bus> on pcib4
cbb0: <RF5C476 PCI-CardBus Bridge> at device 1.0 on pci2
fwohci0: <Ricoh R5C552> mem 0xdfbff800-0xdfbfffff irq 17 at device 1.1 on pci2
fwohci0: OHCI version 1.10 (ROM=0)
fwohci0: No. of Isochronous channels is 4.
fwohci0: EUI64 38:4f:c0:00:38:e3:bc:50
fwohci0: Phy 1394a available S400, 2 ports.
dcons_crom0: <dcons configuration ROM> on firewire0
dcons_crom0: bus_addr 0x5db38000
if_fwe0: Fake Ethernet address: 3a:4f:c0:e3:bc:50
fwe0: Ethernet address: 3a:4f:c0:e3:bc:50
fwip0: <IP over FireWire> on firewire0
fwip0: Firewire address: 38:4f:c0:00:38:e3:bc:50 @ 0xfffe00000000, S400, maxrec 2048
fwohci0: Initiate bus reset
fwohci0: fwohci_intr_core: BUS reset
fwohci0: fwohci_intr_core: node_id=0x00000000, SelfID Count=1, CYCLEMASTER mode
pci2: <base peripheral, SD host controller> at device 1.2 (no driver attached)
isa0: <ISA bus> on isab0
atapci0: <Intel ICH7 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xbfa0-0xbfaf irq 16 at device 31.1 on pci0
ata0: <ATA channel 0> on atapci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64,0x62,0x66 irq 1 on acpi0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: [GIANT-LOCKED]
psm0: model GlidePoint, device ID 0
atrtc0: <AT realtime clock> port 0x70-0x71,0x72-0x77 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 2 on acpi0
Event timer "i8254" frequency 1193182 Hz quality 100
pmtimer0 on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xce7ff,0xce800-0xcffff pnpid ORM0000 on isa0
ppc0: parallel port not found.
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
firewire0: 1 nodes, maxhop <= 0 cable IRM irm(0) (me)
firewire0: bus manager 0
hdac0: HDA Codec #0: Sigmatel STAC9220
pcm0: <HDA Sigmatel STAC9220 PCM #0 Analog> at cad 0 nid 1 on hdac0
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 12Mbps Full Speed USB v1.0
usbus4: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <Intel> at usbus3
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus3
ugen4.1: <Intel> at usbus4
uhub4: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus4
uhub3: 2 ports with 2 removable, self powered
uhub4: 8 ports with 8 removable, self powered
ugen4.2: <vendor 0x413c> at usbus4
uhub5: <vendor 0x413c product 0xa005, class 9/0, rev 2.00/50.18, addr 2> on usbus4
ada0 at ata0 bus 0 scbus1 target 0 lun 0
ada0: <TOSHIBA MK6008GAH BU011A> ATA-6 device
ada0: 100.000MB/s transfers (UDMA5, PIO 8192bytes)
ada0: 57231MB (117210240 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad0
SMP: AP CPU #1 Launched!
uhub5: 4 ports with 0 removable, self powered
Root mount waiting for: usbus4
ugen4.3: <vendor 0x0b97> at usbus4
uhub6: <vendor 0x0b97 product 0x7761, class 9/0, rev 1.10/1.10, addr 3> on usbus4
uhub6: 3 ports with 2 removable, bus powered
ugen4.4: <O2> at usbus4
ugen4.5: <vendor 0x413c> at usbus4
Trying to mount root from ufs:/dev/ad0s2a [rw,noatime]...
WARNING: /usr was not properly dismounted
WARNING: /var was not properly dismounted
bwn0: firmware version (rev 410 patch 2160 date 0x751a time 0x7c0a)
wlan0: Ethernet address: 00:16:cf:59:9b:d6
bwn0: status of RF switch is changed to OFF
bwn0: please turn on the RF switch
drm0: <Intel i945GM> on vgapci0
info: [drm] AGP at 0xc0000000 256MB
info: [drm] Initialized i915 1.6.0 20080730
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
