tboston
Servus,
ich versuche mittlerweile seit zwei Tagen einen 'Brother HL-5240' auf meiner FreeBSD 11 Kiste zum laufen zu bekommen. Endet jeweils mit LIBDBUS errors.
In deiesem Fall wollte ich print/cups-filters installieren. Ähnliche Fehler bekomme ich beim Versuch gutenprint Treiber zu installieren.
Hat das mal jemand gehabt oder hat grob nen Lösungsvorschlag?
Grüße,
Tony
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_get_path@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_watch_get_enabled@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_recurse@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_unref@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_set_timeout_functions@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_timeout_get_interval@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_bus_get_private@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_get_is_connected@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_get_args@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_add_filter@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_dispatch@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_is_signal@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_get_arg_type@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_get_member@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_watch_get_data@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_timeout_handle@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_timeout_get_data@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_watch_handle@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_timeout_set_data@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_next@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_bus_add_match@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_watch_get_flags@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_ref@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_init_append@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_error_free@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_send_with_reply_and_block@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_get_element_type@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_watch_set_data@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_init@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_timeout_get_enabled@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_close_container@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_set_dispatch_status_function@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_set_watch_functions@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_watch_get_unix_fd@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_get_dispatch_status@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_error_is_set@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_get_fixed_array@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_get_interface@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_close@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_open_container@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_append_args@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_get_basic@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_error_init@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_unref@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_new_method_call@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_message_iter_append_fixed_array@LIBDBUS_1_3'
/usr/local/lib/libavahi-client.so: undefined reference to `dbus_connection_set_exit_on_disconnect@LIBDBUS_1_3'
cc: error: linker command failed with exit code 1 (use -v to see invocation)
gmake[3]: *** [Makefile:2181: cups-browsed] Error 1
gmake[3]: Leaving directory '/usr/ports/print/cups-filters/work/cups-filters-1.9.0'
gmake[2]: *** [Makefile:1794: all] Error 2
gmake[2]: Leaving directory '/usr/ports/print/cups-filters/work/cups-filters-1.9.0'
Grüße,
Tony
