DSL mit ppp läuft nicht
albix
Ich habe nun schon unzählige ppp.conf versucht, aber mit keiner konnte ich mich ins Internet einwählen!
Beim manuellen Start von ppp, mit "ppp" und hinterher "dial" wird nur das erste "Ppp" groß, dann stellt es sich wieder ein auf "ppp".
Meine Daten:
FreeBSD 5.3-p5
Provider: Freenet AG
Modem: Teledat Telekom
ppp.conf:
default:
 #PPP over Ethernet
 set device PPPoE:rl0
 set speed sync
 set mru 1492
 set mtu 1492
 set dial
 set crtscts on
 accept lqr
 disable deflate
 disable pred1
 disable vjcomp
 disable acfcomp
 disable protocomp
 set log Phase LCP IPCP CCP Warning Error Alert
 set ifaddr 10.0.0.1/0 10.0.0.2/0 0.0.0.0 0.0.0.0
 add default HISADDR
 #enable dns
 set login
 set authname frn6/login
 set authkey PINPasswort
resolv.conf
nameserver 194.97.173.124
nameserver 194.97.173.125
nameserver 217.5.99.105
nameserver 194.25.2.129
Auszug aus ppp.log
Feb  6 20:26:53 pluto ppp[217]: Phase: deflink: hangup -> opening
Feb  6 20:26:53 pluto ppp[217]: Phase: deflink: Enter pause (3) for redialing.
Feb  6 20:26:53 pluto ppp[217]: Phase: deflink: Connected!
Feb  6 20:26:54 pluto ppp[217]: Phase: deflink: opening -> dial
Feb  6 20:26:54 pluto ppp[217]: Phase: deflink: dial -> carrier
Feb  6 20:26:54 pluto ppp[217]: Phase: Received NGM_PPPOE_ACNAME (hook "KONX11-erx")
Feb  6 20:26:54 pluto ppp[217]: Phase: Received NGM_PPPOE_SESSIONID
Feb  6 20:26:54 pluto ppp[217]: Phase: Received NGM_PPPOE_SUCCESS
Feb  6 20:26:54 pluto ppp[217]: Phase: deflink: carrier -> login
Feb  6 20:26:54 pluto ppp[217]: Phase: deflink: login -> lcp
Feb  6 20:26:54 pluto ppp[217]: LCP: FSM: Using "deflink" as a transport
Feb  6 20:26:54 pluto ppp[217]: LCP: deflink: State change Initial --> Closed
Feb  6 20:26:54 pluto ppp[217]: LCP: deflink: State change Closed --> Stopped
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: RecvConfigReq(202) state = Stopped
Feb  6 20:26:55 pluto ppp[217]: LCP:  MRU[4] 1492
Feb  6 20:26:55 pluto ppp[217]: LCP:  AUTHPROTO[4] 0xc023 (PAP)
Feb  6 20:26:55 pluto ppp[217]: LCP:  MAGICNUM[6] 0x5dee1603
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: SendConfigReq(1) state = Stopped
Feb  6 20:26:55 pluto ppp[217]: LCP:  MAGICNUM[6] 0xaa0e88f5
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: SendConfigAck(202) state = Stopped
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: LayerStart
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: State change Stopped --> Ack-Sent
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: RecvConfigAck(1) state = Ack-Sent
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: State change Ack-Sent --> Opened
Feb  6 20:26:55 pluto ppp[217]: LCP: deflink: LayerUp
Feb  6 20:26:55 pluto ppp[217]: Phase: bundle: Authenticate
Feb  6 20:26:55 pluto ppp[217]: Phase: deflink: his = PAP, mine = none
Feb  6 20:26:55 pluto ppp[217]: Phase: Pap Output: frn6/login ********
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(2) state = Opened
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: LayerDown
Feb  6 20:26:57 pluto ppp[217]: LCP:  MRU[4] 1492
Feb  6 20:26:57 pluto ppp[217]: LCP:  AUTHPROTO[4] 0xc023 (PAP)
Feb  6 20:26:57 pluto ppp[217]: LCP:  MAGICNUM[6] 0xa871e66a
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigReq(2) state = Opened
Feb  6 20:26:57 pluto ppp[217]: LCP:  MAGICNUM[6] 0x1835d561
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigAck(2) state = Opened
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: State change Opened --> Ack-Sent
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigAck(2) state = Ack-Sent
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: State change Ack-Sent --> Opened
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: LayerUp
Feb  6 20:26:57 pluto ppp[217]: Phase: deflink: his = PAP, mine = none
Feb  6 20:26:57 pluto ppp[217]: Phase: Pap Output: frn6/login ********
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(253) state = Opened
Feb  6 20:26:57 pluto ppp[217]: LCP:  MRU[4] 1454
Feb  6 20:26:57 pluto ppp[217]: LCP:  AUTHPROTO[5] 0xc223 (CHAP 0x05)
Feb  6 20:26:57 pluto ppp[217]: LCP:  MAGICNUM[6] 0x4309025d
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigReq(3) state = Opened
Feb  6 20:26:57 pluto ppp[217]: LCP:  MAGICNUM[6] 0xa357b956
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(253) state = Opened
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: State change Opened --> Req-Sent
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigAck(3) state = Req-Sent
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: State change Req-Sent --> Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(254) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(254) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(255) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(255) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(0) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(0) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(1) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(1) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(2) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(2) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(3) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(3) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: RecvConfigReq(4) state = Ack-Rcvd
Feb  6 20:26:57 pluto ppp[217]: LCP: deflink: SendConfigNak(4) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvConfigReq(5) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP:  MRU[4] 1454
Feb  6 20:26:58 pluto ppp[217]: LCP:  AUTHPROTO[5] 0xc223 (CHAP 0x05)
Feb  6 20:26:58 pluto ppp[217]: LCP:  MAGICNUM[6] 0x4309025d
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendConfigNak(5) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP:  MRU[4] 1492
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvConfigReq(6) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendConfigNak(6) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendConfigNak(8) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvConfigReq(9) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendConfigNak(9) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvConfigReq(10) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendConfigNak(10) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvConfigReq(11) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendConfigNak(11) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: Phase: deflink: Too many LCP NAKs sent - abandoning negotiation
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: SendTerminateReq(4) state = Ack-Rcvd
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: State change Ack-Rcvd --> Closing
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvConfigReq(12) state = Closing
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: Error: Got ConfigReq while state = Closing
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: RecvTerminateAck(4) state = Closing
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: LayerFinish
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: State change Closing --> Closed
Feb  6 20:26:58 pluto ppp[217]: LCP: deflink: State change Closed --> Initial
Feb  6 20:26:58 pluto ppp[217]: Phase: deflink: Disconnected!
Feb  6 20:26:58 pluto ppp[217]: Phase: deflink: lcp -> logout
Feb  6 20:26:58 pluto ppp[217]: Phase: deflink: logout -> hangup
Feb  6 20:26:58 pluto ppp[217]: Phase: deflink: Connect time: 7 secs: 430 octets in, 312 octets out
Feb  6 20:26:58 pluto ppp[217]: Phase: deflink: 22 packets in, 23 packets out
In der rc.conf steht bei mir:
ifconfig_rl0="up"
ppp_enable="YES"
ppp_mode="ddial"
ppp_nat="NO"
ppp_profile="default"
Netgraph ist in den Kernel kompiliert worden.
Vielen Dank schon im Voraus.
albix
Ab dieser Stelle unterscheidet sich dein Log von meinem:
Feb  6 22:24:20 hoppel ppp[55321]: Phase: bundle: Authenticate
Feb  6 22:24:20 hoppel ppp[55321]: Phase: deflink: his = PAP, mine = none
Feb  6 22:24:20 hoppel ppp[55321]: Phase: Pap Output: cpeXXXXX@qdsl.de ********
Feb  6 22:24:20 hoppel ppp[55321]: Phase: Pap Input: SUCCESS ()
Ich nehme an, dass deine Zugangsdaten korrekt sind. Es ist nur eine wage Vermutung: vielleicht liegt's an dem "/" im Benutzernamen. Versuche das den mal in Anführungszeichen ('...' oder "...") zu setzen, oder mal dem / ein \ voranstellen.
Gruß Björn
Gruß Björn
Vielen Dank für die Antwort. Das mit "frn6/login" ist ein typischer Freenet Zugang. Natürlich schreibe ich für "login" meinen Login-Account hinein, aber das "frn6/" muss normalerweise vorangestellt werden. Ich versuche es mal mit dem voranstellen von \ oder mit Anführungszeichen.
albix
Erstmal vielen Dank für all die Vorschläge zur Problembehebung, allerdings muss ich sagen, dass mir nichts weitergeholfen hat.
Ich habe es probiert mit "disable lqr" und mit "frn6\/login", kein Erfolg!
Schade, ich weiß nicht mehr was ich sonst noch machen könnte...
Sobald ich "dial" eintippe wird das erste "Ppp" groß danach wieder klein.
Ich hoffe nur, dass sich noch jemand findet, der aus meinem Log etwas herauslesen könnte um mir doch weiterhelfen zu können.
Vielen Dank
albix
Jepp mein Modem läuft einwandfrei, da, jetzt kommts(!!), ich auch über einen Router online gehen kann.
Aber ich wollte einfach mal etwas probieren und dazu musste/wollte ich direkt Laptop--Modem--Internet online gehen mit ppp.
Es scheint nicht zu funktionieren, weshalb auch immer.
albix
muss mal nachfragen - ist das Problem mit Freenet gelöst, und wenn ja, wie?
Steh da nämlich ebenfalls gerade auf dem Schlauch mit Freenet.
:confused:
Gruss :cool:
