FBSD 6.0 - Kerneloption CPU_ENABLED_SSE
overle
Mausschubser
Guten Morgen,
ich habe ein komplett frisches System unter 6.0 aufgesetzt, die Sourcen und Ports sind jeweils über cvsup geupdated. Meine dmesg schaut so aus:
Copyright (c) 1992-2005 The FreeBSD Project.
FreeBSD 6.0-RELEASE #0: Thu Nov  3 09:36:13 UTC 2005
    root@x64.samsco.home:/usr/obj/usr/src/sys/GENERIC
CPU: AMD Athlon(tm) Processor (698.65-MHz 686-class CPU)
  Origin = "AuthenticAMD"  Id = 0x621  Stepping = 1
  Features=0x183f9ff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR>
  AMD Features=0xc0400800<SYSCALL,MMX+,3DNow+,3DNow>
real memory  = 402587648 (383 MB)
avail memory = 384524288 (366 MB)
npx0: [FAST]
npx0: INT 16 interface
acpi0: <AWARD MSI ACPI> on motherboard
acpi0: Power Button (fixed)
acpi0: Sleep Button (fixed)
pci_link0: <ACPI PCI Link LNKA> on acpi0
pci_link1: <ACPI PCI Link LNKB> irq 11 on acpi0
pci_link2: <ACPI PCI Link LNKC> irq 10 on acpi0
pci_link3: <ACPI PCI Link LNKD> irq 12 on acpi0
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x5008-0x500b on acpi0
cpu0: <ACPI CPU> on acpi0
acpi_throttle0: <ACPI CPU Throttling> on cpu0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff,0x5000-0x507f,0x5080-0x50ff on acpi0
pci0: <ACPI PCI bus> on pcib0
agp0: <AMD 751 host to AGP bridge> port 0xd000-0xd003 mem 0xd8000000-0xdbffffff,0xe1011000-0xe1011fff at device 0.0 on pci0
pcib1: <PCI-PCI bridge> at device 1.0 on pci0
pci1: <PCI bus> on pcib1
pci1: <display, VGA> at device 5.0 (no driver attached)
isab0: <PCI-ISA bridge> at device 7.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <AMD 756 UDMA66 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xf000-0xf00f at device 7.1 on pci0
ata0: <ATA channel 0> on atapci0
ata1: <ATA channel 1> on atapci0
pci0: <bridge> at device 7.3 (no driver attached)
atapci1: <SiI 0680 UDMA133 controller> port 0xd400-0xd407,0xd800-0xd803,0xdc00-0xdc07,0xe000-0xe003,0xe400-0xe40f mem 0xe1010000-0xe10100ff irq 11 at device 9.0 on pci0
ata2: <ATA channel 0> on atapci1
ata3: <ATA channel 1> on atapci1
bge0: <Broadcom BCM5701 Gigabit Ethernet, ASIC rev. 0x105> mem 0xe1000000-0xe100ffff irq 10 at device 10.0 on pci0
miibus0: <MII bus> on bge0
brgphy0: <BCM5701 10/100/1000baseTX PHY> on miibus0
brgphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseTX, 1000baseTX-FDX, auto
bge0: Ethernet address: 00:0a:5e:01:49:57
fdc0: <floppy drive controller> port 0x3f2-0x3f5,0x3f7 irq 6 drq 2 on acpi0
fdc0: [FAST]
sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
sio0: type 16550A
sio1: <16550A-compatible COM port> port 0x2f8-0x2ff irq 3 on acpi0
sio1: type 16550A
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
pmtimer0 on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xcffff,0xd0000-0xd1fff on isa0
ppc0: parallel port not found.
Timecounter "TSC" frequency 698648535 Hz quality 800
ad0: 38166MB <WDC WD400BB-00JHC0 05.01C05> at ata0-master UDMA66
ad2: 38166MB <WDC WD400BB-00JHC0 05.01C05> at ata1-master UDMA66
ad4: 152627MB <WDC WD1600JB-00GVA0 08.02D08> at ata2-master UDMA100
ad6: 152627MB <WDC WD1600JB-00GVA0 08.02D08> at ata3-master UDMA100
ar0: 38166MB <FreeBSD PseudoRAID RAID1> status: READY
ar0: disk0 READY (master) using ad0 at ata0-master
ar0: disk1 READY (mirror) using ad2 at ata1-master
ar1: 152625MB <LSILogic v2 MegaRAID RAID1> status: READY
ar1: disk0 READY (master) using ad4 at ata2-master
ar1: disk1 READY (mirror) using ad6 at ata3-master
Trying to mount root from ufs:/dev/ar0s1a
Ich wollte nun meinen Kernel etwas anpassen. Siehe:
# GENERIC -- Generic kernel configuration file for FreeBSD/i386
# For more information on this file, please read the handbook section on
# Kernel Configuration Files:
#    http://www.FreeBSD.org/doc/en_US.ISO8859-1/books/handbook/kernelconfig-config.html
# The handbook is also available locally in /usr/share/doc/handbook
# if you've installed the doc distribution, otherwise always see the
# FreeBSD World Wide Web server (http://www.FreeBSD.org/) for the
# latest information.
# An exhaustive list of options and more detailed explanations of the
# device lines is also present in the ../../conf/NOTES and NOTES files.
# If you are in doubt as to the purpose or necessity of a line, check first
# in NOTES.
# $FreeBSD: src/sys/i386/conf/GENERIC,v 1.429.2.3.2.1 2005/10/28 19:22:41 jhb Exp $
machine		i386
cpu		I686_CPU
ident	 	AMD-700
# Optionale FreeBSD Kernelerweiterungen
options		SC_DISABLE_KDBKEY	#debug key disabled
options		SC_DISABLE_REBOOT	#disable reboot keysequence
options		CPU_ENABLE_SSE
options		CPU_ATHLON_SSE_HACK
options		IPSEC
options		IPSTEALTH
options		MSDOSFS_LARGE		#Einbinden groser DOS-Partitionen
device		atapicam		#Emuliert ATAPI-Laufwerke als SCSI
# To statically compile in device wiring instead of /boot/device.hints
#hints		"GENERIC.hints"		# Default places to look for devices.
makeoptions	DEBUG=-g		# Build kernel with gdb(1) debug symbols
#options 	SCHED_ULE		# ULE scheduler
options 	SCHED_4BSD		# 4BSD scheduler
options 	PREEMPTION		# Enable kernel thread preemption
options 	INET			# InterNETworking
options 	INET6			# IPv6 communications protocols
options 	FFS			# Berkeley Fast Filesystem
options 	SOFTUPDATES		# Enable FFS soft updates support
options 	UFS_ACL			# Support for access control lists
options 	UFS_DIRHASH		# Improve performance on big directories
options 	MD_ROOT			# MD is a potential root device
options 	NFSCLIENT		# Network Filesystem Client
options 	NFSSERVER		# Network Filesystem Server
options 	NFS_ROOT		# NFS usable as /, requires NFSCLIENT
options 	MSDOSFS			# MSDOS Filesystem
options 	CD9660			# ISO 9660 Filesystem
options 	PROCFS			# Process filesystem (requires PSEUDOFS)
options 	PSEUDOFS		# Pseudo-filesystem framework
options 	GEOM_GPT		# GUID Partition Tables.
options 	COMPAT_43		# Compatible with BSD 4.3 [KEEP THIS!]
options 	COMPAT_FREEBSD4		# Compatible with FreeBSD4
options 	COMPAT_FREEBSD5		# Compatible with FreeBSD5
options 	SCSI_DELAY=5000		# Delay (in ms) before probing SCSI
options 	KTRACE			# ktrace(1) support
options 	SYSVSHM			# SYSV-style shared memory
options 	SYSVMSG			# SYSV-style message queues
options 	SYSVSEM			# SYSV-style semaphores
options 	_KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions
options 	KBD_INSTALL_CDEV	# install a CDEV entry in /dev
options 	AHC_REG_PRETTY_PRINT	# Print register bitfields in debug
					# output.  Adds ~128k to driver.
options 	AHD_REG_PRETTY_PRINT	# Print register bitfields in debug
					# output.  Adds ~215k to driver.
options 	ADAPTIVE_GIANT		# Giant mutex is adaptive.
device		apic			# I/O APIC
# Bus support.
device		eisa
device		pci
# Floppy drives
device		fdc
# ATA and ATAPI devices
device		ata
device		atadisk		# ATA disk drives
device		ataraid		# ATA RAID drives
device		atapicd		# ATAPI CDROM drives
device		atapifd		# ATAPI floppy drives
device		atapist		# ATAPI tape drives
options 	ATA_STATIC_ID	# Static device numbering
# SCSI Controllers
device		ahb		# EISA AHA1742 family
device		ahc		# AHA2940 and onboard AIC7xxx devices
device		ahd		# AHA39320/29320 and onboard AIC79xx devices
device		amd		# AMD 53C974 (Tekram DC-390(T))
device		isp		# Qlogic family
#device 	ispfw		# Firmware for QLogic HBAs- normally a module
device		mpt		# LSI-Logic MPT-Fusion
#device		ncr		# NCR/Symbios Logic
device		sym		# NCR/Symbios Logic (newer chipsets + those of `ncr')
device		trm		# Tekram DC395U/UW/F DC315U adapters
device		adv		# Advansys SCSI adapters
device		adw		# Advansys wide SCSI adapters
device		aha		# Adaptec 154x SCSI adapters
device		aic		# Adaptec 15[012]x SCSI adapters, AIC-6[23]60.
device		bt		# Buslogic/Mylex MultiMaster SCSI adapters
device		ncv		# NCR 53C500
device		nsp		# Workbit Ninja SCSI-3
device		stg		# TMC 18C30/18C50
# SCSI peripherals
device		scbus		# SCSI bus (required for SCSI)
device		ch		# SCSI media changers
device		da		# Direct Access (disks)
device		sa		# Sequential Access (tape etc)
device		cd		# CD
device		pass		# Passthrough device (direct SCSI access)
device		ses		# SCSI Environmental Services (and SAF-TE)
# RAID controllers interfaced to the SCSI subsystem
device		amr		# AMI MegaRAID
device		arcmsr		# Areca SATA II RAID
device		asr		# DPT SmartRAID V, VI and Adaptec SCSI RAID
device		ciss		# Compaq Smart RAID 5*
device		dpt		# DPT Smartcache III, IV - See NOTES for options
device		hptmv		# Highpoint RocketRAID 182x
device		iir		# Intel Integrated RAID
device		ips		# IBM (Adaptec) ServeRAID
device		mly		# Mylex AcceleRAID/eXtremeRAID
device		twa		# 3ware 9000 series PATA/SATA RAID
# RAID controllers
device		aac		# Adaptec FSA RAID
device		aacp		# SCSI passthrough for aac (requires CAM)
device		ida		# Compaq Smart RAID
device		mlx		# Mylex DAC960 family
device		pst		# Promise Supertrak SX6000
device		twe		# 3ware ATA RAID
# atkbdc0 controls both the keyboard and the PS/2 mouse
device		atkbdc		# AT keyboard controller
device		atkbd		# AT keyboard
device		psm		# PS/2 mouse
device		vga		# VGA video card driver
device		splash		# Splash screen and screen saver support
# syscons is the default console driver, resembling an SCO console
device		sc
# Enable this for the pcvt (VT220 compatible) console driver
#device		vt
#options 	XSERVER		# support for X server on a vt console
#options 	FAT_CURSOR	# start with block cursor
device		agp		# support several AGP chipsets
# Power management support (see NOTES for more options)
#device		apm
# Add suspend/resume support for the i8254.
device		pmtimer
# PCCARD (PCMCIA) support
# PCMCIA and cardbus bridge support
device		cbb		# cardbus (yenta) bridge
device		pccard		# PC Card (16-bit) bus
device		cardbus		# CardBus (32-bit) bus
# Serial (COM) ports
device		sio		# 8250, 16[45]50 based serial ports
# Parallel port
device		ppc
device		ppbus		# Parallel port bus (required)
device		lpt		# Printer
device		plip		# TCP/IP over parallel
device		ppi		# Parallel port interface device
#device		vpo		# Requires scbus and da
# If you've got a "dumb" serial or parallel PCI card that is
# supported by the puc(4) glue driver, uncomment the following
# line to enable it (connects to the sio and/or ppc drivers):
#device		puc
# PCI Ethernet NICs.
device		de		# DEC/Intel DC21x4x (``Tulip'')
device		em		# Intel PRO/1000 adapter Gigabit Ethernet Card
device		ixgb		# Intel PRO/10GbE Ethernet Card
device		txp		# 3Com 3cR990 (``Typhoon'')
device		vx		# 3Com 3c590, 3c595 (``Vortex'')
# PCI Ethernet NICs that use the common MII bus controller code.
# NOTE: Be sure to keep the 'device miibus' line in order to use these NICs!
device		miibus		# MII bus support
device		bfe		# Broadcom BCM440x 10/100 Ethernet
device		bge		# Broadcom BCM570xx Gigabit Ethernet
device		dc		# DEC/Intel 21143 and various workalikes
device		fxp		# Intel EtherExpress PRO/100B (82557, 82558)
device		lge		# Level 1 LXT1001 gigabit Ethernet
device		nge		# NatSemi DP83820 gigabit Ethernet
device		nve		# nVidia nForce MCP on-board Ethernet Networking
device		pcn		# AMD Am79C97x PCI 10/100(precedence over 'lnc')
device		re		# RealTek 8139C+/8169/8169S/8110S
device		rl		# RealTek 8129/8139
device		sf		# Adaptec AIC-6915 (``Starfire'')
device		sis		# Silicon Integrated Systems SiS 900/SiS 7016
device		sk		# SysKonnect SK-984x & SK-982x gigabit Ethernet
device		ste		# Sundance ST201 (D-Link DFE-550TX)
device		ti		# Alteon Networks Tigon I/II gigabit Ethernet
device		tl		# Texas Instruments ThunderLAN
device		tx		# SMC EtherPower II (83c170 ``EPIC'')
device		vge		# VIA VT612x gigabit Ethernet
device		vr		# VIA Rhine, Rhine II
device		wb		# Winbond W89C840F
device		xl		# 3Com 3c90x (``Boomerang'', ``Cyclone'')
# ISA Ethernet NICs.  pccard NICs included.
device		cs		# Crystal Semiconductor CS89x0 NIC
# 'device ed' requires 'device miibus'
device		ed		# NE[12]000, SMC Ultra, 3c503, DS8390 cards
device		ex		# Intel EtherExpress Pro/10 and Pro/10+
device		ep		# Etherlink III based cards
device		fe		# Fujitsu MB8696x based cards
device		ie		# EtherExpress 8/16, 3C507, StarLAN 10 etc.
device		lnc		# NE2100, NE32-VL Lance Ethernet cards
device		sn		# SMC's 9000 series of Ethernet chips
device		xe		# Xircom pccard Ethernet
# ISA devices that use the old ISA shims
#device		le
# Wireless NIC cards
device		wlan		# 802.11 support
device		an		# Aironet 4500/4800 802.11 wireless NICs.
device		awi		# BayStack 660 and others
device		ral		# Ralink Technology RT2500 wireless NICs.
device		wi		# WaveLAN/Intersil/Symbol 802.11 wireless NICs.
#device		wl		# Older non 802.11 Wavelan wireless NIC.
# Pseudo devices.
device		loop		# Network loopback
device		random		# Entropy device
device		ether		# Ethernet support
device		sl		# Kernel SLIP
device		ppp		# Kernel PPP
device		tun		# Packet tunnel.
device		pty		# Pseudo-ttys (telnet etc)
device		md		# Memory "disks"
device		gif		# IPv6 and IPv4 tunneling
device		faith		# IPv6-to-IPv4 relaying (translation)
# The `bpf' device enables the Berkeley Packet Filter.
# Be aware of the administrative consequences of enabling this!
# Note that 'bpf' is required for DHCP.
device		bpf		# Berkeley packet filter
# USB support
device		uhci		# UHCI PCI->USB interface
device		ohci		# OHCI PCI->USB interface
device		ehci		# EHCI PCI->USB interface (USB 2.0)
device		usb		# USB Bus (required)
#device		udbp		# USB Double Bulk Pipe devices
device		ugen		# Generic
device		uhid		# "Human Interface Devices"
device		ukbd		# Keyboard
device		ulpt		# Printer
device		umass		# Disks/Mass storage - Requires scbus and da
device		ums		# Mouse
device		ural		# Ralink Technology RT2500USB wireless NICs
device		urio		# Diamond Rio 500 MP3 player
device		uscanner	# Scanners
# USB Ethernet, requires miibus
device		aue		# ADMtek USB Ethernet
device		axe		# ASIX Electronics USB Ethernet
device		cdce		# Generic USB over Ethernet
device		cue		# CATC USB Ethernet
device		kue		# Kawasaki LSI USB Ethernet
device		rue		# RealTek RTL8150 USB Ethernet
# FireWire support
device		firewire	# FireWire bus code
device		sbp		# SCSI over FireWire (Requires scbus and da)
device		fwe		# Ethernet over FireWire (non-standard!)
Bisher lief der Kernel, mit diesen "Erweiterungen" seither (5.4) immer durch. Jetzt hängt sich FBSD 6.0 an dieser Option auf:
. Über Hintergrundinfo´s, warum das so nicht mehr funktioniert und wie es jetzt gelöst ist, würde ich mich freuen. Vielleicht ist´s ja ganz simple!
Fehlermeldungen lesen hilft.
SSE muss nicht mehr eingeschalten, sondern explizit abgeschalten werden.
Nimm die zeile einfach raus.
Also, bei mir sieht dmesg so aus;
FreeBSD 6.0-RELEASE #4: Sun Nov 20 16:28:33 CET 2005
marius@PCBSD.localhost:/usr/obj/usr/src/sys/MARIUS
ACPI APIC Table: <A M I OEMAPIC >
CPU: AMD Athlon(tm) 64 Processor 3000+ (2386.39-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x20ff0 Stepping = 0
Features=0x78bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2>
Features2=0x1<SSE3>
AMD Features=0xe2500800<SYSCALL,NX,MMX+,<b25>,LM,3DNow+,3DNow>
real memory = 2147155968 (2047 MB)
avail memory = 2087944192 (1991 MB)
Ich frage mich aber ob dein AMD-700 überhaupt SSE unterstützt? Sonst hat die Einstellung keinen wert, denke ich..
Gruß iptraf
CPU: AMD Duron(tm) Processor (650.03-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x631 Stepping = 1
AMD Features=0xc0440800<SYSCALL,<b18>,MMX+,3DNow+,3DNow>
das ist vom einem duron der auch kein sse unterstützt, sse gabs erst ab xp und duron 1000 und ss2 ab barton/sempron soweit ich weiß
hier ist noch ein link
http://www.de.tomshardware.com/cpu/20030217/cpu_charts-18.html
Also, wenn ich von eurer Aussage ausgehe, dann hätte ja schon 5.4 hier einen "Fehler" bringen müssen!? Dies war aber nicht der fall! Daher die Frage.
Nur wenn schon config(8) oder spätestens der Compiler überprüfen würden ob Deine CPU SSE-Befehle unterstützt. Da Du es hier aber mit Softwareprodukten zu tun hast die sich vom Benutzer sagen lassen was sie tun sollen und nicht, wie bei andern Herstellern, dem Benutzer Entscheidungen vorenthalten werden, wird sich niemand vor oder während dem Kompilieren beklagen.
Wie sollte die Entscheidung auch zuverlässig gefällt werden? Könnte ja sein, dass Du Deinen alten Rechner verwendest um seinem großen Bruder einen neuen Kernel zu übersetzen. Also: Es kann nicht schon während des Übersetzens festgestellt werden ob SSE-Befehle von der Ziel-CPU unterstützt werden.
Stattdessen würdest Du wohl eine "Illegal Instruction"-Trap zur Laufzeit erhalten => Panic. Die Tatsache, dass Du offenbar keine solchen Panics gesehen hast spricht für sich. Überleg mal. ;)
Oh, der hat ja gar kein SSE :)
Naja, FreeBSD hängt sich an dieser Option auf (ich denke mal das kompilieren), weil es die Option eben nicht mehr gibt. Ansonsten kommt es auf den CPUTYPE?= in der make.conf an. du kannst auf einem P2 problemlos p3/sse code erzeugen, aber cputype pentiumpro mit enable_sse ging iirc nicht.
Warum es unter 5.4 bisher ging bzw ob es überhaupt eingeschalten war - gute Frage.
muß man das überhaupt angeben, wenn ich den kernel übersetz mit einen duron oder athlon ohne sse und rüste morgen auf auf amd xp??? mit sse wird doch die cpu automatisch durch die hardwareerkennung erkannt und in dem moment auch sse aktiviert oder lieg ich da falsch,
OFFTOPIC:
Kurze Nebenfrage, wo ich gerade die obige dmesg sehe: Was bedeuten eigentlich diese gelegentlich auftauchenden [GIANT-LOCKED]-Meldungen hinter manchen Netzwerk- und Grafikkarten? Hatte diesbezüglich und die Version 5.x betreffend einmal etwas im Hinterkopf, dass bestimmte Treiber für die unterstützte Peripherie noch in der Entwicklung seien. Kann mir mal jemand ganz kurz auf die Sprünge helfen?
@Flex: der Compiler muss die SSE Befehle auch nutzen. Wenn dein binary keine SSE Befehle verwendet is es reichlich egal ob die CPU die kann oder nicht. Daher, wenn du von CPU ohne SSE auf CPU mit SSE umsteigst und dies auch gerne verwenden würdest, musst du neu kompilieren.
@quantumleeks: [GIANT-LOCKED] bedeutet, dass der Treiber noch nicht vom grossen Kernel-Lock das bis FreeBSD 4 normal war auf das neue multithreaded locking aus FreeBSD 5 und später umgestellt wurde. Wohingegen [MPSAFE] bei denen erscheint, bei denen dies bereits abgeschlossen ist.
Bestimmte SSE-Funktionen werden zum Teil auch von den älteren Athlons unterstützt, dazu gehört zum Beispiel das was bei dir als "FXSR" ("Fast floating point save and restore") in der Feature-Liste angezeigt wird. Bei der Verwendung von CPU_ENABLE_SSE werden insbesondere von diesen Funktionen im Kernel Gebrauch gemacht. Alles was darüberhinaus geht, wird außerdem durch zusätzliche if-Abfragen nochmals explizit auf Vorhandensein geprüft, so dass gar nichts schlimmes passieren kann, wenn man eine bestimmte Funktionalität nicht hat und trotzdem einen Kernel mit CPU_ENABLE_SSE benutzt. Übrigens ist CPU_ENABLE_SSE auch schon bei 5.x nicht mehr nötig; das wird automatisch definiert, sobald man "cpu I686_CPU" in der Kernelkonfiguration hat; und somit steckt es auch schon im GENERIC.
Björn
Und der FreeBSD Kernel baut sich btw automatisch, egal was man definiert, mit
-mno-mmx -mno-3dnow -mno-sse -mno-sse2
Eine Begründung dafür findet man zB hier: http://lists.freebsd.org/pipermail/freebsd-amd64/2005-February/003663.html
Wobei mir persönlich ehrlich gesagt nicht einleutet, warum man MMX deaktiviert wenn man sich auf Integer beschränkt. MMX war doch eine reine Integer-Erweiterung. :confused:
[Edit]
Ok, Google hilft. MMX arbeitet mit 64bit Registern die IA32 für Integer nicht bereitstellt, weshalb hierfür die 80bit floating-point Register verwendet werden. Damit is alles geklärt, auch bei MMX müssten die floating register gesichert werden.
