schorsch_76
FreeBSD Fanboy
Hallo Bsd Kollegen,
auf meinem NAS hab ich diese Platte als backup Platte am laufen. Die reinen Smart Werte zeigen keine Probleme aber das UFS wird immer wieder korrupt. Es gibt aber jede Menge DMA Fehler.
Was kann ich hier machen? Mainboard tauschen? Kabel hab ich schon neu rein gepackt....
root@nas-dsm:/mnt # smartctl -a /dev/ada1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-RELEASE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Samsung SpinPoint M8 (AF)
Device Model: ST1000LM024 HN-M101MBB
Serial Number: S2R8J9GCA06016
LU WWN Device Id: 5 0004cf 208b663f2
Firmware Version: 2AR10002
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.0, 3.0 Gb/s (current: 1.5 Gb/s)
Local Time is: Mon Sep 24 21:37:42 2018 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
data collection: (13560) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 226) minutes.
SCT capabilities: (0x003f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 051 Pre-fail Always - 1
2 Throughput_Performance 0x0026 252 252 000 Old_age Always - 0
3 Spin_Up_Time 0x0023 089 089 025 Pre-fail Always - 3469
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1781
5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0
8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 1504
10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 11
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1062
191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 5
192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0
194 Temperature_Celsius 0x0002 062 055 000 Old_age Always - 38 (Min/Max 14/55)
195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0
196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 252 252 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0036 098 098 000 Old_age Always - 1359
200 Multi_Zone_Error_Rate 0x002a 100 100 000 Old_age Always - 796
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 11
225 Load_Cycle_Count 0x0032 097 097 000 Old_age Always - 33429
SMART Error Log Version: 1
ATA Error Count: 28 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 28 occurred at disk power-on lifetime: 1462 hours (60 days + 22 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 31 71 46 4d e0 Error: ICRC, ABRT at LBA = 0x004d4671 = 5064305
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ca 00 40 62 46 4d e0 00 00:19:28.824 WRITE DMA
c6 00 10 00 00 00 e0 00 00:19:28.824 SET MULTIPLE MODE
ef 03 45 00 00 00 e0 00 00:19:28.824 SET FEATURES [Set transfer mode]
ec 00 00 00 00 00 e0 00 00:19:28.824 IDENTIFY DEVICE
Error 27 occurred at disk power-on lifetime: 1462 hours (60 days + 22 hours)
ca 00 40 62 46 4d e0 00 00:19:28.674 WRITE DMA
ca 00 40 22 46 4d e0 00 00:19:28.673 WRITE DMA
Error 26 occurred at disk power-on lifetime: 1462 hours (60 days + 22 hours)
84 51 31 31 46 4d e0 Error: ICRC, ABRT at LBA = 0x004d4631 = 5064241
Error 25 occurred at disk power-on lifetime: 1462 hours (60 days + 22 hours)
ca 00 40 e2 45 4d e0 00 00:19:28.673 WRITE DMA
Error 24 occurred at disk power-on lifetime: 1462 hours (60 days + 22 hours)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 1504 -
# 2 Offline Completed without error 00% 0 -
# 3 Offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Completed [00% left] (0-65535)
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Ich hab jetzt neue Hardware bestellt. Neues MB, neue CPU, neues RAM, neues Netzteil, neues Gehäuse.
