dettus
Bicycle User
Ich habe gerade ein kleines Script gebastelt, welches die Abhaengigkeiten aus den OpenBSD ports extrahiert und als JSON speichert.
Das wuerde ich gerne mit Euch teilen
Python:
#!/usr/bin/env python3 -i
import os
import shutil
import pickle
import json
PORTS_ROOT="/usr/ports/"
ports_makefiles_dir=[]
for (dirpath,dirnames,filenames) in os.walk(PORTS_ROOT):
if filenames.count("Makefile")==1 and dirpath.find("pobj")==-1:
d=dirpath.replace(PORTS_ROOT,"")
ports_makefiles_dir.append(d)
print("Number of ports found: \x1b[1;36m"+str(len(ports_makefiles_dir))+"\x1b[0m")
cnt=0
lib_depends={}
build_depends={}
run_depends={}
for p in ports_makefiles_dir:
cnt=cnt+1
print("Processing \x1b[1;36m"+str(cnt)+"/"+str(len(ports_makefiles_dir))+"\x1b[0m")
lines=os.popen("cd "+PORTS_ROOT+" ; make -p -f "+p+"/Makefile").read().split("\n")
for l in lines:
tmp=l.split("=")
if len(tmp)==2:
key=tmp[0].replace(" ","")
value=tmp[1].split(" ")
if value.count(""):
value.remove("")
if key=="BUILD_DEPENDS":
build_depends[p]=value
if key=="LIB_DEPENDS":
lib_depends[p]=value
if key=="RUN_DEPENDS":
run_depends[p]=value
handle={
"ports_makefiles_dir":ports_makefiles_dir,
"build_depends":build_depends,
"lib_depends":lib_depends,
"run_depends":run_depends
with open("saved_handle.pkl","wb") as f:
pickle.dump(handle,f)
with open("saved_handle.json","w") as f:
json.dump(handle,f)
