FreeBSD: FreeBSD 5.3-RC1 als ISO verfügbar
asg
push it, don´t hype
Wie Scott Long eben auf der mailingliste "freebsd-current@" mitgeteilt hat, sind ISOs für FreeBSD 5.3-RC1 auf den FTP Servern verfügbar.
Für Deutschland empfiehlt sich ftp.de.freebsd.org.
Stand der Dinge zum jetzigen Zeitpunkt:
alpha: will be available shortly
amd64: all images available
i386: all images available
ia64: all images available
pc98: miniinst available
sparc64: all images available
Weiterhin teilt er mit das es folgende Änderungen seit BETA7 gab:
- Added support for nForce2, nForce3, and ICH3 sound chips
- Fixed LOR in the socket code
- VM_KMEM_SIZE_MAX and VM_KMEM_SIZE_SCALE are now tunables
- Fixed security hole in syscons related to invalid coordinates
- Interface renaming events are now logged
- PFIL_HOOKS are no longer an option and exist by default
- Fixed problem with threads sometimes ignoring signals
- Many fixes to gvinum
- Fix timecounting on sparc64 SMP
- Many fixes to the 4BSD scheduler and infrastructure
- Fix pflogd to handle the pflog module being unloaded
- Fix rare locking bug in sendfile
- Fix locking in the nge driver
- Increase NKPT so that amd64 and i386+PAE can boot with more than
8GB of RAM
- Many fixes to thread support
- Fix breakpoint handing on i386 and amd64 for kernel GDB
- Many fixes for the THR thread library
- Fix IP multicast locking when the stack is running under Giant
- Fix locking in the sis, bfe, and ndis drivers
- Fix possible crash in linux ptrace
- Remove the FreeBSD keyword from all rc.d scripts
- Disable MTU feedback on IPv6 packets to fix NFS over IPv6 problems
- Many ATA driver fixes
- Many VM fixes for i386 and amd64
- Fix 2.88MB floppy support
- Fix locking in bpf, pfil, and IPv6 routing
- Fix the isp driver to work with i386+PAE
- Fix locking that sometimes resulted in deadlock in the TCP code
- Fix jumbo frame handling for the re driver
- Fix the msdos filesystem code to not panic on corrupt filesystems.
- Fix compiling the NDIS module into the kernel
- Fix permission handling on multicast sockets for non-root users
- Fix locking for i4b driver
- Fix byteorder problem in the dc driver on big-endian machines
- Many gstipe/gmirror/graid fixes
- Correctly set BIOS packet mode in the i386 bootblocks
- Update the em driver to support the PRO/1000 GT card, plus many bug
fixes including the common 'wedge on heavy transmit' problem.
- Fix locking in the dc driver, add ALTQ support
- Fix stability problems with UMA
- Fix a potential panic in ethernet entropy harvesting
Folgende Probleme gibt es noch:
- Panic in sodealloc() under heavy load. A fix is being tested now.
- Poor performance of the de and re drivers. Fixes are being tested
now.
Eine sehr schöne News...:D Wie sieht das eigentlich mit dem ehci treiber aus? Fliegt der aus der 5er Linie und lebt im 6er-current weiter, denn er war ja noch buggy. (Bei mir jedenfalls)
carb
Hallo Leute
Ich habe die RC1 getestet,in der Hoffnung das da jetzt endlich Unterstützung für den Nvidia-Ethernet Chip (nforce-ethernet) im Kernel integriert ist. Aber nein, scheinbar immernoch nicht. Schade. Aber eine ganz kleine Hoffnung habe ich noch. Ich habe von der bootonly ISO aus angefangen, kann es sein das dort ein angespeckter kernel enthalten ist?? Ich weiß ich weiß :-) irgendwie etwas unwarscheinlich, aber wer weiß ???
--Ich weiß übrigens das der nforce-chip treiber aus den ports auch manuell installiert werden kann werden kann, aber das ist mir etwas zu umständlich. Erst per anderem System die daten holen auf cd brennen usw.usw
Thomas
thomasf said:
Hallo Leute
Thomas
Hi Thomas,
normal ist der GENERIC Kernel drin, schau einfach mal in /usr/src/sys/<Achitektur>/conf/GENERIC was drin is nach ...
Gruß Bummibaer
Thomas
Oh nein, ich wollte eigentlich in Kürze mal FreeBSD ausprobieren, weil mir das FreeBSD - Konzept in Abgrenzung zu den vielen Linuxdistrbutionen mit ihren unterschiedlichen Pakteformaten besser gefällt.
Aber da ich Dual Boot mit Win XP machen möchte und das mit einem Nforce3 - Mainboard wird da solange nix werden, bis FreeBSD den Nforce3 - Ethernet - Chip von der Installations-CD aus unterstützt... ;'(
Mich wundert nur, dass der nforce-Sound ja gemäss der Liste oben unterstützt wird und das Netzwerk laut meinem Vorposter nicht. Kann das denn? Oder liegt das wirklich an der bootonly-CD? :confused:
Nett gemeint, aber wie kriege ich die Datei auf mein FreeBSD-System?
Kann man da mit Windows 'ne ISO-CD brennen, von der FreeBSD die Dateien dann lesen kann?
Und wenn, wie greife ich unter FreeBSD auf ein DVD/CD-ROM-Laufwerk zu? Kenne leider nur die "Komfortversionen" von Gnome auf Fedora Core2 oder Ubuntu. Da wird das Laufwerk ja automatisch eingebunden.
Ich hoffe, diese Noob-Frage ist hier gestattet... Bitte kein RTFM, das mache ich ganz in Ruhe, wenn das Grundsystem mal steht.
