FTP Zwischen zwei Netzwerke mit PF dazwischen
PaulAtreides
Ich habe zwei Netzwerke.
$printer_if: Drucker und Scanner
$int_if: Clients und Server
Wie konfiguriere ich PF so, dass ein Scanner im Netzwerk $printer_if Daten an einen FTP-Server im Netzwerk $int_if senden kann?
ext_if = "pppoe0"
int_if = "ix0"
printer_if = "vlan21"
local_net = "{10.0.30.0/24, 10.0.20.0/24, 10.0.50.0/24, 10.0.70.0/24}"
server_net = "{10.0.20.0/24}"
printer_net = "{10.0.21.0/24}"
anchor "ftp-proxy/*"
# DEFAULT OPTIONS
set block-policy drop
set loginterface $ext_if
set skip on lo0
# NAT
match in all scrub (no-df max-mss 1440)
match out on $ext_if inet from $local_net nat-to ($ext_if)
match out on $ext_if inet from $printer_net nat-to ($ext_if)
# ANTISPOOOF
antispoof for $int_if
# DEFAULT BLOCK
block log all
pass from (self)
# ICMP
icmp_types = "{ echoreq, unreach }"
pass log inet proto icmp icmp-type $icmp_types
# PRINTER NETWORK
block in log on $printer_if from $printer_net to any
pass in on $printer_if proto { tcp, udp } from $printer_net to 10.0.21.1 port { domain, ntp }
pass in quick on $printer_if inet proto tcp to port 21 divert-to 127.0.0.1 port 8021
pass out inet proto tcp from (self) to any port ftp
pass in on $printer_if proto tcp from $printer_net to any port { http, https, smtp }
pass proto tcp from { $local_net } to $printer_net port { ipp, 9100, http, https }
pass proto tcp from $printer_net to { $local_net }
pass proto udp from $printer_net to { $local_net }
# ALLOWED NETWORK SERVICES LAN
tcp_services = "{ ftp-data, ftp, ssh, smtp, smtps, domain, pop3, auth, http, https, pop3s, imap, imaps, 6667, 3000, 8883}"
udp_services = "{ domain, ntp, openvpn}"
# pass proto tcp from $local_net to port $tcp_services
pass in on $int_if proto tcp from $local_net to port $tcp_services
pass out on $int_if proto tcp from $local_net to port $tcp_services
pass quick proto { tcp, udp } from $local_net to port $udp_services
# FTP Proxy
pass in quick inet proto tcp from $local_net to port ftp divert-to 127.0.0.1 port 8021
# LOCALHOST SERVER
local_tcp_server = "{ ssh, 3128 }"
local_udp_server = "{ domain, ntp }"
pass in on $int_if proto tcp from $local_net to port $local_tcp_server
pass in on $int_if proto udp from $local_net to port $local_udp_server
# By default, do not permit remote connections to X11
block return in on ! lo0 proto tcp to port 6000:6010
# Port build user does not need network
block return out log proto {tcp udp} user _pbuild
der ftp-proxy und die anleitungen gehen meistens davon aus das man hinter einem nat sitzt und ftp-verbindungen in die Außenwelt für Downloads machen möchte.
Das ist da ja nicht der Fall da du kein NAT zwischen dne netzen machst.
Ich kann das gerade nicht gut durchdenken da ich im Urlaub bin, aber als alternatividee: Kann das ding evtl. noch was anderes was firewalltechnisch einfacher ist als ftp? Viele der letzten 20 Jahre können auch scan to smb oder to smtp oder so.
Du machst hier ja noch etwas mehr, und leitest den Verkehr auf einen anderen Port wie ich sehe? Prinzipiell musst du für das einfachste Setup (active ftp) nur 21 von printer auf intern erlauben, und Port 20 von intern auf printer. Standardports und Activemode vorausgesetzt.
Oder besser natürlich, was Commander sagt, du nimmst ein vernüftiges Protokoll :)
Der Scanner konnte den DNS für den FTP Server nicht auflösen, weil im DHCP Server eine Adresse drin steht die $print_if nicht erreichen kann
Fehler über tcpdump -ni vlan21 host 10.0.21.13 gefunden
Lösung:
pass in on $printer_if proto { tcp, udp } from $printer_net to any port domain rdr-to 127.0.0.1 port 53
hi
ein ftp-proxy wird benötigt bezüglich aktiv / passiv ftp , das hat mit nat nix zu tun,
der ftp-proxy benötigt einen anchor in den pf regeln ( siehe man ftp-proxy ).
Holger
hi
Holger
Außer man macht gar (kaum) keine Filterregeln zwischen den netzen ;)
Die Anchor-Regel hat er doch drinn?
Aber es funktioniert ja, also alles gut
