bsd-yusa
semi-pro geek
hab' schon fleissig gegoogelt, aber nichts gefunden...
ideen/vorschläge?
edit: okay, der build läuft jetzt weiter, allerdings ohne muine.
# cd /usr/ports/sysutils/serpentine && make config
weg mit muine -> passt
# make install clean
===> Installing for gnome2-power-tools-2.24.2_2
===> gnome2-power-tools-2.24.2_2 depends on file: /usr/local/lib/epiphany/2.24/extensions/libgesturesextension.so - found
===> gnome2-power-tools-2.24.2_2 depends on executable: gnome-pkgview - found
===> gnome2-power-tools-2.24.2_2 depends on file: /usr/local/libexec/netspeed_applet2 - found
===> gnome2-power-tools-2.24.2_2 depends on file: /usr/local/sbin/gkrellmd - found
===> gnome2-power-tools-2.24.2_2 depends on executable: splashsetter - found
===> gnome2-power-tools-2.24.2_2 depends on executable: gdesklets - found
===> gnome2-power-tools-2.24.2_2 depends on executable: cog - found
===> gnome2-power-tools-2.24.2_2 depends on executable: gnome-blog-poster - found
===> gnome2-power-tools-2.24.2_2 depends on executable: gnomesu - found
===> gnome2-power-tools-2.24.2_2 depends on executable: bpm - found
===> gnome2-power-tools-2.24.2_2 depends on executable: gnome-file-share-properties - found
===> gnome2-power-tools-2.24.2_2 depends on executable: serpentine - not found
===> Verifying install for serpentine in /usr/ports/sysutils/serpentine
===> serpentine-0.7_4 depends on executable: xmlproc_parse - found
===> serpentine-0.7_4 depends on file: /usr/local/bin/python2.5 - found
===> serpentine-0.7_4 depends on executable: muine - not found
===> Verifying install for muine in /usr/ports/audio/muine
===> Building for muine-0.8.8_2
gmake all-recursive
gmake[1]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8'
Making all in data
gmake[2]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/data'
Making all in glade
gmake[3]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/data/glade'
gmake[3]: Nothing to be done for `all'.
gmake[3]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/data/glade'
Making all in images
gmake[3]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/data/images'
gmake[3]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/data/images'
Making all in ui
gmake[3]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/data/ui'
gmake[3]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/data/ui'
gmake[3]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/data'
gmake[3]: Nothing to be done for `all-am'.
gmake[3]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/data'
gmake[2]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/data'
Making all in libmuine
gmake[2]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/libmuine'
Making all in id3-vfs
gmake[3]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/libmuine/id3-vfs'
gmake[3]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/libmuine/id3-vfs'
gmake[3]: Entering directory `/usr/ports/audio/muine/work/muine-0.8.8/libmuine'
/bin/sh ../libtool --tag=CC --mode=compile cc -DHAVE_CONFIG_H -I. -I.. -I.. -DG_LOG_DOMAIN=\"libmuine\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DORBIT2=1 -D_REENTRANT -D_THREAD_SAFE -I/usr/local/include/gconf/2 -I/usr/local/include/orbit-2.0 -I/usr/local/include/dbus-1.0 -I/usr/local/include/dbus-1.0/include -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I/usr/local/include/gtk-2.0 -I/usr/local/include/gnome-vfs-2.0 -I/usr/local/lib/gnome-vfs-2.0/include -I/usr/local/lib/gtk-2.0/include -I/usr/local/include/atk-1.0 -I/usr/local/include/cairo -I/usr/local/include/pango-1.0 -I/usr/local/include -I/usr/local/include/pixman-1 -I/usr/local/include/freetype2 -I/usr/local/include/gstreamer-0.10 -I/usr/local/include/libxml2 -Wall -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wno-sign-compare -DG_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGNOME_DISABLE_DEPRECATED -I/usr/local/include -O2 -fno-strict-aliasing -pipe -MT pointer-list-model.lo -MD -MP -MF .deps/pointer-list-model.Tpo -c -o pointer-list-model.lo pointer-list-model.c
cc -DHAVE_CONFIG_H -I. -I.. -I.. -DG_LOG_DOMAIN=\"libmuine\" -DGNOMELOCALEDIR=\"/usr/local/share/locale\" -DORBIT2=1 -D_REENTRANT -D_THREAD_SAFE -I/usr/local/include/gconf/2 -I/usr/local/include/orbit-2.0 -I/usr/local/include/dbus-1.0 -I/usr/local/include/dbus-1.0/include -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I/usr/local/include/gtk-2.0 -I/usr/local/include/gnome-vfs-2.0 -I/usr/local/lib/gnome-vfs-2.0/include -I/usr/local/lib/gtk-2.0/include -I/usr/local/include/atk-1.0 -I/usr/local/include/cairo -I/usr/local/include/pango-1.0 -I/usr/local/include -I/usr/local/include/pixman-1 -I/usr/local/include/freetype2 -I/usr/local/include/gstreamer-0.10 -I/usr/local/include/libxml2 -Wall -Wmissing-prototypes -Wnested-externs -Wpointer-arith -Wno-sign-compare -DG_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGNOME_DISABLE_DEPRECATED -I/usr/local/include -O2 -fno-strict-aliasing -pipe -MT pointer-list-model.lo -MD -MP -MF .deps/pointer-list-model.Tpo -c pointer-list-model.c -fPIC -DPIC -o .libs/pointer-list-model.o
pointer-list-model.c: In function 'pointer_list_model_row_draggable':
pointer-list-model.c:220: warning: implicit declaration of function 'GTK_CHECK_TYPE'
pointer-list-model.c:220: warning: nested extern declaration of 'GTK_CHECK_TYPE'
pointer-list-model.c: In function 'pointer_list_model_row_drop_possible':
pointer-list-model.c:276: warning: implicit declaration of function 'GTK_CHECK_CAST'
pointer-list-model.c:276: warning: nested extern declaration of 'GTK_CHECK_CAST'
pointer-list-model.c:276: error: expected expression before 'PointerListModel'
pointer-list-model.c:276: warning: assignment makes pointer from integer without a cast
gmake[3]: *** [pointer-list-model.lo] Error 1
gmake[3]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/libmuine'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8/libmuine'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/usr/ports/audio/muine/work/muine-0.8.8'
gmake: *** [all] Error 2
*** Error code 2
Stop in /usr/ports/audio/muine.
*** Error code 1
Stop in /usr/ports/sysutils/serpentine.
*** Error code 1
*** Error code 1
Stop in /usr/ports/x11/gnome2-power-tools.
ideen/vorschläge?
