JeffJohnson
ich hab mit mpd andauernd Probleme beim verbinden.
Es sieht so aus als wäre das genau dieses Problem:
http://www.freebsd.org/cgi/query-pr.cgi?pr=62477
Der bug wurde aber scho 2004 gefixt und ich benutze FreeBSD 7.2-RELEASE-p1
Dat sollte doch inzwischen scho längst gefixt worden sein
/usr/local/etc/mpd/mpd.conf:
/usr/local/etc/mpd/mpd.links
Könnte das 'n Problem an meiner Config sein?
Sollte ich einfach mal 'n Bugreport erstellen? :O
Jun 14 13:17:08 whiteshark mpd: mpd: pid 4083, version 3.18 (root@xyz 18:52 4-Jun-2009)
Jun 14 13:17:08 whiteshark mpd: [pppoe] ppp node is "mpd4083-pppoe"
Jun 14 13:17:08 whiteshark mpd: [pppoe] using interface ng0
Jun 14 13:17:08 whiteshark mpd: [pppoe] IFACE: Open event
Jun 14 13:17:08 whiteshark mpd: [pppoe] IPCP: Open event
Jun 14 13:17:08 whiteshark mpd: [pppoe] IPCP: state change Initial --> Starting
Jun 14 13:17:08 whiteshark mpd: [pppoe] IPCP: LayerStart
Jun 14 13:17:08 whiteshark mpd: [pppoe] bundle: OPEN event in state CLOSED
Jun 14 13:17:08 whiteshark mpd: [pppoe] opening link "pppoe"...
Jun 14 13:17:08 whiteshark mpd: [pppoe] link: OPEN event
Jun 14 13:17:08 whiteshark mpd: [pppoe] LCP: Open event
Jun 14 13:17:08 whiteshark mpd: [pppoe] LCP: state change Initial --> Starting
Jun 14 13:17:08 whiteshark mpd: [pppoe] LCP: LayerStart
Jun 14 13:17:08 whiteshark mpd: [pppoe] device: OPEN event in state DOWN
Jun 14 13:17:08 whiteshark mpd: [pppoe] can't connect bypass,link0 and rl0:orphans,mpd4083-pppoe: No such file or directory
Jun 14 13:17:08 whiteshark mpd: [pppoe] can't remove hook mpd4083-pppoe from node "rl0:orphans": No such file or directory
Jun 14 13:17:08 whiteshark mpd: [pppoe] device is now in state OPENING
Jun 14 13:17:08 whiteshark mpd: [pppoe] device: DOWN event in state OPENING
Jun 14 13:17:08 whiteshark mpd: [pppoe] device is now in state DOWN
Jun 14 13:17:08 whiteshark mpd: [pppoe] link: DOWN event
Jun 14 13:17:08 whiteshark mpd: [pppoe] LCP: Down event
Jun 14 13:17:08 whiteshark mpd: [pppoe] pausing 4 seconds before open
Jun 14 13:17:12 whiteshark mpd: [pppoe] device: OPEN event in state DOWN
Jun 14 13:17:12 whiteshark mpd: [pppoe] pausing 1 seconds before open
default:
load PPPoE
PPPoE:
new -i ng0 PPPoE PPPoE
set iface route default
set iface disable on-demand
#set iface addrs 1.1.1.1 2.2.2.2
set iface idle 0
set bundle disable multilink
set bundle authname "123
set iface disable tcpmssfix
set link no acfcomp protocomp
set link disable pap chap
set link accept chap
#set link mtu 1492
#set link mru 1492
set link keep-alive 10 60
set ipcp yes vjcomp
set ipcp ranges 0.0.0.0/0 0.0.0.0/0
log +link
open iface
PPPoE:
set link type pppoe
set pppoe iface rl0
set pppoe disable incoming
set pppoe enable originate
