Hallo Leute
Hier mal meine dmesg:
OpenBSD 3.4-beta (LAPTOP) #1: Sat Aug 16 20:36:16 CEST 2003
zensiert ... zensiert ... zensiert : /usr/src/sys/arch/i386/conf/LAPTOP
cpu0: Intel Pentium III (Coppermine) ("GenuineIntel" 686-class) 598 MHz
cpu0: FPU,V86,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SIMD
real mem = 267952128 (261672K)
avail mem = 244920320 (239180K)
using 3296 buffers containing 13500416 bytes (13184K) of memory
mainbus0 (root)
bios0 at mainbus0: AT/286+(31) BIOS, date 05/15/00, BIOS32 rev. 0 @ 0xfd890
apm0 at bios0: Power Management spec V1.2
apm0: battery life expectancy 92%
apm0: AC on, battery charge high
pcibios0 at bios0: rev. 2.1 @ 0xfd890/0x770
pcibios0: PCI IRQ Routing Table rev. 1.0 @ 0xfdf50/144 (7 entries)
pcibios0: PCI Interrupt Router at 000:07:0 ("Intel 82371FB PCI-ISA" rev 0x00)
pcibios0: PCI bus #3 is the last bus
bios0: ROM list: 0xc0000/0xf800
pci0 at mainbus0 bus 0: configuration mode 1 (no bios)
pchb0 at pci0 dev 0 function 0 "Intel 82443BX PCI-AGP" rev 0x03
ppb0 at pci0 dev 1 function 0 "Intel 82443BX AGP" rev 0x03
pci1 at ppb0 bus 1
vga1 at pci1 dev 0 function 0 "ATI Mobility 1" rev 0x64
wsdisplay0 at vga1: console (80x25, vt100 emulation)
wsdisplay0: screen 1-7 added (80x25, vt100 emulation)
pcib0 at pci0 dev 7 function 0 "Intel 82371AB PIIX4 ISA" rev 0x02
pciide0 at pci0 dev 7 function 1 "Intel 82371AB IDE" rev 0x01: DMA, channel 0 wired to compatibility, channel 1 wired to compatibility
wd0 at pciide0 channel 0 drive 0: <TOSHIBA MK2016GAP>
wd0: 16-sector PIO, LBA, 19077MB, 16383 cyl, 16 head, 63 sec, 39070080 sectors
wd0(pciide0:0:0): using PIO mode 4, Ultra-DMA mode 2
atapiscsi0 at pciide0 channel 1 drive 0
scsibus0 at atapiscsi0: 2 targets
cd0 at scsibus0 targ 0 lun 0: <MATSHITA, DVD-ROM SR-8175, GF22> SCSI0 5/cdrom removable
cd0(pciide0:1:0): using PIO mode 4, Ultra-DMA mode 2
uhci0 at pci0 dev 7 function 2 "Intel 82371AB USB" rev 0x01: irq 9
usb0 at uhci0: USB revision 1.0
uhub0 at usb0
"Intel 82371AB Power Mgmt" rev 0x03 at pci0 dev 7 function 3 not configured
maestro0 at pci0 dev 13 function 0 "ESS Maestro 2E" rev 0x10: irq 9
maestro0: maestro_read_codec() RW_DONE timed out.
maestro0: resetting codec
ac97: codec id 0x83847609 (SigmaTel STAC9721/23)
ac97: codec features 18 bit DAC, 18 bit ADC, SigmaTel 3D
audio0 at maestro0
cbb0 at pci0 dev 15 function 0 "Ricoh 5C476 PCI-CardBus" rev 0x80: irq 9
cbb1 at pci0 dev 15 function 1 "Ricoh 5C476 PCI-CardBus" rev 0x80: irq 9
isa0 at pcib0
isadma0 at isa0
pckbc0 at isa0 port 0x60/5
pckbd0 at pckbc0 (kbd slot)
wskbd0 at pckbd0: console keyboard, using wsdisplay0
pms0 at pckbc0 (aux slot)
pckbc0: using irq 12 for aux slot
wsmouse0 at pms0 mux 0
lpt0 at isa0 port 0x378/4 irq 7
npx0 at isa0 port 0xf0/16: using exception 16
pccom0 at isa0 port 0x3f8/8 irq 4: ns16550a, 16 byte fifo
fdc0 at isa0 port 0x3f0/6 irq 6 drq 2
cardslot0 at cbb0 slot 0 flags 0
cardbus0 at cardslot0: bus 2 device 0 cacheline 0x0, lattimer 0x20
pcmcia0 at cardslot0
cardslot1 at cbb1 slot 1 flags 0
cardbus1 at cardslot1: bus 3 device 0 cacheline 0x0, lattimer 0x20
pcmcia1 at cardslot1
biomask c240 netmask c240 ttymask d2c2
pctr: 686-class user-level performance counters enabled
mtrr: Pentium Pro MTRR support
dkcsum: wd0 matched BIOS disk 80
root on wd0a
rootdev=0x0 rrootdev=0x300 rawdev=0x302
xl0 at cardbus0 dev 0 function 0: 3Com 3c575C-TX Ethernet: irq 9 address zensiert ... zensiert ... zensiert
ukphy0 at xl0 phy 0: Generic IEEE 802.3u media interface
ukphy0: OUI 0x00c000, model 0x0000, rev. 0
CW
