OpenBSD-Projekt: Call for Testers
CW
Netswimmer
Bald ist es soweit und die neue OpenBSD-Version (3.4) wird zu haben sein. Und natürlich möchte das Projekt alles richtig machen, und bittet um Mithilfe.
Hier der Auszug von der http://www.deadly.org:
We're heading towards the final 3.4 release cut, but we need to test stuff. One of the ways you can help is to download the new snapshots and test them out. From Wim Vandeputte, expressing requests from Theo, Pval and others:
At the request of the OpenBSD developers, you are invited to test the latest snapshots on the ftp server to verify a last minute fix in the boot blocks (version 2.02). Please mail your report to: henning@openbsd.org when you test: something like
i386:Serverworks SLC,P42.4:CD34.iso+FTP install(VERSION 2.02 boot block):WORKS:X GOOD (ATI RADEON 7500)
Be sure to say arch, something about what it is, what install method you used, and be sure to indicate whether or not you had the VERSION 2.02 boot block. Test X if you can and say if you did.
Also start testing packages (as opposed to ports), since those also go on the CD. Thanks
CW
