TYPOlight 2.7.2 system check
PHP configuration
Parameter • Value Description
Safe mode Off Recommended setting is Off.
Maximum execution time 30 Recommended setting is 30 or greater.
Memory limit 128M Recommended setting is 16M or greater.
Register globals Off Recommended setting is Off.
File uploads On Recommended setting is On.
Upload maximum filesize 8M Recommended setting is 8M or greater.
SOAP extension • On Recommended setting is On. HIER MELDET DAS TOOL EIN PROBLEM, LEIDER OHNE GENAUERE AUSSAGE
If there are any warnings, TYPOlight might not work properly. If PHP safe_mode is enabled (first line), you have to use the "Safe Mode Hack" to run TYPOlight. Otherwise, you will not be able to create or modify files or use the live update feature.
You will most likely not be able to use the TYPOlight extension repository.
File permissions
Operating system FreeBSD FreeBSD VMFREEBSD72 7.2-RELEASE FreeBSD 7.2-RELEASE #0: Fri May 1 08:49:13 UTC 2009
root@walker.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC i386
Create directory • Error Error creating directory "typolight-check"
Directory permissions • 0 Recommended directory permission setting is 775 or 755 or 750.
Directory owner root The new directory is owned by you.
Create file • Error Error creating file "typolight-check.txt"
File permissions • 0 Recommended file permission setting is 664 or 644 or 640.
File owner root The new file is owned by you.
If there are any warnings, you have to use the "Safe Mode Hack" to run TYPOlight. Otherwise, you will not be able to create or modify files and you will not be able to use the live update feature. Making files and folders writeable is not recommended!
You will most likely not be able to run TYPOlight without Safe Mode Hack.
Files
Click here to show all files.
File • CHMOD Recommended • Owner Recommended Status
CHANGELOG.txt 644 664, 644, 640 root root File
INSTALL.txt 644 664, 644, 640 root root File
LICENSE.txt 644 664, 644, 640 root root File
cron.php 644 664, 644, 640 root root File
flash.php 644 664, 644, 640 root root File
index.php 644 664, 644, 640 root root File
plugins 755 775, 755, 750 root root Folder
plugins/calendar 755 775, 755, 750 root root Folder
plugins/calendar/calendar-icon.gif 644 664, 644, 640 root root File
plugins/calendar/calendar-next.gif 644 664, 644, 640 root root File
plugins/calendar/calendar-prev.gif 644 664, 644, 640 root root File
plugins/calendar/calendar-td.gif 644 664, 644, 640 root root File
plugins/calendar/calendar-valid.gif 644 664, 644, 640 root root File
plugins/calendar/calendar.css 644 664, 644, 640 root root File
plugins/calendar/calendar.js 644 664, 644, 640 root root File
plugins/calendar/calendar.png 644 664, 644, 640 root root File
plugins/calendar/calendar_src.css 644 664, 644, 640 root root File
plugins/calendar/calendar_src.js 644 664, 644, 640 root root File
plugins/highlighter 755 775, 755, 750 root root Folder
plugins/highlighter/scripts 755 775, 755, 750 root root Folder
plugins/highlighter/scripts/clipboard.swf 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushBash.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushCSharp.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushCpp.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushCss.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushDelphi.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushDiff.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushGroovy.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushJScript.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushJava.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushPerl.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushPhp.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushPlain.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushPython.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushRuby.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushScala.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushSql.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushVb.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shBrushXml.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shCore.js 644 664, 644, 640 root root File
plugins/highlighter/scripts/shCore.js.gz 644 664, 644, 640 root root File
plugins/highlighter/scripts/shInit.js 644 664, 644, 640 root root File
plugins/highlighter/src 755 775, 755, 750 root root Folder
plugins/highlighter/src/shCore.css 644 664, 644, 640 root root File
plugins/highlighter/src/shCore.js 644 664, 644, 640 root root File
plugins/highlighter/src/shThemeTYPOlight.css 644 664, 644, 640 root root File
plugins/highlighter/styles 755 775, 755, 750 root root Folder
plugins/highlighter/styles/help.png 644 664, 644, 640 root root File
plugins/highlighter/styles/magnifier.png 644 664, 644, 640 root root File
plugins/highlighter/styles/page_white_code.png 644 664, 644, 640 root root File
plugins/highlighter/styles/page_white_copy.png 644 664, 644, 640 root root File
plugins/highlighter/styles/printer.png 644 664, 644, 640 root root File
plugins/highlighter/styles/shCore.css 644 664, 644, 640 root root File
plugins/highlighter/styles/shThemeDefault.css 644 664, 644, 640 root root File
plugins/highlighter/styles/shThemeTYPOlight.css 644 664, 644, 640 root root File
plugins/highlighter/styles/wrapping.png 644 664, 644, 640 root root File
plugins/mootools 755 775, 755, 750 root root Folder
plugins/mootools/images 755 775, 755, 750 root root Folder
plugins/mootools/images/blank.gif 644 664, 644, 640 root root File
plugins/mootools/images/moor_arrows.gif 644 664, 644, 640 root root File
plugins/mootools/images/moor_boverlay.png 644 664, 644, 640 root root File
plugins/mootools/images/moor_cursor.gif 644 664, 644, 640 root root File
plugins/mootools/images/moor_slider.png 644 664, 644, 640 root root File
plugins/mootools/images/moor_woverlay.png 644 664, 644, 640 root root File
plugins/mootools/mootools.js 644 664, 644, 640 root root File
plugins/mootools/mootools.js.gz 644 664, 644, 640 root root File
plugins/mootools/mootools_src.js 644 664, 644, 640 root root File
plugins/mootools/rainbow.css 644 664, 644, 640 root root File
plugins/mootools/rainbow.js 644 664, 644, 640 root root File
plugins/mootools/rainbow_src.css 644 664, 644, 640 root root File
plugins/mootools/rainbow_src.js 644 664, 644, 640 root root File
plugins/phpmailer 755 775, 755, 750 root root Folder
plugins/phpmailer/class.phpmailer.php 644 664, 644, 640 root root File
plugins/phpmailer/class.smtp.php 644 664, 644, 640 root root File
plugins/phpmailer/language 755 775, 755, 750 root root Folder
plugins/phpmailer/language/phpmailer.lang-en.php 644 664, 644, 640 root root File
plugins/simplepie 755 775, 755, 750 root root Folder
plugins/simplepie/idna_convert.class.php 644 664, 644, 640 root root File
plugins/simplepie/npdata.ser 644 664, 644, 640 root root File
plugins/simplepie/simplepie.inc 644 664, 644, 640 root root File
plugins/slimbox 755 775, 755, 750 root root Folder
plugins/slimbox/css 755 775, 755, 750 root root Folder
plugins/slimbox/css/closelabel.gif 644 664, 644, 640 root root File
plugins/slimbox/css/loading.gif 644 664, 644, 640 root root File
plugins/slimbox/css/nextlabel.gif 644 664, 644, 640 root root File
plugins/slimbox/css/prevlabel.gif 644 664, 644, 640 root root File
plugins/slimbox/css/slimbox.css 644 664, 644, 640 root root File
plugins/slimbox/css/slimbox_src.css 644 664, 644, 640 root root File
plugins/slimbox/js 755 775, 755, 750 root root Folder
plugins/slimbox/js/slimbox.js 644 664, 644, 640 root root File
plugins/slimbox/js/slimbox_src.js 644 664, 644, 640 root root File
plugins/swfobject 755 775, 755, 750 root root Folder
plugins/swfobject/swfobject.js 644 664, 644, 640 root root File
plugins/swfobject/swfobject.js.gz 644 664, 644, 640 root root File
plugins/swfobject/swfobject_src.js 644 664, 644, 640 root root File
plugins/tablesort 755 775, 755, 750 root root Folder
plugins/tablesort/css 755 775, 755, 750 root root Folder
plugins/tablesort/css/tablesort.css 644 664, 644, 640 root root File
plugins/tablesort/css/tablesort_src.css 644 664, 644, 640 root root File
plugins/tablesort/js 755 775, 755, 750 root root Folder
plugins/tablesort/js/tablesort.js 644 664, 644, 640 root root File
plugins/tablesort/js/tablesort_src.js 644 664, 644, 640 root root File
plugins/tablesort/media 755 775, 755, 750 root root Folder
plugins/tablesort/media/asc.gif 644 664, 644, 640 root root File
plugins/tablesort/media/default.gif 644 664, 644, 640 root root File
plugins/tablesort/media/desc.gif 644 664, 644, 640 root root File
plugins/tcpdf 755 775, 755, 750 root root Folder
plugins/tcpdf/cache 755 775, 755, 750 root root Folder
plugins/tcpdf/cache/.htaccess 644 664, 644, 640 root root File
plugins/tcpdf/config 755 775, 755, 750 root root Folder
plugins/tcpdf/config/lang 755 775, 755, 750 root root Folder
plugins/tcpdf/config/lang/eng.php 644 664, 644, 640 root root File
plugins/tcpdf/config/tcpdf_config.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts 755 775, 755, 750 root root Folder
plugins/tcpdf/fonts/courier.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserif.ctg.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserif.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserif.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifb.ctg.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifb.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifb.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifbi.ctg.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifbi.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifbi.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifi.ctg.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifi.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/freeserifi.z 644 664, 644, 640 root root File
plugins/tcpdf/fonts/helvetica.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/helveticab.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/helveticabi.php 644 664, 644, 640 root root File
plugins/tcpdf/fonts/helveticai.php 644 664, 644, 640 root root File
plugins/tcpdf/htmlcolors.php 644 664, 644, 640 root root File
plugins/tcpdf/images 755 775, 755, 750 root root Folder
plugins/tcpdf/images/_blank.png 644 664, 644, 640 root root File
plugins/tcpdf/tcpdf.php 644 664, 644, 640 root root File
plugins/tcpdf/unicode_data.php 644 664, 644, 640 root root File
plugins/tinyMCE 755 775, 755, 750 root root Folder
plugins/tinyMCE/blank.htm 644 664, 644, 640 root root File
plugins/tinyMCE/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/langs/ar.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/bg.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/br.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/bs.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/ca.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/cs.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/da.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/de.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/el.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/en.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/es.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/fa.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/fr.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/he.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/hr.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/hu.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/is.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/it.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/ja.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/lt.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/lv.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/nl.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/nn.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/pl.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/pt.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/ro.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/ru.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/sk.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/sl.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/sq.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/sr.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/sv.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/tr.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/uk.js 644 664, 644, 640 root root File
plugins/tinyMCE/langs/zh.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/advimage 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/advimage/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/advimage/css/advimage.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/image.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/advimage/img/sample.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/advimage/js/image.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/advimage/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/advimage/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/autosave 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/autosave/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/autosave/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/contextmenu 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/contextmenu/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/contextmenu/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/directionality 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/directionality/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/directionality/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/emotions/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/emotions.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/emotions/img/smiley-cool.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-cry.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-embarassed.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-foot-in-mouth.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-frown.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-innocent.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-kiss.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-laughing.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-money-mouth.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-sealed.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-smile.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-surprised.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-tongue-out.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-undecided.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-wink.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/img/smiley-yell.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/emotions/js/emotions.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/emotions/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/emotions/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/inlinepopups/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/alert.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/button.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/buttons.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/confirm.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/corners.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/horizontal.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/img/vertical.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/skins/clearlooks2/window.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/inlinepopups/template.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/paste/blank.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/paste/css/blank.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/css/pasteword.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/paste/js/pastetext.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/js/pasteword.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/paste/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/pastetext.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/paste/pasteword.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/safari 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/safari/blank.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/safari/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/safari/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/save 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/save/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/save/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/searchreplace/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/searchreplace/css/searchreplace.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/searchreplace/js/searchreplace.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/searchreplace/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/searchreplace/searchreplace.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/spellchecker/classes 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/spellchecker/classes/EnchantSpell.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/classes/GoogleSpell.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/classes/PSpell.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/classes/PSpellShell.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/classes/SpellChecker.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/classes/utils 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/spellchecker/classes/utils/JSON.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/classes/utils/Logger.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/config.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/spellchecker/css/content.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/spellchecker/img/wline.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/includes 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/spellchecker/includes/general.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/spellchecker/rpc.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/style/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/style/css/props.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/style/js/props.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/style/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/style/props.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/table/cell.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/table/css/cell.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/css/row.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/css/table.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/table/js/cell.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/js/merge_cells.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/js/row.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/js/table.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/table/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/merge_cells.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/row.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/table/table.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/template/blank.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/template/css/template.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/template/js/template.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/template/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/template/template.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/typolinks/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/typolinks/img/image.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/img/link.gif 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/typolinks/js/typobox.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/js/typobox_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/js/typolinks.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/js/typolinks_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/typolinks/langs/da.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/de.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/en.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/fr.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/it.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/ja.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/lv.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/nl.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/pl.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/typobox.html 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/typoimages.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/typolib.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/typolinks.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/typolinks/typotemplates.php 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/xhtmlxtras/abbr.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/acronym.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/attributes.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/cite.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/css 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/xhtmlxtras/css/attributes.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/css/popup.css 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/del.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/editor_plugin.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/editor_plugin_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/ins.htm 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/xhtmlxtras/js/abbr.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js/acronym.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js/attributes.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js/cite.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js/del.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js/element_common.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/js/ins.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/plugins/xhtmlxtras/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/plugins/xhtmlxtras/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/about.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/anchor.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/charmap.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/color_picker.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/editor_template.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/editor_template_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/image.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/img/colorpicker.jpg 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/img/icons.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/js/about.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js/anchor.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js/charmap.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js/color_picker.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js/image.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js/link.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/js/source_editor.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/langs/ar.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ar_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/bg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/bg_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/br.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/br_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/bs.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/bs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ca.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ca_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/cs.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/cs_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/da.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/da_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/de.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/de_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/el.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/el_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/en.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/en_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/es.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/es_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/fa.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/fa_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/fr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/fr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/he.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/he_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/hr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/hr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/hu.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/hu_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/is.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/is_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/it.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/it_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ja.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ja_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/lt.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/lt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/lv.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/lv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/nl.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/nl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/nn.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/nn_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/pl.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/pl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/pt.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/pt_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ro.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ro_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ru.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/ru_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sk.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sl.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sl_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sq.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sq_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sv.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/sv_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/tr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/tr_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/uk.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/uk_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/zh.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/langs/zh_dlg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/link.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/skins/default 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/skins/default/content.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/dialog.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/skins/default/img/buttons.png 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/img/items.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/img/menu_arrow.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/img/menu_check.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/img/progress.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/img/tabs.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/default/ui.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/skins/o2k7/content.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/dialog.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/advanced/skins/o2k7/img/button_bg.png 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/img/button_bg_black.png 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/img/button_bg_silver.png 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/ui.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/ui_black.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/skins/o2k7/ui_silver.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/advanced/source_editor.htm 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/editor_template.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/editor_template_src.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/img/icons.gif 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/langs/ar.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/bg.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/br.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/bs.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/ca.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/cs.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/da.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/de.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/el.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/en.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/es.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/fa.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/fr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/he.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/hr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/hu.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/is.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/it.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/ja.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/lt.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/lv.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/nl.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/nn.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/pl.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/pt.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/ro.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/ru.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/sk.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/sl.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/sq.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/sr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/sv.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/tr.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/uk.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/langs/zh.js 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/skins 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/skins/default 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/skins/default/content.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/skins/default/ui.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/skins/o2k7 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/skins/o2k7/content.css 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/skins/o2k7/img 755 775, 755, 750 root root Folder
plugins/tinyMCE/themes/simple/skins/o2k7/img/button_bg.png 644 664, 644, 640 root root File
plugins/tinyMCE/themes/simple/skins/o2k7/ui.css 644 664, 644, 640 root root File
plugins/tinyMCE/tiny_mce.js 644 664, 644, 640 root root File
plugins/tinyMCE/tiny_mce_gzip.js 644 664, 644, 640 root root File
plugins/tinyMCE/tiny_mce_gzip.php 644 664, 644, 640 root root File
plugins/tinyMCE/tiny_mce_popup.js 644 664, 644, 640 root root File
plugins/tinyMCE/utils 755 775, 755, 750 root root Folder
plugins/tinyMCE/utils/editable_selects.js 644 664, 644, 640 root root File
plugins/tinyMCE/utils/form_utils.js 644 664, 644, 640 root root File
plugins/tinyMCE/utils/mctabs.js 644 664, 644, 640 root root File
plugins/tinyMCE/utils/validate.js 644 664, 644, 640 root root File
robots.txt 644 664, 644, 640 root root File
system 755 775, 755, 750 root root Folder
system/config 755 775, 755, 750 root root Folder
system/config/.htaccess 644 664, 644, 640 root root File
system/config/config.php 644 664, 644, 640 root root File
system/config/countries.php 644 664, 644, 640 root root File
system/config/dcaconfig.php 644 664, 644, 640 root root File
system/config/langconfig.php 644 664, 644, 640 root root File
system/config/languages.php 644 664, 644, 640 root root File
system/config/localconfig.php 644 664, 644, 640 • www root File
