hier die Ausgabe von "truss pkg"
root@file:/var/db/pkg # truss pkg
mmap(0x0,32768,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34366164992 (0x800621000)
issetugid(0x800820f30,0x7fffffffefd2,0x40,0x0,0xffff800800821f5e,0x0) = 0 (0x0)
lstat("/etc",{ mode=drwxr-xr-x ,inode=9871488,size=2560,blksize=32768 }) = 0 (0x0)
lstat("/etc/libmap.conf",{ mode=-rw-r--r-- ,inode=9886132,size=112,blksize=32768 }) = 0 (0x0)
open("/etc/libmap.conf",O_CLOEXEC,01760) = 3 (0x3)
fstat(3,{ mode=-rw-r--r-- ,inode=9886132,size=112,blksize=32768 }) = 0 (0x0)
mmap(0x0,112,PROT_READ,MAP_PRIVATE,3,0x0) = 34366197760 (0x800629000)
close(3) = 0 (0x0)
lstat("/usr",{ mode=drwxr-xr-x ,inode=9630720,size=512,blksize=32768 }) = 0 (0x0)
lstat("/usr/local",{ mode=drwxr-xr-x ,inode=9630728,size=512,blksize=32768 }) = 0 (0x0)
lstat("/usr/local/etc",{ mode=drwxr-xr-x ,inode=9793539,size=1536,blksize=32768 }) = 0 (0x0)
lstat("/usr/local/etc/libmap.d",0x7fffffffb718) ERR#2 'No such file or directory'
munmap(0x800629000,112) = 0 (0x0)
access("/usr/lib/private/libarchive.so.6",0) ERR#2 'No such file or directory'
open("/var/run/ld-elf.so.hints",O_CLOEXEC,030453770) = 3 (0x3)
read(3,"Ehnt\^A\0\0\0\M^@\0\0\0C\0\0\0\0"...,128) = 128 (0x80)
lseek(3,0x80,SEEK_SET) = 128 (0x80)
read(3,"/lib:/usr/lib:/usr/lib/compat:/u"...,67) = 67 (0x43)
close(3) = 0 (0x0)
access("/lib/libarchive.so.6",0) ERR#2 'No such file or directory'
access("/usr/lib/libarchive.so.6",0) = 0 (0x0)
open("/usr/lib/libarchive.so.6",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9631818,size=616664,blksize=32768 }) = 0 (0x0)
mmap(0x0,4096,PROT_READ,MAP_PRIVATE|MAP_PREFAULT_READ,3,0x0) = 34366197760 (0x800629000)
mmap(0x0,2707456,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34368266240 (0x800822000)
mmap(0x800822000,598016,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34368266240 (0x800822000)
mmap(0x800ab3000,16384,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x91000) = 34370957312 (0x800ab3000)
munmap(0x800629000,4096) = 0 (0x0)
close(3) = 0 (0x0)
access("/usr/lib/private/libelf.so.1",0) ERR#2 'No such file or directory'
access("/lib/libelf.so.1",0) ERR#2 'No such file or directory'
access("/usr/lib/libelf.so.1",0) = 0 (0x0)
open("/usr/lib/libelf.so.1",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9631834,size=90712,blksize=32768 }) = 0 (0x0)
mmap(0x0,2183168,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34370973696 (0x800ab7000)
mmap(0x800ab7000,81920,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34370973696 (0x800ab7000)
mmap(0x800ccb000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x14000) = 34373152768 (0x800ccb000)
close(3) = 0 (0x0)
access("/usr/lib/private/libfetch.so.6",0) ERR#2 'No such file or directory'
access("/lib/libfetch.so.6",0) ERR#2 'No such file or directory'
access("/usr/lib/libfetch.so.6",0) = 0 (0x0)
open("/usr/lib/libfetch.so.6",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9631836,size=68896,blksize=32768 }) = 0 (0x0)
mmap(0x0,2166784,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34373156864 (0x800ccc000)
mmap(0x800ccc000,65536,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34373156864 (0x800ccc000)
mmap(0x800edb000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0xf000) = 34375315456 (0x800edb000)
close(3) = 0 (0x0)
access("/usr/lib/private/libyaml.so.1",0) = 0 (0x0)
open("/usr/lib/private/libyaml.so.1",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9972975,size=117456,blksize=32768 }) = 0 (0x0)
mmap(0x0,2215936,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34375323648 (0x800edd000)
mmap(0x800edd000,114688,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34375323648 (0x800edd000)
mmap(0x8010f9000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x1c000) = 34377535488 (0x8010f9000)
close(3) = 0 (0x0)
access("/usr/lib/private/libsbuf.so.6",0) ERR#2 'No such file or directory'
access("/lib/libsbuf.so.6",0) = 0 (0x0)
open("/lib/libsbuf.so.6",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=13723807,size=9392,blksize=32768 }) = 0 (0x0)
mmap(0x0,2105344,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34377539584 (0x8010fa000)
mmap(0x8010fa000,8192,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34377539584 (0x8010fa000)
mmap(0x8012fb000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x1000) = 34379640832 (0x8012fb000)
close(3) = 0 (0x0)
access("/usr/lib/private/libssl.so.7",0) ERR#2 'No such file or directory'
access("/lib/libssl.so.7",0) ERR#2 'No such file or directory'
access("/usr/lib/libssl.so.7",0) = 0 (0x0)
open("/usr/lib/libssl.so.7",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9630795,size=430352,blksize=32768 }) = 0 (0x0)
mmap(0x0,2527232,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34379644928 (0x8012fc000)
mmap(0x8012fc000,389120,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34379644928 (0x8012fc000)
mmap(0x80155b000,40960,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x5f000) = 34382131200 (0x80155b000)
close(3) = 0 (0x0)
access("/usr/lib/private/libcrypto.so.7",0) ERR#2 'No such file or directory'
access("/lib/libcrypto.so.7",0) = 0 (0x0)
open("/lib/libcrypto.so.7",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=13723778,size=2001568,blksize=32768 }) = 0 (0x0)
mmap(0x0,4108288,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34382172160 (0x801565000)
mmap(0x801565000,1839104,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34382172160 (0x801565000)
mmap(0x801926000,163840,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x1c1000) = 34386108416 (0x801926000)
mmap(0x80194e000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34386272256 (0x80194e000)
close(3) = 0 (0x0)
access("/usr/lib/private/libc.so.7",0) ERR#2 'No such file or directory'
access("/lib/libc.so.7",0) = 0 (0x0)
open("/lib/libc.so.7",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=13723784,size=1567216,blksize=32768 }) = 0 (0x0)
mmap(0x0,3772416,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34386280448 (0x801950000)
mmap(0x801950000,1458176,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34386280448 (0x801950000)
mmap(0x801cb4000,49152,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x164000) = 34389835776 (0x801cb4000)
mmap(0x801cc0000,167936,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_ANON,-1,0x0) = 34389884928 (0x801cc0000)
mmap(0x0,36864,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34366201856 (0x80062a000)
close(3) = 0 (0x0)
access("/lib/libz.so.6",0) = 0 (0x0)
open("/lib/libz.so.6",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=13723815,size=85424,blksize=32768 }) = 0 (0x0)
mmap(0x0,2183168,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34390052864 (0x801ce9000)
mmap(0x801ce9000,81920,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34390052864 (0x801ce9000)
mmap(0x801efd000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x14000) = 34392231936 (0x801efd000)
close(3) = 0 (0x0)
access("/lib/libbz2.so.4",0) ERR#2 'No such file or directory'
access("/usr/lib/libbz2.so.4",0) = 0 (0x0)
open("/usr/lib/libbz2.so.4",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9631827,size=71752,blksize=32768 }) = 0 (0x0)
mmap(0x0,2166784,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34392236032 (0x801efe000)
mmap(0x801efe000,65536,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34392236032 (0x801efe000)
mmap(0x80210e000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x10000) = 34394398720 (0x80210e000)
close(3) = 0 (0x0)
access("/lib/liblzma.so.5",0) ERR#2 'No such file or directory'
access("/usr/lib/liblzma.so.5",0) = 0 (0x0)
open("/usr/lib/liblzma.so.5",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=9631865,size=143736,blksize=32768 }) = 0 (0x0)
mmap(0x0,2240512,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34394402816 (0x80210f000)
mmap(0x80210f000,139264,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34394402816 (0x80210f000)
mmap(0x802331000,4096,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x22000) = 34396639232 (0x802331000)
close(3) = 0 (0x0)
access("/lib/libbsdxml.so.4",0) = 0 (0x0)
open("/lib/libbsdxml.so.4",O_CLOEXEC,030453770) = 3 (0x3)
fstat(3,{ mode=-r--r--r-- ,inode=13723783,size=157600,blksize=32768 }) = 0 (0x0)
mmap(0x0,2252800,PROT_NONE,MAP_PRIVATE|MAP_ANON|MAP_NOCORE,-1,0x0) = 34396643328 (0x802332000)
mmap(0x802332000,147456,PROT_READ|PROT_EXEC,MAP_PRIVATE|MAP_FIXED|MAP_NOCORE|MAP_PREFAULT_READ,3,0x0) = 34396643328 (0x802332000)
mmap(0x802556000,8192,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FIXED|MAP_PREFAULT_READ,3,0x24000) = 34398887936 (0x802556000)
close(3) = 0 (0x0)
munmap(0x800632000,4096) = 0 (0x0)
mmap(0x0,53248,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34366234624 (0x800632000)
munmap(0x800638000,28672) = 0 (0x0)
mmap(0x0,102400,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34366259200 (0x800638000)
sysarch(0x81,0x7fffffffd108,0x4,0x0,0xfffffffffe996080,0xf0000000) = 0 (0x0)
sigprocmask(SIG_BLOCK,SIGHUP|SIGINT|SIGQUIT|SIGKILL|SIGPIPE|SIGALRM|SIGTERM|SIGURG|SIGSTOP|SIGTSTP|SIGCONT|SIGCHLD|SIGTTIN|SIGTTOU|SIGIO|SIGXCPU|SIGXFSZ|SIGVTALRM|SIGPROF|SIGWINCH|SIGINFO|SIGUSR1|SIGUSR2,0x0) = 0 (0x0)
sigprocmask(SIG_SETMASK,0x0,0x0) = 0 (0x0)
readlink("/etc/malloc.conf",0x7fffffffc830,1024) ERR#2 'No such file or directory'
issetugid(0x801a8b93e,0x7fffffffc830,0xffffffffffffffff,0x0,0x3a,0xffffffff0fffffff) = 0 (0x0)
mmap(0x0,4194304,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34398896128 (0x802558000)
munmap(0x802558000,4194304) = 0 (0x0)
mmap(0x0,8384512,PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_ANON,-1,0x0) = 34398896128 (0x802558000)
munmap(0x802558000,2785280) = 0 (0x0)
munmap(0x802c00000,1404928) = 0 (0x0)
access("/usr/local/sbin/pkg",1) = 0 (0x0)
execve("/usr/local/sbin/pkg",<missing argument>,<missing argument>) ERR#8 'Exec format error'
process exit, rval = 1
Gruß ré
