Commodore-Freak
Ex-Linuxer
Guten Morgen zusammen!
Ich hab mir gestern mal aus purer neugier PC-BSD installiert, und bis jetzt macht es einen guten Eindruch. das einzige Problem ist das Ports-System.
Ich habe mich an diesem Tutorial orientiert um es einzurichten:
http://sig9.com/articles/ports-howto
Nach dem ports-supfile editieren muss ich demnach den befehl cvsup -L 2 /root/ports-supfile
ausführen.
Jedoch beschwert sich mein System das es meine IP-Adresse nicht finden kann:
Cannot get IP address of my own host -- is its hostname correct?
Ich weiss nicht ob es was damit zu tun hat aber hier ist meine supfile:
# $FreeBSD: src/share/examples/cvsup/standard-supfile,v 1.23.2.2.2.1 2005/04/03 07:48:09 kensmith Exp $
# This file contains all of the "CVSup collections" that make up the
# FreeBSD-stable source tree.
# CVSup (CVS Update Protocol) allows you to download the latest CVS
# tree (or any branch of development therefrom) to your system easily
# and efficiently (far more so than with sup, which CVSup is aimed
# at replacing). If you're running CVSup interactively, and are
# currently using an X display server, you should run CVSup as follows
# to keep your CVS tree up-to-date:
# cvsup standard-supfile
# If not running X, or invoking cvsup from a non-interactive script, then
# run it as follows:
# cvsup -g -L 2 standard-supfile
# You may wish to change some of the settings in this file to better
# suit your system:
# host=CHANGE_THIS.FreeBSD.org
# This specifies the server host which will supply the
# file updates. You must change it to one of the CVSup
# mirror sites listed in the FreeBSD Handbook at
# http://www.freebsd.org/doc/handbook/mirrors.html.
# You can override this setting on the command line
# with cvsup's "-h host" option.
# base=/var/db
# This specifies the root where CVSup will store information
# about the collections you have transferred to your system.
# A setting of "/var/db" will generate this information in
# /var/db/sup. Even if you are CVSupping a large number of
# collections, you will be hard pressed to generate more than
# ~1MB of data in this directory. You can override the
# "base" setting on the command line with cvsup's "-b base"
# option. This directory must exist in order to run CVSup.
# prefix=/usr
# This specifies where to place the requested files. A
# setting of "/usr" will place all of the files requested
# in "/usr/src" (e.g., "/usr/src/bin", "/usr/src/lib").
# The prefix directory must exist in order to run CVSup.
# Defaults that apply to all the collections
# IMPORTANT: Change the next line to use one of the CVSup mirror sites
# listed at http://www.freebsd.org/doc/handbook/mirrors.html.
*default host=cvsup2.de.FreeBSD.org
*default base=/var/db
*default prefix=/usr
*default release=cvs tag=RELENG_5_4
*default delete use-rel-suffix
# If you seem to be limited by CPU rather than network or disk bandwidth, try
# commenting out the following line. (Normally, today's CPUs are fast enough
# that you want to run compression.)
*default compress
## Main Source Tree.
# The easiest way to get the main source tree is to use the "src-all"
# mega-collection. It includes all of the individual "src-*" collections.
src-all
# These are the individual collections that make up "src-all". If you
# use these, be sure to comment out "src-all" above.
#src-base
#src-bin
#src-contrib
#src-etc
#src-games
#src-gnu
#src-include
#src-kerberos5
#src-kerberosIV
#src-lib
#src-libexec
#src-release
#src-sbin
#src-share
#src-sys
#src-tools
#src-usrbin
#src-usrsbin
# These are the individual collections that make up FreeBSD's crypto
# collection. They are no longer export-restricted and are a part of
# src-all
#src-crypto
#src-eBones
#src-secure
#src-sys-crypto
Irgendwelche Vorschläge?
Danke schonmal im vorraus!
ausführen.
# suit your system:
# base=/var/db
# prefix=/usr
*default compress
src-all
#src-base
#src-bin
#src-contrib
#src-etc
#src-games
#src-gnu
#src-include
#src-kerberos5
#src-kerberosIV
#src-lib
#src-libexec
#src-release
#src-sbin
#src-share
#src-sys
#src-tools
#src-usrbin
#src-usrsbin
# src-all
#src-crypto
#src-eBones
#src-secure
#src-sys-crypto
