xGhost
OpenBSD Freack
Moins,
Kann es sein, dass portsupgrade nicht mehr funktioniert?
es kommt immer der selbe fehler.
Dann habe ich die pkgdb.db geloescht und waerend dem
neu erstellen kam wieder der Fehler.
Danach habe ich /usr/ports/* geloescht und mit portsnap neu erstellt.
Die pkgdb.db wieder geloscht und dann wieder portsupgrade -a
immer das selbe...
Kennt jemand das Problem?
[missing key: categories] [Updating the portsdb <format:bdb_btree> in /usr/po
... - 16437 port entries found .........1000.........2000.........3000......
4000.........5000.........6000.........7000.........8000.........9000........
000.........11000.........12000.........13000.........14000.........15000....
..16000.... ..... done]
missing key: categories: Cannot read the portsdb!
/usr/local/lib/ruby/site_ruby/1.8/portsdb.rb:548:in `open_db': database file
or (PortsDB::DBError)
from /usr/local/lib/ruby/site_ruby/1.8/portsdb.rb:702:in `port'
from /usr/local/lib/ruby/site_ruby/1.8/portsdb.rb:890:in `all_depends
st'
from /usr/local/lib/ruby/site_ruby/1.8/pkgdb.rb:809:in `tsort_build'
from /usr/local/lib/ruby/site_ruby/1.8/pkgdb.rb:801:in `each'
from /usr/local/lib/ruby/site_ruby/1.8/pkgdb.rb:801:in `tsort_build'
from /usr/local/lib/ruby/site_ruby/1.8/pkgdb.rb:823:in `sort_build'
from /usr/local/lib/ruby/site_ruby/1.8/pkgdb.rb:827:in `sort_build!'
from /usr/local/sbin/portupgrade:721:in `main'
from /usr/local/lib/ruby/1.8/optparse.rb:755:in `initialize'
from /usr/local/sbin/portupgrade:220:in `new'
from /usr/local/sbin/portupgrade:220:in `main'
from /usr/local/sbin/portupgrade:2084
immer das selbe...
