Postfix hat Probleme mit smtp-auth
righter
Sorry dass ich euch nerve mit dem Newbie Thema aber ich bin jetzt etwa seit 30h dran habe auch schon zigmal gegooglet und diverse howtos ausprobiert um dies zu aktivieren und krieg es einfach nicht hin wie ich will.
Habe FreeBSD 6.0 mit Postfix 2.2.8, qpopper 4.0.8 , cyrussasl 1.5
Alles aus den Ports installiert
Hier die Main.cf
myhostname = mail.righter.ch
mydomain = righter.ch
myorigin = $mydomain
mydestination = $myhostname, localhost, $mydomain
readme_directory = no
sample_directory = /usr/local/etc/postfix
sendmail_path = /usr/local/sbin/sendmail
html_directory = no
setgid_group = maildrop
command_directory = /usr/local/sbin
manpage_directory = /usr/local/man
daemon_directory = /usr/local/libexec/postfix
newaliases_path = /usr/local/bin/newaliases
mailq_path = /usr/local/bin/mailq
queue_directory = /var/spool/postfix
mail_owner = postfix
unknown_local_recipient_reject_code = 450
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = server
smtpd_sasl_security_options = noanonymous
broken_sasl_auth_clients = yes
smtpd_recipient_restrictions = permit_sasl_authenticated, reject
die master.cf
# Postfix master process configuration file.  For details on the format
# of the file, see the Postfix master(5) manual page.
# service type  private unpriv  chroot  wakeup  maxproc command + args
#               (yes)   (yes)   (yes)   (never) (100)
smtp      inet  n       -       n       -       -       smtpd -v
#submission inet n      -       n       -       -       smtpd
#       -o smtpd_etrn_restrictions=reject
#       -o smtpd_client_restrictions=permit_sasl_authenticated,reject
#smtps    inet  n       -       n       -       -       smtpd
#  -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes
#  -o smtpd_enforce_tls=yes -o smtpd_sasl_auth_enable=yes
#628      inet  n       -       n       -       -       qmqpd
pickup    fifo  n       -       n       60      1       pickup
cleanup   unix  n       -       n       -       0       cleanup
qmgr      fifo  n       -       n       300     1       qmgr
#qmgr     fifo  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       n       1000?   1       tlsmgr
rewrite   unix  -       -       n       -       -       trivial-rewrite
bounce    unix  -       -       n       -       0       bounce
defer     unix  -       -       n       -       0       bounce
trace     unix  -       -       n       -       0       bounce
verify    unix  -       -       n       -       1       verify
flush     unix  n       -       n       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
smtp      unix  -       -       n       -       -       smtp
# When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay     unix  -       -       n       -       -       smtp
        -o fallback_relay=
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       n       -       -       showq
error     unix  -       -       n       -       -       error
discard   unix  -       -       n       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       n       -       -       lmtp
anvil     unix  -       -       n       -       1       anvil
scache    unix  -       -       n       -       1       scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent.  See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop  unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
# The Cyrus deliver program has changed incompatibly, multiple times.
old-cyrus unix  -       n       n       -       -       pipe
  flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
  user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=foo argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
/usr/local/lib/sasl/smtpd.conf:
#Check mit SASL Datenbank
pwcheck_method: sasldb
Ich möchte einfach eine stinknormale smtp auth haben.
wenn ich nun per client senden möchte verlangt er immer pw.
das einzig schlaue was mir jedoch nicht weitergeholfen hat fand ich im maillog:
Feb 28 14:04:59 server postfix/smtpd[850]: connection established
Feb 28 14:04:59 server postfix/smtpd[850]: master_notify: status 0
Feb 28 14:04:59 server postfix/smtpd[850]: name_mask: resource
Feb 28 14:04:59 server postfix/smtpd[850]: name_mask: software
Feb 28 14:04:59 server postfix/smtpd[850]: name_mask: noanonymous
Feb 28 14:04:59 server postfix/smtpd[850]: connect from cable-static-87-245-102-63.shinternet.ch[87.245.102.63]
Feb 28 14:04:59 server postfix/smtpd[850]: match_list_match: cable-static-87-245-102-63.shinternet.ch: no match
Feb 28 14:04:59 server postfix/smtpd[850]: match_list_match: 87.245.102.63: no match
Feb 28 14:04:59 server postfix/smtpd[850]: match_hostname: cable-static-87-245-102-63.shinternet.ch ~? 87.245.120.32/29
Feb 28 14:04:59 server postfix/smtpd[850]: match_hostaddr: 87.245.102.63 ~? 87.245.120.32/29
Feb 28 14:04:59 server postfix/smtpd[850]: match_hostname: cable-static-87-245-102-63.shinternet.ch ~? 87.0.0.0/8
Feb 28 14:04:59 server postfix/smtpd[850]: match_hostaddr: 87.245.102.63 ~? 87.0.0.0/8
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 220 mail.righter.ch ESMTP Postfix
Feb 28 14:04:59 server postfix/smtpd[850]: < cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: EHLO righternb
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-mail.righter.ch
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-PIPELINING
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-SIZE 10240000
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-VRFY
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-ETRN
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-AUTH LOGIN PLAIN DIGEST-MD5 CRAM-MD5
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250-AUTH=LOGIN PLAIN DIGEST-MD5 CRAM-MD5
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 250 8BITMIME
Feb 28 14:04:59 server postfix/smtpd[850]: < cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: AUTH LOGIN
Feb 28 14:04:59 server postfix/smtpd[850]: smtpd_sasl_authenticate: sasl_method LOGIN
Feb 28 14:04:59 server postfix/smtpd[850]: smtpd_sasl_authenticate: uncoded challenge: Username:
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 334 VXNlcm5hbWU6
Feb 28 14:04:59 server postfix/smtpd[850]: < cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: cmlnaHRlcg==
Feb 28 14:04:59 server postfix/smtpd[850]: smtpd_sasl_authenticate: decoded response: BENUTZERNAME
Feb 28 14:04:59 server postfix/smtpd[850]: smtpd_sasl_authenticate: uncoded challenge: Password:
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 334 ""HASH""
Feb 28 14:04:59 server postfix/smtpd[850]: < cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: ""HASH""==
Feb 28 14:04:59 server postfix/smtpd[850]: smtpd_sasl_authenticate: decoded response: PW
Feb 28 14:04:59 server postfix/smtpd[850]: warning: cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: SASL LOGIN authentication failed
Feb 28 14:04:59 server postfix/smtpd[850]: > cable-static-87-245-102-63.shinternet.ch[87.245.102.63]: 535 Error: authentication failed
Feb 28 14:04:59 server postfix/smtpd[850]: smtp_get: EOF
Feb 28 14:04:59 server postfix/smtpd[850]: lost connection after AUTH from cable-static-87-245-102-63.shinternet.ch[87.245.102.63]
Feb 28 14:04:59 server postfix/smtpd[850]: disconnect from cable-static-87-245-102-63.shinternet.ch[87.245.102.63]
Feb 28 14:04:59 server postfix/smtpd[850]: master_notify: status 1
Feb 28 14:04:59 server postfix/smtpd[850]: connection closed
In den anderen Logs ist finde ich keine Fehler oder so.
danke für eure geduld
Ein Schuss ins Blaue:
Irgendwoher habe ich im Hinterkopf, dass SMTP-AUTH mit Postfix + SASL2 nur mit der "plain"-Methode funktioniert.
Versuch mal eine Zeile in die /usr/local/lib/sasl2/smtpd.conf einzufügen:
mech_list: plain
HTH & Ciao.
Markus Mann
Hmm...
# less  /usr/local/lib/sasl2/smtpd.conf
pwcheck_method: authdaemond
log_level: 3
mech_list: LOGIN DIGEST-MD5 CRAM-MD5
authdaemond_path:/var/run/authdaemond/socket
*Aaahrg* Überlesen. Wenn du sasl in Version 1 benutzt, dann sollte /usr/local/lib/sasl2 eigentlich gar nicht existieren bzw. Einträge dort werden wohl nicht beachtet. Versuch es trotzdem mal mit "mech_list: plain" aber eben in /usr/local/lib/sasl/smtpd.conf.
Ich verwende auch postfix 2.2 mit sasl2 und hatte da eigentlich keine Probleme:
mann@bsd:~$ pkg_info | egrep "postfix|sasl"
cyrus-sasl-2.1.21_2 RFC 2222 SASL (Simple Authentication and Security Layer)
postfix-2.2.9,1     A secure alternative to widely-used Sendmail
Ciao.
Markus Mann
Hab das jetz mal so abgeändert wie du gemeint hast:
log_level: 3
bleibt gleich ausser dass sich der auth fehler folgendermassen meldet:
Mar  2 16:03:48 server postfix/smtpd[1492]: warning: SASL authentication problem: unrecognized plaintext verifier authdaemond
Mar  2 16:03:48 server postfix/smtpd[1492]: warning: unknown[87.245.102.63]: SASL LOGIN authentication failed
Mar  2 16:03:48 server postfix/smtpd[1492]: > unknown[87.245.102.63]: 535 Error: authentication failed
auch nur mit PLAIN klappt es nicht ;'(
Hat Postfix Zugriffrechte auf die sasldb? Postfix muss diese lesen können (chown postfix sasldb).
Hast Du
smtpd_sasl_local_domain = domain
in der main.cf? Wobei domain identisch mit dem sein muss was in Deiner sasldb, auflisten mit sasldblistuser, steht.
Wobei in der salsdb username und domain stehen muss, also test@example.org [hier ist das PW]
Du hast da mehrere Fehler drin, also der Eintrag:
log_level: 3
wird Dir nichts nützen da Du ja nicht gegen Courier-Authdaemon sondern gegen sie sasldb Authentifizierung machen möchtest. Schau erstmal nach was Du Installiert hast (cyrus-sasl oder cyrus-sasl2) je nachdem muß der Eintrag so aussehen:
pwcheck_method: sasldb > bei cyrus-sasl
pwcheck_method: sasldb2 > bei cyrus-sasl2
Wichtig sind noch die Rechte der /usr/local/etc/sasldb oder sasldb2
In der /usr/local/etc/postfix/main.cf muß folgendes drin stehen:
smtpd_sasl2_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, permit
Wichtig sind vorallem die Rechte der sasldb!!
Gruß, Micha
kommt langsam
ok hab jetzt mal noch cyrus sasl2 rübergefitzt und jetzt klappt die anmeldung alles tip top.. jedcoh kann ich jetzt auch ohne smtp auth senden,, ich hab da diverse sachen ausprobiert es hat nicht richtig geklappt.
ich denke der fehler lieg hier
ich will einfach nur dass clients mit smtp auth kommen zugelassen werden, egal wohin er mails schickt und von welchem network er kommt.
thx
Das "permit" am Ende brauchst du nicht, dann sollte es eigentlich so klappen, wie du dir das vorstellst. Zum Testen kannst du ja auch noch das erste "permit_mynetworks" weglassen, dann müsste der Mailversand eigentlich nur noch für authentifizierte Clients möglich sein.
Ciao.
Markus Mann
Das permit_mynetworks NICHT raus nehmen!! Sonst kann cron usw. keine Mails versenden, statt dessen die Zeile mynetworks in der main.cf ändern:
mynetworks = 127.0.0.0/8
somit kann localhost Mails senden, aber alle anderen müssen sich Anmelden.
Gruß, Micha
asg said:
Hmm...
log_level: 3
Wie klappt denn das? Ich habe genau das gleiche, funktioniert auch einwandfrei mit LOGIN, sobald ich aber z.B. CRAM-MD5 zur AUTH verwende, geht mir Cyrus automatisch in der sasldb2 gucken, und schickt die Abfrage nicht mehr über authdaemond... da reiss ich mir schon über einen Monat die Haare dran aus, kann aber keine Erklärung dafür finden.
Bin mir jetzt nicht sicher, aber soweit ich weiss geht nur PLAIN und LOGIN über authdaemond. DIGEST-MD5 und CRAM-MD5 geht nur bei sasldb/sasldb2.
Gruß Micha
Gruß Micha
Das kann so gut sein, das würde das ganze erklären... wäre aber auch eine riesen Schweinerei, das ich die ganzen Logins/Passwörter doppelt halten muss...
Kann das jemand bestätigen bzw. kennt jemand einen Ausweg?
ich knack ab
hab das permit draussen. kann nun auch schön mails an meine domäne senden.
Jedoch alle anderen Adressen blockts mir ab.
Hier nochmals die main.cf
html_directory = no
#smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $mydomain
und der maillog output beim fehler
Mar 14 10:27:31 server postfix/smtpd[44019]: < unknown[87.245.102.68]: MAIL FROM: <righter@righter.ch>
Mar 14 10:27:31 server postfix/smtpd[44019]: extract_addr: input: <righter@righter.ch>
Mar 14 10:27:31 server postfix/smtpd[44019]: smtpd_check_addr: addr=righter@righter.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: ctable_locate: leave existing entry key righter@righter.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: extract_addr: result: righter@righter.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: fsspace: .: block size 2048, blocks free 877668
Mar 14 10:27:31 server postfix/smtpd[44019]: smtpd_check_size: blocks 2048 avail 877668 min_free 0 msg_size_limit 10240000
Mar 14 10:27:31 server postfix/smtpd[44019]: > unknown[87.245.102.68]: 250 Ok
Mar 14 10:27:31 server postfix/smtpd[44019]: < unknown[87.245.102.68]: RCPT TO: <dkaufmann@letec.ch>
Mar 14 10:27:31 server postfix/smtpd[44019]: extract_addr: input: <dkaufmann@letec.ch>
Mar 14 10:27:31 server postfix/smtpd[44019]: smtpd_check_addr: addr=dkaufmann@letec.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: ctable_locate: move existing entry key dkaufmann@letec.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: extract_addr: result: dkaufmann@letec.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: >>> START Recipient address RESTRICTIONS <<<
Mar 14 10:27:31 server postfix/smtpd[44019]: generic_checks: name=permit_mynetworks
Mar 14 10:27:31 server postfix/smtpd[44019]: permit_mynetworks: unknown 87.245.102.68
Mar 14 10:27:31 server postfix/smtpd[44019]: match_hostname: unknown ~? 127.0.0.0/8
Mar 14 10:27:31 server postfix/smtpd[44019]: match_hostaddr: 87.245.102.68 ~? 127.0.0.0/8
Mar 14 10:27:31 server postfix/smtpd[44019]: match_list_match: unknown: no match
Mar 14 10:27:31 server postfix/smtpd[44019]: match_list_match: 87.245.102.68: no match
Mar 14 10:27:31 server postfix/smtpd[44019]: generic_checks: name=permit_mynetworks status=0
Mar 14 10:27:31 server postfix/smtpd[44019]: generic_checks: name=permit_sasl_authenticated
Mar 14 10:27:31 server postfix/smtpd[44019]: generic_checks: name=permit_sasl_authenticated status=0
Mar 14 10:27:31 server postfix/smtpd[44019]: generic_checks: name=reject_unauth_destination
Mar 14 10:27:31 server postfix/smtpd[44019]: reject_unauth_destination: dkaufmann@letec.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: permit_auth_destination: dkaufmann@letec.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: ctable_locate: leave existing entry key dkaufmann@letec.ch
Mar 14 10:27:31 server postfix/smtpd[44019]: NOQUEUE: reject: RCPT from unknown[87.245.102.68]: 554 <dkaufmann@letec.ch>: Relay access denied; from=<righter@righter.ch> to=<dkaufmann@letec.ch> proto=ESMTP helo=<righternb>
Mar 14 10:27:31 server postfix/smtpd[44019]: generic_checks: name=reject_unauth_destination status=2
Mar 14 10:27:31 server postfix/smtpd[44019]: > unknown[87.245.102.68]: 554 <dkaufmann@letec.ch>: Relay access denied
Mar 14 10:27:31 server postfix/smtpd[44019]: < unknown[87.245.102.68]: QUIT
Mar 14 10:27:31 server postfix/smtpd[44019]: > unknown[87.245.102.68]: 221 Bye
Mar 14 10:27:31 server postfix/smtpd[44019]: send attr request = disconnect
Mar 14 10:27:31 server postfix/smtpd[44019]: send attr ident = smtp:87.245.102.68
Mar 14 10:27:31 server postfix/smtpd[44019]: private/anvil: wanted attribute: status
Mar 14 10:27:31 server postfix/smtpd[44019]: input attribute name: status
Mar 14 10:27:31 server postfix/smtpd[44019]: input attribute value: 0
Mar 14 10:27:31 server postfix/smtpd[44019]: private/anvil: wanted attribute: (list terminator)
Mar 14 10:27:31 server postfix/smtpd[44019]: input attribute name: (end)
Mar 14 10:27:31 server postfix/smtpd[44019]: disconnect from unknown[87.245.102.68]
Mar 14 10:27:31 server postfix/smtpd[44019]: master_notify: status 1
Mar 14 10:27:31 server postfix/smtpd[44019]: connection closed
wieso blockt der mir alle externen??
