Dec 28 07:23:48 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(6) state = Opened
Dec 28 07:24:18 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(7) state = Opened
Dec 28 07:24:18 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(7) state = Opened
Dec 28 07:24:48 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(8) state = Opened
Dec 28 07:24:48 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(8) state = Opened
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: Received NGM_PPPOE_CLOSE
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: Device disconnected
Dec 28 07:25:02 LittelGate ppp[495]: tun0: CCP: deflink: State change Stopped --> Closed
Dec 28 07:25:02 LittelGate ppp[495]: tun0: CCP: deflink: State change Closed --> Initial
Dec 28 07:25:02 LittelGate ppp[495]: tun0: LCP: deflink: LayerDown
Dec 28 07:25:02 LittelGate ppp[495]: tun0: LCP: deflink: State change Opened --> Starting
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: open -> lcp
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: deflink: LayerDown: 77.XXX.XXX.XX
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: deflink: State change Opened --> Starting
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: deflink: LayerFinish.
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: Connect time: 86400 secs: 17783937808 octets in, 202151040 octets out
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: 12313223 packets in, 2013094 packets out
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: total 208172 bytes/sec, peak 11701658 bytes/sec on Sat Dec 28 04:54:09 2024
Dec 28 07:25:02 LittelGate ppp[495]: tun0: IPCP: deflink: State change Starting --> Initial
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: bundle: Terminate
Dec 28 07:25:02 LittelGate ppp[495]: tun0: LCP: deflink: LayerFinish
Dec 28 07:25:02 LittelGate ppp[495]: tun0: LCP: deflink: State change Starting --> Initial
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: Disconnected!
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: lcp -> logout
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: logout -> hangup
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: Connect time: 86401 secs: 17759347394 octets in, 206205990 octets out
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: 12316129 packets in, 2015931 packets out
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: total 207932 bytes/sec, peak 11718074 bytes/sec on Sat Dec 28 04:54:09 2024
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: hangup -> opening
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: bundle: Establish
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Phase: deflink: Enter pause (3) for redialing.
Dec 28 07:25:02 LittelGate ppp[495]: tun0: Chat: deflink: Reconnect try 1 of 0
Dec 28 07:25:05 LittelGate ppp[495]: tun0: Chat: deflink: Redial timer expired.
Dec 28 07:25:05 LittelGate ppp[495]: tun0: Phase: deflink: Connected!
Dec 28 07:25:05 LittelGate ppp[495]: tun0: Phase: deflink: opening -> dial
Dec 28 07:25:05 LittelGate ppp[495]: tun0: Phase: deflink: dial -> carrier
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: Received NGM_PPPOE_ACNAME (hook "XXXXX")
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: Received NGM_PPPOE_SESSIONID
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: Received NGM_PPPOE_SUCCESS
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: deflink: carrier -> login
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: deflink: login -> lcp
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: FSM: Using "deflink" as a transport
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: State change Initial --> Closed
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: State change Closed --> Stopped
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: RecvConfigReq(151) state = Stopped
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: MRU[4] 1492
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: AUTHPROTO[4] 0xc023 (PAP)
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: MAGICNUM[6] 0x4d3e4e02
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: SendConfigReq(3) state = Stopped
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: MAGICNUM[6] 0xb7b01278
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: QUALPROTO[8] proto c025, interval 30000ms
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: SendConfigAck(151) state = Stopped
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: LayerStart
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: State change Stopped --> Ack-Sent
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: RecvConfigRej(3) state = Ack-Sent
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: SendConfigReq(4) state = Ack-Sent
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: RecvConfigAck(4) state = Ack-Sent
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: State change Ack-Sent --> Opened
Dec 28 07:25:06 LittelGate ppp[495]: tun0: LCP: deflink: LayerUp
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: bundle: Authenticate
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: deflink: his = PAP, mine = none
Dec 28 07:25:06 LittelGate ppp[495]: tun0: Phase: Pap Output: DSL0XXXXX@xxx.bbi-o2.de ********
Dec 28 07:25:07 LittelGate ppp[495]: tun0: Phase: Pap Input: SUCCESS (Accepted.)
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: FSM: Using "deflink" as a transport
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: deflink: State change Initial --> Closed
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: deflink: LayerStart.
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: MPPE: Not usable without CHAP81
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: deflink: SendConfigReq(1) state = Closed
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: DEFLATE[4] win 15
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: PRED1[2]
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: deflink: State change Closed --> Req-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: Phase: deflink: lcp -> open
Dec 28 07:25:07 LittelGate ppp[495]: tun0: Phase: bundle: Network
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: FSM: Using "deflink" as a transport
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: State change Initial --> Closed
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: LayerStart.
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: SendConfigReq(3) state = Closed
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: IPADDR[6] 77.XXX.XXX.XX
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: PRIDNS[6] 62.XXX.XXX.X
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: SECDNS[6] 62.XXX.XXX.X
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: State change Closed --> Req-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: RecvConfigReq(1) state = Req-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: IPADDR[6] 62.XXX.XXX.XXX
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: SendConfigAck(1) state = Req-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: State change Req-Sent --> Ack-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: LCP: deflink: RecvProtocolRej(1) state = Opened
Dec 28 07:25:07 LittelGate ppp[495]: tun0: LCP: deflink: -- Protocol 0x80fd (Compression Control Protocol) was rejected!
Dec 28 07:25:07 LittelGate ppp[495]: tun0: CCP: deflink: State change Req-Sent --> Stopped
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: RecvConfigNak(3) state = Ack-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: IPADDR[6] 78.XXX.XXX.XXX
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: IPADDR[6] changing address: 77.XXX.XXX.XXX --> 78.XXX.XXX.XXX
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: Primary nameserver set to 62.XXX.XXX.X
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: Secondary nameserver set to 62.XXX.XXX.X
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: SendConfigReq(4) state = Ack-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: IPADDR[6] 78.XX.XXX.XXX
Dec 28 07:25:07 LittelGate ppp[495]: tun0: Warning: ff02::/: Change route failed: errno: File exists
Dec 28 07:25:07 LittelGate syslogd: last message repeated 1 times
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: RecvConfigAck(4) state = Ack-Sent
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: State change Ack-Sent --> Opened
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: deflink: LayerUp.
Dec 28 07:25:07 LittelGate ppp[495]: tun0: IPCP: myaddr 78.XX.XXX.XXX hisaddr = 62.XX.XXX.XX
Dec 28 07:25:37 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(1) state = Opened
Dec 28 07:25:37 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(1) state = Opened
Dec 28 07:26:22 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(2) state = Opened
Dec 28 07:26:22 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(2) state = Opened
Dec 28 07:26:52 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(3) state = Opened
Dec 28 07:26:52 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(3) state = Opened
Dec 28 07:27:22 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(4) state = Opened
Dec 28 07:27:22 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(4) state = Opened
Dec 28 07:27:52 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(5) state = Opened
Dec 28 07:27:52 LittelGate ppp[495]: tun0: LCP: deflink: SendEchoReply(5) state = Opened
Dec 28 07:28:22 LittelGate ppp[495]: tun0: LCP: deflink: RecvEchoRequest(6) state = Opened
