Hallo Leute,
ich habe folgendes Problem. Ich versuche seit einiger Zeit kde3 über den port x11/kde3 zu installieren. Bei der installation von postgresql74-client (genauergesagt beim configure script) bekomme ich folgende Fehlermeldung:
===> Installing for kde-3.4.2
===> kde-3.4.2 depends on executable: kjumpingcube - found
===> kde-3.4.2 depends on executable: kdessh - found
===> kde-3.4.2 depends on executable: kword - not found
===> Verifying install for kword in /usr/ports/editors/koffice-kde3
===> koffice-1.4.1,1 depends on file: /usr/local/lib/libpqxx.a - not found
===> Verifying install for /usr/local/lib/libpqxx.a in /usr/ports/databases/postgresql-libpqxx
===> postgresql-libpqxx-2.5.5 depends on executable: gmake - found
===> postgresql-libpqxx-2.5.5 depends on file: /usr/local/bin/libtool15 - found
===> postgresql-libpqxx-2.5.5 depends on shared library: pq.3 - not found
===> Verifying install for pq.3 in /usr/ports/databases/postgresql74-client
===> Vulnerability check disabled, database not found
===> Found saved configuration for postgresql-client-7.4.8
===> Extracting for postgresql-client-7.4.8
=> Checksum OK for postgresql/postgresql-base-7.4.8.tar.bz2.
=> Checksum OK for postgresql/postgresql-opt-7.4.8.tar.bz2.
===> Patching for postgresql-client-7.4.8
===> Applying FreeBSD patches for postgresql-client-7.4.8
===> postgresql-client-7.4.8 depends on executable: gmake - found
===> postgresql-client-7.4.8 depends on shared library: krb5.3 - found
===> postgresql-client-7.4.8 depends on shared library: intl - found
===> Configuring for postgresql-client-7.4.8
checking build system type... i386-portbld-freebsd5.4
checking host system type... i386-portbld-freebsd5.4
checking which template to use... freebsd
checking whether to build with 64-bit integer date/time support... no
checking whether NLS is wanted... yes
checking for default port number... 5432
checking for i386-portbld-freebsd5.4-gcc... cc
checking for C compiler default output... a.out
checking whether the C compiler works... ===> Script "configure" failed unexpectedly.
Please report the problem to girgen@FreeBSD.org [maintainer] and attach the
"/usr/ports/databases/postgresql74-client/work/postgresql-7.4.8/config.log"
including the output of the failure of your make command. Also, it might be
a good idea to provide an overview of all packages installed on your system
(e.g. an `ls /var/db/pkg`).
*** Error code 1
Stop in /usr/ports/databases/postgresql74-client.
*** Error code 1
Stop in /usr/ports/databases/postgresql-libpqxx.
*** Error code 1
Stop in /usr/ports/editors/koffice-kde3.
*** Error code 1
Stop in /usr/ports/x11/kde3.
Jemand ne Idee was zu tun ist? Ich bin ein newbie in Sachen FreeBSD und weiß deshalb nicht welche Dateien bzw Outputs ihr noch brauchen könnt. Daher hoffe ich auf eure Nachsicht.
mfg
*** Error code 1
*** Error code 1
*** Error code 1
*** Error code 1
mfg
