hypernetics
Kollegenschwein
bei der Installation der aktuellen Samba-Release aus den Ports, bekomme ich von meinem Fb5.3-Server folgendes vorgesetzt:
<schnippel>
===> samba-3.0.11,1 depends on file: /usr/local/bin/autoconf259 - found
===> samba-3.0.11,1 depends on shared library: cups.2 - found
===> samba-3.0.11,1 depends on shared library: popt.0 - found
===> samba-3.0.11,1 depends on shared library: ldap-2.2.7 - found
===> samba-3.0.11,1 depends on shared library: iconv.3 - found
===> Configuring for samba-3.0.11,1
!!! Due to a bug in the deinstall procedure in port versions prior to 3.0.9,
!!! you should BACK UP YOUR VALUABLE /var/db/samba/windbindd_* FILES
!!! before you continue the (re)installation.
*** Press Ctrl-C *now* if you need to preserve these files ***
exec: /usr/local/bin/autom4te259: not found
*** Error code 127
</schnippel>
Weiss jemand, was hier los ist?
<schnippel>
*** Error code 127
</schnippel>
