Problem Request bei Port?
  • Thread starter Thread starter tib
  • Start date Start date
/usr/ports/devel/porttools
less pkg-descr
FreeBSD Port Tools includes the following commands:
- port create: create a new port from a template
- port diff: generate a diff against a previous version of the port
- port fetch: fetch distfile(s) of a new version of the port
- port help: display usage summary for port(1) commands
- port submit: submit a PR with new port, or port change/update
- port test: automate testing a new port or a port update
tib said:
2. Eine explizite Aussage bzgl. exakten Verfahrensweise kann ich dort nicht herauslesen.
Dann mußt du genauer lesen:
http://www.freebsd.org/doc/en_US.ISO8859-1/articles/problem-reports/pr-when.html said:
Next, to decide to whom you should file your problem report, you need to understand that the software that makes up FreeBSD is composed of several different elements:
  • Individual applications that are not in the base system but are instead part of the FreeBSD Ports Collection (category ports). Most of these applications are not written by FreeBSD developers; what FreeBSD provides is merely a framework for installing the application. Therefore, you should only report a problem to the FreeBSD developers when you believe the problem is FreeBSD-specific; otherwise, you should report it to the authors of the software.
Das beantwortet deine Frage mehr als explizit.
