habe von http://download.purpe.com/ die treiber geladen,
bei make bekomme ich folgende fehlermeldung:
hab mich an die anleitung vom wiki gehalten.
lg,
tux# make
===> kmod
Warning: Object directory not changed from original /usr/home/schendi/saa/kmod
@ -> /usr/src/sys
machine -> /usr/src/sys/i386/include
awk -f @/tools/makeobjops.awk @/dev/iicbus/iicbus_if.m -h
awk -f @/tools/makeobjops.awk @/kern/device_if.m -h
awk -f @/tools/makeobjops.awk @/kern/bus_if.m -h
awk -f @/tools/makeobjops.awk @/dev/pci/pci_if.m -h
cc -O -pipe -D_KERNEL -DKLD_MODULE -nostdinc -I- -I. -I@ -I@/contrib/altq -I@/../include -I/usr/include -finline-limit=8000 -fno-common -mno-align-long-strings -mpreferred-stack-boundary=2 -ffreestanding -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -fformat-extensions -std=c99 -c saa713x.c
cc -O -pipe -D_KERNEL -DKLD_MODULE -nostdinc -I- -I. -I@ -I@/contrib/altq -I@/../include -I/usr/include -finline-limit=8000 -fno-common -mno-align-long-strings -mpreferred-stack-boundary=2 -ffreestanding -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -fformat-extensions -std=c99 -c saa713x_i2c.c
cc -O -pipe -D_KERNEL -DKLD_MODULE -nostdinc -I- -I. -I@ -I@/contrib/altq -I@/../include -I/usr/include -finline-limit=8000 -fno-common -mno-align-long-strings -mpreferred-stack-boundary=2 -ffreestanding -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -fformat-extensions -std=c99 -c saa713x_video.c
cc -O -pipe -D_KERNEL -DKLD_MODULE -nostdinc -I- -I. -I@ -I@/contrib/altq -I@/../include -I/usr/include -finline-limit=8000 -fno-common -mno-align-long-strings -mpreferred-stack-boundary=2 -ffreestanding -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -fformat-extensions -std=c99 -c saa713x_audio.c
ld -d -warn-common -r -d -o saa.kld saa713x.o saa713x_i2c.o saa713x_video.o saa713x_audio.o
touch /usr/home/schendi/saa/kmod/export_syms
awk -f /sys/conf/kmod_syms.awk saa.kld /usr/home/schendi/saa/kmod/export_syms | xargs -J% objcopy % saa.kld
ld -Bshareable -d -warn-common -o saa.ko saa.kld
objcopy --strip-debug saa.ko
===> support
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o dump_eeprom dump_eeprom.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o scan_i2c scan_i2c.c
cc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -c tuner_ctrl.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o set_channel set_channel.c tuner_ctrl.o
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o set_videoopt set_videoopt.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o tune_channels tune_channels.c tuner_ctrl.o
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o set_audioopt set_audioopt.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o flash_eeprom flash_eeprom.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o audio_looper audio_looper.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o audio_player audio_player.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o audio_setlineout audio_setlineout.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o video_printsts video_printsts.c
gcc -I../kmod -DTUNER_APITYPE_PHILIPS -DTUNER_PAL -DTUNER_WR_I2CADDR=0xc0 -DTUNER_RD_I2CADDR=0xc1 -o set_gpio set_gpio.c
===> tvv
Warning: Object directory not changed from original /usr/home/schendi/saa/tvv
cc -I/usr/X11R6/include -I../kmod -DTVV_USE_MMXEXT -c tvv.c
cc -I/usr/X11R6/include -I../kmod -DTVV_USE_MMXEXT -c tvv_clip.c
cc -I/usr/X11R6/include -I../kmod -DTVV_USE_MMXEXT -o tvv tvv.o tvv_clip.o -L/usr/X11R6/lib -lXt -lXv -lXxf86dga -lXext -lSM -lICE -lX11
===> tvv/FLTK
Warning: Object directory not changed from original /usr/home/schendi/saa/tvv/FLTK
fluid -c gui.fld
fluid:No such file or directory
*** Error code 1
Stop in /usr/home/schendi/saa/tvv/FLTK.
*** Error code 1
lg,
