Probleme mit dem Bau von devl/qt4-moc auf 7.2 (amd64)
crotchmaster
happy BSD user
Hallo Forenleser,
ich habe im Moment Probleme mit dem Bau des Ports devel/qt4-moc unter FreeBSD 7.2 (amd64). Ich erhalte beim Bau folgende Fehlermeldungen:
===>  Extracting for qt4-moc-4.5.2
=> MD5 Checksum OK for KDE/qt-x11-opensource-src-4.5.2.tar.gz.
=> SHA256 Checksum OK for KDE/qt-x11-opensource-src-4.5.2.tar.gz.
===>  Patching for qt4-moc-4.5.2
===>   qt4-moc-4.5.2 depends on package: qt4-qmake>=4.5.2 - found
===>  Configuring for qt4-moc-4.5.2
/bin/cp /usr/ports/devel/qt4-moc/../../devel/qt4/files/configure /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/src/tools/moc/../../../
/usr/bin/sed -i.bak -e 's|target.path.*|target.path=/usr/local/bin|g'  -e 's|^TARGET.*|TARGET=moc-qt4|g'  /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/src/tools/moc/moc.pro
/bin/mkdir -p /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/src/tools/moc/../../../mkspecs
/bin/ln -sf /usr/local/bin/qmake-qt4 /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/src/tools/moc/../../../bin/qmake
This is the Qt/X11 Open Source Edition.
You are licensed to use this software under the terms of
the GNU General Public License (GPL) versions 3.
You are also licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You have already accepted the terms of the  license.
/usr/local/share/qt4/mkspecs/freebsd-g++/qmake.conf:50: Parse Error ('include(../common/usr/local/bin/ccache c++')
Failure to read QMAKESPEC conf file /usr/local/share/qt4/mkspecs/freebsd-g++/qmake.conf.
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/floatmath/floatmath.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/mmx/mmx.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/3dnow/3dnow.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/sse/sse.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/sse2/sse2.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/db2/db2.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/ibase/ibase.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/mysql_r/mysql_r.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/mysql/mysql.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/oci/oci.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/odbc/odbc.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/psql/psql.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/sqlite2/sqlite2.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/tds/tds.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/nis/nis.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/cups/cups.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/iconv/iconv.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/gnu-libiconv/gnu-libiconv.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/dbus/dbus.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/glib/glib.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/opengl/opengl.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/opengles2/opengles2.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/opengles1/opengles1.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/opengles1cl/opengles1cl.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xcursor/xcursor.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xfixes/xfixes.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xrandr/xrandr.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xrender/xrender.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/mitshm/mitshm.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/fontconfig/fontconfig.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/sm/sm.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xshape/xshape.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xinerama/xinerama.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xinput/xinput.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/x11/xkb/xkb.pro
Error processing project file: /usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/config.tests/unix/freetype/freetype.pro
The target system byte order could not be detected!
Turn on verbose messaging (-v) to see the final report.
You can use the -little-endian or -big-endian switch to
./configure to continue.
===>  Script "configure" failed unexpectedly.
Please report the problem to kde@FreeBSD.org [maintainer] and attach the
"/usr/ports/devel/qt4-moc/work/qt-x11-opensource-src-4.5.2/src/tools/moc/../../..//config.log"
including the output of the failure of your make command. Also, it might be
a good idea to provide an overview of all packages installed on your system
(e.g. an `ls /var/db/pkg`).
*** Error code 1
Stop in /usr/ports/devel/qt4-moc.
Ich bin ziemlich ratlos was ich noch tun kann. Meine bisherigen Versuche:
* ich habe ich meine make.conf bis auf den Eintrag von Perl und die Definiton des distfile-Verzeichnisses geleert
* ich habe alle Shell-Variablen ccache betreffend entfernt
* ich habe in der Datei /usr/local/share/qt4/mkspecs/freebsd-g++/qmake.conf die ccache betreffende Zeile auskommentiert und erhalte nun folgende Meldung:
*** Error code 1
Jetzt bin aber mit meinem Latein am Ende. Ich hoffe ihr noch nicht und jemand kann mir helfen.
Danke und Gruß
c.
[solved]
Hab das Problem gefunden. Irgendwie war mein Port devel/qmake4 zerdengelt. Ich habe den Port neugebaut, deinstalliert und dann installiert und dann konnte ich devel/qt4-moc bauen.
c.
