Probleme mit soundjuicer
cabriofahrer
Nummerierung von SCSI-Emulation von CD-Laufwerken ändert sich willkürlich
Habe FreeBSD 6.0 und SCSI-Emulation für die CD-Laufwerke mittels Eintrag
atapicam_load="YES"
in der loader.conf.
Hier die dmesg:
$ dmesg
Copyright (c) 1992-2005 The FreeBSD Project.
FreeBSD 6.0-RELEASE #0: Thu Nov 3 09:36:13 UTC 2005
root@x64.samsco.home:/usr/obj/usr/src/sys/GENERIC
CPU: AMD Athlon(tm) processor (1000.02-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x642 Stepping = 2
Features=0x183f9ff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR>
AMD Features=0xc0440800<SYSCALL,<b18>,MMX+,3DNow+,3DNow>
real memory = 536805376 (511 MB)
avail memory = 511774720 (488 MB)
npx0: [FAST]
npx0: INT 16 interface
acpi0: <VT8363 AWRDACPI> on motherboard
acpi0: Power Button (fixed)
pci_link0: <ACPI PCI Link LNKA> irq 10 on acpi0
pci_link1: <ACPI PCI Link LNKB> irq 5 on acpi0
pci_link2: <ACPI PCI Link LNKC> irq 11 on acpi0
pci_link3: <ACPI PCI Link LNKD> irq 9 on acpi0
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
cpu0: <ACPI CPU> on acpi0
acpi_throttle0: <ACPI CPU Throttling> on cpu0
acpi_button1: <Sleep Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff,0x4000-0x407f,0x4080-0x40ff,0x5000-0x500f,0x6000-0x607f on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <PCI-PCI bridge> at device 1.0 on pci0
pci1: <PCI bus> on pcib1
nvidia0: <GeForce3 Ti 200> mem 0xe0000000-0xe0ffffff,0xd8000000-0xdbffffff,0xdc000000-0xdc07ffff irq 10 at device 0.0 on pci1
nvidia0: [GIANT-LOCKED]
isab0: <PCI-ISA bridge> at device 7.0 on pci0
isa0: <ISA bus> on isab0
atapci0: <VIA 82C686B UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xd000-0xd00f at device 7.1 on pci0
atapci0: Correcting VIA config for southbridge data corruption bug
ata0: <ATA channel 0> on atapci0
ata1: <ATA channel 1> on atapci0
uhci0: <VIA 83C572 USB controller> port 0xd400-0xd41f irq 11 at device 7.2 on pci0
uhci0: [GIANT-LOCKED]
usb0: <VIA 83C572 USB controller> on uhci0
usb0: USB revision 1.0
uhub0: VIA UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhci1: <VIA 83C572 USB controller> port 0xd800-0xd81f irq 11 at device 7.3 on pci0
uhci1: [GIANT-LOCKED]
usb1: <VIA 83C572 USB controller> on uhci1
usb1: USB revision 1.0
uhub1: VIA UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
pcm0: <Creative EMU10K1> port 0xe000-0xe01f irq 5 at device 10.0 on pci0
pcm0: <TriTech TR28602 AC97 Codec>
rl0: <RealTek 8139 10/100BaseTX> port 0xe800-0xe8ff mem 0xe2000000-0xe20000ff irq 11 at device 11.0 on pci0
miibus0: <MII bus> on rl0
rlphy0: <RealTek internal media interface> on miibus0
rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
rl0: Ethernet address: 00:30:84:3d:fa:d1
fdc0: <floppy drive controller> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
fdc0: [FAST]
sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
sio0: type 16550A
sio1: <16550A-compatible COM port> port 0x2f8-0x2ff irq 3 on acpi0
sio1: type 16550A
ppc0: <ECP parallel printer port> port 0x378-0x37f,0x778-0x77b irq 7 drq 3 on acpi0
ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
ppc0: FIFO with 16/16/8 bytes threshold
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: [GIANT-LOCKED]
psm0: model MouseMan+, device ID 0
pmtimer0 on isa0
Timecounter "TSC" frequency 1000019925 Hz quality 800
ad0: 76319MB <WDC WD800JB-00FMA0 13.03G13> at ata0-master UDMA100
acd0: DVDROM <Pioneer DVD-ROM ATAPIModel DVD-106S 0122/E1.22> at ata1-master UDMA66
acd1: CDRW <LITE-ON LTR-40125S/ZS0R> at ata1-slave UDMA33
Trying to mount root from ufs:/dev/ad0s1a
cd0 at ata1 bus 0 target 0 lun 0
cd0: <PIONEER DVD-ROM DVD-106 1.22> Removable CD-ROM SCSI-0 device
cd0: 66.000MB/s transfers
cd0: Attempt to query device size failed: NOT READY, Medium not present
cd1 at ata1 bus 0 target 1 lun 0
cd1: <LITE-ON LTR-40125S ZS0R> Removable CD-ROM SCSI-0 device
cd1: 33.000MB/s transfers
cd1: Attempt to query device size failed: NOT READY, Medium not present
rl0: link state changed to UP
Hier ist es korrekt, denn acd0 entspricht hier cd0 (Pioneer-Laufwerk) und acd1 cd1 (Lite-ON Brenner)
Doch manchmal bekomme ich das Pioneer Laufwerk als cd1 (obwohl acd0) und das Lite-On als cd0 (obwohl acd1), das passiert manchmal völlig willkürlich und führt dann dazu, daß Soundjuicer und alle anderen Gnome-Multimediaanwendungen dann kein Laufwerk erkennen, denn diese erkennen nur SCSI-Laufwerke, so ist gnome eben konzipiert.
1. Was ist da los?
2. Dummerweise funktioniert alles nur, wenn der Rechner "falsch gebootet hat", weil ich das nie bemerkt hatte, also Pioneer ist acd0 und cd1 und Lite-On ist acd1 und cd0. Wie kann ich den Gnome-Anwendungen mitteilen, welche Konstellation die richtige ist (acd0=cd0=Pioneer, acd1=cd1=Lite-On), bzw. wie kann ich bei korrekter Konstellation die Gnome-Anwendungen dafür neu konfigurieren?
