#dmesg
Copyright (c) 1992-2007 The FreeBSD Project.
FreeBSD 6.2-RELEASE-p4 #0: Thu Apr 26 17:40:53 UTC 2007
root@i386-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC
CPU: Intel(R) Pentium(R) M processor 1400MHz (599.49-MHz 686-class CPU)
Origin = "GenuineIntel" Id = 0x695 Stepping = 5
Features=0xa7e9f9bf<FPU,VME,DE,PSE,TSC,MSR,MCE,CX8,SEP,MTRR,PGE,MCA,CMOV,PAT,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,TM,PBE>
Features2=0x180<EST,TM2>
real memory = 1073020928 (1023 MB)
avail memory = 1040674816 (992 MB)
kbd1 at kbdmux0
ath_hal: 0.9.17.2 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413)
acpi0: <IBM TP-1Q> on motherboard
acpi_ec0: <Embedded Controller: GPE 0x1c, ECDT> port 0x62,0x66 on acpi0
acpi0: Power Button (fixed)
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1008-0x100b on acpi0
cpu0: <ACPI CPU> on acpi0
acpi_perf0: <ACPI CPU Frequency Control> on cpu0
acpi_throttle0: <ACPI CPU Throttling> on cpu0
acpi_lid0: <Control Method Lid Switch> on acpi0
acpi_button0: <Sleep Button> on acpi0
pci0: <ACPI PCI bus> on pcib0
agp0: <Intel 82855 host to AGP bridge> mem 0xd0000000-0xdfffffff at device 0.0 on pci0
pci1: <ACPI PCI bus> on pcib1
uhci0: <Intel 82801DB (ICH4) USB controller USB-A> port 0x1800-0x181f irq 11 at device 29.0 on pci0
uhci0: [GIANT-LOCKED]
usb0: <Intel 82801DB (ICH4) USB controller USB-A> on uhci0
usb0: USB revision 1.0
uhci1: <Intel 82801DB (ICH4) USB controller USB-B> port 0x1820-0x183f irq 11 at device 29.1 on pci0
uhci1: [GIANT-LOCKED]
usb1: <Intel 82801DB (ICH4) USB controller USB-B> on uhci1
usb1: USB revision 1.0
uhub1: Intel UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhci2: <Intel 82801DB (ICH4) USB controller USB-C> port 0x1840-0x185f irq 11 at device 29.2 on pci0
uhci2: [GIANT-LOCKED]
usb2: <Intel 82801DB (ICH4) USB controller USB-C> on uhci2
usb2: USB revision 1.0
uhub2: Intel UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
ehci0: <Intel 82801DB/L/M (ICH4) USB 2.0 controller> mem 0xc0000000-0xc00003ff irq 11 at device 29.7 on pci0
ehci0: [GIANT-LOCKED]
usb3: EHCI version 1.0
usb3: companion controllers, 2 ports each: usb0 usb1 usb2
usb3: <Intel 82801DB/L/M (ICH4) USB 2.0 controller> on ehci0
usb3: USB revision 2.0
uhub3: Intel EHCI root hub, class 9/0, rev 2.00/1.00, addr 1
uhub3: 6 ports with 6 removable, self powered
pcib2: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci2: <ACPI PCI bus> on pcib2
cbb0: <RF5C476 PCI-CardBus Bridge> mem 0xb0000000-0xb0000fff irq 11 at device 0.0 on pci2
cbb1: <RF5C476 PCI-CardBus Bridge> mem 0xb1000000-0xb1000fff irq 5 at device 0.1 on pci2
cardbus1: <CardBus bus> on cbb1
pccard1: <16-bit PCCard bus> on cbb1
fwohci0: <Ricoh R5C552> mem 0xc0202000-0xc02027ff irq 11 at device 0.2 on pci2
fwohci0: OHCI version 1.0 (ROM=0)
fwohci0: No. of Isochronous channels is 4.
fwohci0: EUI64 00:06:1b:03:10:01:0d:b1
fwohci0: Phy 1394a available S400, 2 ports.
if_fwe0: Fake Ethernet address: 02:06:1b:01:0d:b1
fwe0: Ethernet address: 02:06:1b:01:0d:b1
fwe0: if_start running deferred for Giant
fwohci0: Initiate bus reset
fwohci0: node_id=0xc800ffc0, gen=1, CYCLEMASTER mode
firewire0: bus manager 0 (me)
iwi0: <Intel(R) PRO/Wireless 2200BG> mem 0xc0200000-0xc0200fff irq 11 at device 2.0 on pci2
iwi0: Ethernet address: 00:16:6f:b7:9a:d7
fxp0: <Intel 82801DB (ICH4) Pro/100 VE Ethernet> port 0x8000-0x803f mem 0xc0201000-0xc0201fff irq 11 at device 8.0 on pci2
miibus0: <MII bus> on fxp0
inphy0: <i82562ET 10/100 media interface> on miibus0
inphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
fxp0: Ethernet address: 00:09:6b:fa:ad:aa
isa0: <ISA bus> on isab0
atapci0: <Intel ICH4 UDMA100 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0x1860-0x186f at device 31.1 on pci0
ata0: <ATA channel 0> on atapci0
ata1: <ATA channel 1> on atapci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
pcm0: <Intel ICH4 (82801DB)> port 0x1c00-0x1cff,0x18c0-0x18ff mem 0xc0000c00-0xc0000dff,0xc0000800-0xc00008ff irq 5 at device 31.5 on pci0
pcm0: <Analog Devices AD1981B AC97 Codec>
pci0: <simple comms, generic modem> at device 31.6 (no driver attached)
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
psm0: [GIANT-LOCKED]
psm0: model Generic PS/2 mouse, device ID 0
fdc0: <floppy drive controller (FDE)> port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on acpi0
fdc0: [FAST]
sio0: configured irq 4 not in bitmap of probed irqs 0
sio0: port may not be enabled
sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
sio0: type 8250 or not responding
ppc0: <Standard parallel printer port> port 0x3bc-0x3be irq 7 on acpi0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
sio1: port may not be enabled
battery0: <ACPI Control Method Battery> on acpi0
battery1: <ACPI Control Method Battery> on acpi0
acpi_acad0: <AC Adapter> on acpi0
acpi_ibm0: <IBM ThinkPad ACPI Extras> on acpi0
pmtimer0 on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xcffff,0xd0000-0xd0fff,0xd1000-0xd1fff,0xdc000-0xdffff,0xe0000-0xeffff on isa0
Timecounter "TSC" frequency 599493502 Hz quality 800
ad0: 152627MB <SAMSUNG HM160JC AP100-16> at ata0-master UDMA100
acd0: DVDR <SONY DVD RW DW-Q58A/1.11> at ata1-master UDMA33
Trying to mount root from ufs:/dev/ad0s4a
drm0: <ATI Radeon LY RV100 Mobility M6> port 0x3000-0x30ff mem 0xe0000000-0xe7ffffff,0xc0100000-0xc010ffff irq 11 at device 0.0 on pci1
info: [drm] AGP at 0xd0000000 256MB
info: [drm] Initialized radeon 1.24.0 20060225
info: [drm] Setting GART location based on old memory map
info: [drm] writeback test succeeded in 1 usecs
