# login.conf - login class capabilities database.
# Remember to rebuild the database after each change to this file:
# cap_mkdb /etc/login.conf
# This file controls resource limits, accounting limits and
# default user environment settings.
# $FreeBSD: releng/10.1/etc/login.conf 246002 2013-01-27 21:55:01Z neel $
# Default settings effectively disable resource limits, see the
# examples below for a starting point to enable them.
# defaults
# These settings are used by login(1) by default for classless users
# Note that entries like "cputime" set both "cputime-cur" and "cputime-max"
# Note that since a colon ':' is used to separate capability entries,
# a \c escape sequence must be used to embed a literal colon in the
# value or name of a capability (see the ``CGETNUM AND CGETSTR SYNTAX
# AND SEMANTICS'' section of getcap(3) for more escape sequences).
default:\
:passwd_format=sha512:\
:copyright=/etc/COPYRIGHT:\
:welcome=/etc/motd:\
:setenv=MAIL=/var/mail/$,BLOCKSIZE=K:\
:path=/sbin /bin /usr/sbin /usr/bin /usr/games /usr/local/sbin /usr/local/bin ~/bin:\
:nologin=/var/run/nologin:\
:cputime=unlimited:\
:datasize=unlimited:\
:stacksize=unlimited:\
:memorylocked=64K:\
:memoryuse=unlimited:\
:filesize=unlimited:\
:coredumpsize=unlimited:\
:openfiles=unlimited:\
:maxproc=unlimited:\
:sbsize=unlimited:\
:vmemoryuse=unlimited:\
:swapuse=unlimited:\
:pseudoterminals=unlimited:\
:priority=0:\
:ignoretime@:\
:umask=022:
# A collection of common class names - forward them all to 'default'
# (login would normally do this anyway, but having a class name
# here suppresses the diagnostic)
standard:\
:tc=default:
xuser:\
:tc=default:
staff:\
:tc=default:
daemon:\
:memorylocked=128M:\
:tc=default:
news:\
:tc=default:
dialer:\
:tc=default:
# Root can always login
# N.B. login_getpwclass(3) will use this entry for the root account,
# in preference to 'default'.
root:\
:ignorenologin:\
:memorylocked=unlimited:\
:tc=default:
# Russian Users Accounts. Setup proper environment variables.
russian|Russian Users Accounts:\
:charset=KOI8-R:\
:lang=ru_RU.KOI8-R:\
:tc=default:
## Example entries
## Example defaults
## These settings are used by login(1) by default for classless users
## Note that entries like "cputime" set both "cputime-cur" and "cputime-max"
#default:\
# :cputime=infinity:\
# :datasize-cur=22M:\
# :stacksize-cur=8M:\
# :memorylocked-cur=10M:\
# :memoryuse-cur=30M:\
# :filesize=infinity:\
# :coredumpsize=infinity:\
# :maxproc-cur=64:\
# :openfiles-cur=64:\
# :priority=0:\
# :requirehome@:\
# :umask=022:\
# :tc=auth-defaults:
## standard - standard user defaults
#standard:\
# :copyright=/etc/COPYRIGHT:\
# :welcome=/etc/motd:\
# :setenv=MAIL=/var/mail/$,BLOCKSIZE=K:\
# :path=~/bin /bin /usr/bin /usr/local/bin:\
# :manpath=/usr/share/man /usr/local/man:\
# :nologin=/var/run/nologin:\
# :cputime=1h30m:\
# :datasize=8M:\
# :vmemoryuse=100M:\
# :stacksize=2M:\
# :memorylocked=4M:\
# :memoryuse=8M:\
# :filesize=8M:\
# :coredumpsize=8M:\
# :openfiles=24:\
# :maxproc=32:\
# :priority=0:\
# :requirehome:\
# :passwordtime=90d:\
# :umask=002:\
# :ignoretime@:\
# :tc=default:
## users of X (needs more resources!)
#xuser:\
# :cputime=4h:\
# :datasize=12M:\
# :vmemoryuse=infinity:\
# :stacksize=4M:\
# :filesize=8M:\
# :memoryuse=16M:\
# :openfiles=32:\
# :maxproc=48:\
# :tc=standard:
## Staff users - few restrictions and allow login anytime
#staff:\
# :ignorenologin:\
# :ignoretime:\
# :requirehome@:\
# :accounted@:\
# :path=~/bin /bin /sbin /usr/bin /usr/sbin /usr/local/bin /usr/local/sbin:\
# :umask=022:\
# :tc=standard:
## root - fallback for root logins
#root:\
# :datasize=infinity:\
# :stacksize=infinity:\
# :memorylocked=infinity:\
# :memoryuse=infinity:\
# :openfiles=infinity:\
# :maxproc=infinity:\
# :memoryuse-cur=32M:\
# :maxproc-cur=64:\
# :openfiles-cur=1024:\
# :priority=0:\
# :requirehome@:\
# :umask=022:\
# :tc=auth-root-defaults:
## Settings used by /etc/rc
#daemon:\
# :coredumpsize@:\
# :coredumpsize-cur=0:\
# :datasize-cur@:\
# :maxproc=512:\
# :maxproc-cur@:\
# :memoryuse-cur=64M:\
# :memorylocked-cur=64M:\
# :openfiles=1024:\
# :openfiles-cur@:\
# :stacksize=16M:\
# :stacksize-cur@:\
# :tc=default:
## Settings used by news subsystem
#news:\
# :path=/usr/local/news/bin /bin /sbin /usr/bin /usr/sbin /usr/local/bin /usr/local/sbin:\
# :filesize=128M:\
# :datasize-cur=64M:\
# :stacksize-cur=32M:\
# :maxmemorysize-cur=128M:\
# :memorylocked=32M:\
# :maxproc=128:\
# :openfiles=256:\
# :tc=default:
## The dialer class should be used for a dialup PPP account
## Welcome messages/news suppressed
#dialer:\
# :hushlogin:\
# :requirehome@:\
# :cputime=unlimited:\
# :filesize=2M:\
# :datasize=2M:\
# :stacksize=4M:\
# :coredumpsize=0:\
# :memoryuse=4M:\
# :memorylocked=1M:\
# :maxproc=16:\
# :openfiles=32:\
# :tc=standard:
## Site full-time 24/7 PPP connection
## - no time accounting, restricted to access via dialin lines
#site:\
# :ignoretime:\
# :passwordtime@:\
# :refreshtime@:\
# :refreshperiod@:\
# :sessionlimit@:\
# :autodelete@:\
# :expireperiod@:\
# :graceexpire@:\
# :gracetime@:\
# :warnexpire@:\
# :warnpassword@:\
# :idletime@:\
# :sessiontime@:\
# :daytime@:\
# :weektime@:\
# :monthtime@:\
# :warntime@:\
# :accounted@:\
# :tc=dialer:\
# :tc=staff:
## Example standard accounting entries for subscriber levels
#subscriber|Subscribers:\
# :accounted:\
# :refreshtime=180d:\
# :refreshperiod@:\
# :sessionlimit@:\
# :autodelete=30d:\
# :expireperiod=180d:\
# :graceexpire=7d:\
# :gracetime=10m:\
# :warnexpire=7d:\
# :warnpassword=7d:\
# :idletime=30m:\
# :sessiontime=4h:\
# :daytime=6h:\
# :weektime=40h:\
# :monthtime=120h:\
# :warntime=4h:\
# :tc=standard:
## Subscriber accounts. These accounts have their login times
## accounted and have access limits applied.
#subppp|PPP Subscriber Accounts:\
# :tc=dialer:\
# :tc=subscriber:
#subshell|Shell Subscriber Accounts:\
# :tc=subscriber:
## If you want some of the accounts to use traditional UNIX DES based
## password hashes.
#des_users:\
# :passwd_format=des:\
# :tc=default:
german|German User Accounts:\
:charset=UTF-8:\
:lang=de_DE.UTF-8:\
:tc=default:
