USB3-Controller wird gefunden, aber plötzlich getrennt
mod3
Themenstarter #1
Hallo zusammen,
habe mir einen neuen USB3-Controller per PCI-E besorgt, der über Molex mit Strom versorgt wird.
Die angeschlossenen Platten findet er problemlos, plötzlich sind diese im System dann aber wieder verschwunden...
Könnt ihr mir helfen?
kernel:GEOM_ELI:g_eli_read_done()failed(error=5)da0.eli[READ(offset=270336,length=8192)]
kernel:(da0:umass-sim0:0:0:0):READ(10).CDB:28007470681000
kernel:(da0:umass-sim0:0:0:0):CAMstatus:CCBrequestcompletedwithanerror
kernel:(da0:umass-sim0:0:0:0):Retryingcommand,3moretriesremain
kernel:(da0:umass-sim0:0:0:0):Retryingcommand,2moretriesremain
kernel:(da0:umass-sim0:0:0:0):Retryingcommand,1moretriesremain
kernel:(da0:umass-sim0:0:0:0):Retryingcommand,0moretriesremain
kernel:(da0:umass-sim0:0:0:0):Error5,Retriesexhausted
kernel:GEOM_ELI:g_eli_read_done()failed(error=5)da0.eli[READ(offset=1000204410880,length=8192)]
kernel:GEOM_ELI:g_eli_read_done()failed(error=5)da0.eli[READ(offset=1000204148736,length=8192)]
kernel:da0atumass-sim0bus0scbus7target0lun0
kernel:da0:<WDCWD10EADS-00L5B101.0>detached
kernel:GEOM_ELI:g_eli_write_done()failed(error=6)da0.eli[WRITE(offset=730545770496,length=1048576)]
kernel:GEOM_ELI:Deviceda0.elidestroyed.
kernel:GEOM_ELI:Detachedda0.elionlastclose.
kernel:(da0:umass-sim0:0:0:0):Periphdestroyed
kernel:umass0:detached
kernel:ugen4.3:<ASMediaAS2105>atusbus4
kernel:umass0onuhub1
kernel:umass0:<ASMediaAS2105,class0/0,rev3.00/0.01,addr2>on
kernel:umass0:SCSIoverBulk-Only;quirks=0xc100
kernel:umass0:7:0:Attachedtoscbus7
kernel:ugen4.3:<ASMediaAS2105>atusbus4(disconnected)
kernel:umass0:atuhub1,port5,addr2(disconnected)
kernel:(probe0:umass-sim0:0:0:0):REPORTLUNS.CDB:a00000000000
kernel:(probe0:umass-sim0:0:0:0):CAMstatus:CCBrequestcompletedwithanerror
kernel:(probe0:umass-sim0:0:0:0):Retryingcommand,4moretriesremain
kernel:(probe0:umass-sim0:0:0:0):Retryingcommand,3moretriesremain
kernel:(probe0:umass-sim0:0:0:0):Retryingcommand,2moretriesremain
kernel:(probe0:umass-sim0:0:0:0):Retryingcommand,1moretriesremain
kernel:(probe0:umass-sim0:0:0:0):Retryingcommand,0moretriesremain
kernel:(probe0:umass-sim0:0:0:0):Error5,Retriesexhausted
kernel:(da0:umass-sim0:0:0:0):gotCAMstatus0x44
kernel:(da0:umass-sim0:0:0:0):fatalerror,failedtoattachtodevice
kernel:g_access(958):providerda0haserror6set
syslogd:lastmessagerepeated3times
kernel:(probe0:umass-sim0:0:0:0):CAMstatus:SCSIStatusError
kernel:(probe0:umass-sim0:0:0:0):SCSIstatus:CheckCondition
kernel:(probe0:umass-sim0:0:0:0):SCSIsense:ILLEGALREQUESTasc:20,0(Invalidcommandoperationcode)
kernel:(probe0:umass-sim0:0:0:0):Error22,Unretryableerror
kernel:da0:<WDCWD10EADS-00L5B101.0>FixedDirectAccessSPC-3SCSI
kernel:da0:400.000MB/stransfers
kernel:da0:953869MB(1953525168512bytesectors)
kernel:da0:quirks=0x2<NO_6_BYTE>
kernel:umass0:<ASMediaAS2105,class0/0,rev2.10/0.01,addr2>on
kernel:usbd_req_re_enumerate:addr=2,setaddressfailed!(USB_ERR_IOERROR,ignored)
kernel:usbd_setup_device_desc:gettingdevicedescriptorataddr2failed,USB_ERR_IOERROR
kernel:usb_alloc_device:Failureselectingconfigurationindex0:USB_ERR_IOERROR,port5,addr2
mod3
Themenstarter #4
Ja, habe den Adapter drin gelassen, aber mal den Rahmen getauscht, in dem die externe Festplatte saß (also selbe Platte, aber anderer Rahmen) und siehe da: läuft.
Ist das ne BSD-Sache, oder einfach ne Inkompatibilität der Chips? Denn an nem Linux-Rechner funktioniert der "defekte" Rahmen wunderbar.
