vgapci0: Boot video device
[drm] amdgpu kernel modesetting enabled.
drmn0: <drmn> on vgapci0
vgapci0: child drmn0 requested pci_enable_io
[drm] initializing kernel modesetting (KABINI 0x1002:0x9833 0x1734:0x1202 0x00).
[drm] register mmio base: 0xFEB00000
[drm] register mmio size: 262144
[drm] PCI I/O BAR is not found.
[drm] probing mlw for device 1002:9833 = 0
[drm] BIOS signature incorrect 0 0
[drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
drmn0: VRAM: 32M 0x0000000F00000000 - 0x0000000F01FFFFFF (32M used)
drmn0: GTT: 1024M 0x0000001000000000 - 0x000000103FFFFFFF
[drm] Detected VRAM RAM=32M, BAR=32M
[drm] RAM width 64bits UNKNOWN
[drm] amdgpu: 32M of VRAM memory ready
[drm] amdgpu: 3072M of GTT memory ready.
[drm] GART: num cpu pages 262144, num gpu pages 262144
[drm] PCIE GART of 1024M enabled (table at 0x0000000F00040000).
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] Driver supports precise vblank timestamp query.
[drm] Internal thermal controller without fan control
[drm] amdgpu: dpm initialized
[drm] Connector DP-1: get mode from tunables:
[drm] - kern.vt.fb.modes.DP-1
[drm] - kern.vt.fb.default_mode
[drm] Connector DVI-I-1: get mode from tunables:
[drm] - kern.vt.fb.modes.DVI-I-1
[drm] AMDGPU Display Connectors
[drm] Connector 0:
[drm] DP-1
[drm] HPD1
[drm] DDC: 0x194c 0x194c 0x194d 0x194d 0x194e 0x194e 0x194f 0x194f
[drm] Encoders:
[drm] DFP1: INTERNAL_UNIPHY
[drm] Connector 1:
[drm] DVI-I-1
[drm] HPD2
[drm] DDC: 0x1950 0x1950 0x1951 0x1951 0x1952 0x1952 0x1953 0x1953
[drm] Encoders:
[drm] DFP2: INTERNAL_UNIPHY
[drm] CRT1: INTERNAL_KLDSCP_DAC1
drmn0: successfully loaded firmware image with name: radeon/kabini_pfp.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_me.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_ce.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_mec.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_rlc.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_sdma.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_sdma1.bin
drmn0: successfully loaded firmware image with name: radeon/kabini_uvd.bin
[drm] Found UVD firmware Version: 1.64 Family ID: 9
drmn0: successfully loaded firmware image with name: radeon/kabini_vce.bin
[drm] Found VCE firmware Version: 50.10 Binary ID: 2
[drm] UVD initialized successfully.
[drm] VCE initialized successfully.
[drm] fb mappable at 0xDE428000
[drm] vram apper at 0xDE000000
[drm] size 1310720
[drm] fb depth is 8
[drm] pitch is 1280
VT: Replacing driver "vga" with new "fb".
name=drmn0 flags=0x0 stride=1280 bpp=8
drmn0: fb0: amdgpudrmfb frame buffer device
[drm] Initialized amdgpu 3.23.0 20150101 for drmn0 on minor 0
VT(vga): resolution 640x480
vtvga0: <VT VGA driver> on motherboard
vgapci0: <VGA-compatible display> port 0xf000-0xf0ff mem 0xf8000000-0xfbffffff,0xfc000000-0xfc7fffff,0xfeb00000-0xfeb3ffff irq 44 at device 1.0 on pci0
[drm] Connector 0:
[drm] DP-1
[drm] HPD1
[drm] Encoders:
[drm] Connector 1:
[drm] DVI-I-1
[drm] HPD2
[drm] Encoders:
[drm] size 1310720
[drm] fb depth is 8
[drm] pitch is 1280
[drm] Connector 0:
[drm] DP-1
[drm] HPD1
[drm] Encoders:
[drm] Connector 1:
[drm] DVI-I-1
[drm] HPD2
[drm] Encoders:
[drm] size 1310720
[drm] fb depth is 8
[drm] pitch is 1280
