# To disable a repository, instead of modifying or removing this file,
# create a /usr/local/etc/pkg/repos/FreeBSD.conf file, e.g.:
# mkdir -p /usr/local/etc/pkg/repos
# echo "FreeBSD-ports: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf
# echo "FreeBSD-ports-kmods: { enabled: no }" >> /usr/local/etc/pkg/repos/FreeBSD.conf
# Note that the FreeBSD-base repository is disabled by default.
FreeBSD-ports: {
url: "pkg+https://pkg.FreeBSD.org/${ABI}/latest",
ip_version: 6,
enabled: yes
ip_version: 6,
enabled: no
FreeBSD-base: {
ip_version: 6,
enabled: no
pkg install -f ksh
Updating FreeBSD-ports repository catalogue...
FreeBSD-ports repository is up to date.
All repositories are up to date.
Checking integrity... done (0 conflicting)
The following 8 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
binutils: 2.44,1
gcc12-devel: 12.4.1.s20250702
gmp: 6.3.0
indexinfo: 0.3.1_1
mpc: 1.3.1_1
mpfr: 4.2.2,1
zstd: 1.5.7_1
Installed packages to be REINSTALLED:
ksh-1.0.10
Number of packages to be installed: 7
Number of packages to be reinstalled: 1
The process will require 486 MiB more space.
Proceed with this action? [y/N]:
FreeBSD-acct-15.0 System resource accounting
FreeBSD-at-15.0 Scheduled and batch command utilities
FreeBSD-atf-15.0 Automated Testing Framework
FreeBSD-atf-dev-15.0 Automated Testing Framework (development files)
FreeBSD-atf-lib-15.0 Automated Testing Framework (libraries)
FreeBSD-audit-15.0 OpenBSM auditing utilities
FreeBSD-audit-dev-15.0 OpenBSM auditing utilities (development files)
FreeBSD-audit-lib-15.0 OpenBSM auditing utilities (libraries)
FreeBSD-autofs-15.0 File system automounter
FreeBSD-bhyve-15.0 bhyve virtual machine hypervisor
FreeBSD-blocklist-15.0 Network blocklist daemon
FreeBSD-blocklist-dev-15.0 Network blocklist daemon (development files)
FreeBSD-bluetooth-15.0 Bluetooth support
FreeBSD-bluetooth-dev-15.0 Bluetooth support (development files)
FreeBSD-bluetooth-lib-15.0 Bluetooth support (libraries)
FreeBSD-bmake-15.0 Program maintenance utility
FreeBSD-bootloader-15.0 System boot loader
FreeBSD-bootloader-dev-15.0 System boot loader (development files)
FreeBSD-bsdconfig-15.0 System configuration utility
FreeBSD-bsdinstall-15.0 System installer
FreeBSD-bsnmp-15.0 Simple and extensible SNMP daemon
FreeBSD-bsnmp-dev-15.0 Simple and extensible SNMP daemon (development files)
FreeBSD-bzip2-15.0 A block-sorting data compressor
FreeBSD-bzip2-dev-15.0 A block-sorting data compressor (development files)
FreeBSD-bzip2-lib-15.0 A block-sorting data compressor (libraries)
FreeBSD-caroot-15.0 Mozilla Root Store trusted TLS certificates
FreeBSD-certctl-15.0 Tool for managing trusted and untrusted TLS certificates
FreeBSD-clang-15.0 The Clang C, C++, and Objective-C compiler
FreeBSD-clang-dev-15.0 The Clang C, C++, and Objective-C compiler (development files)
FreeBSD-clibs-15.0 Core runtime libraries
FreeBSD-clibs-dev-15.0 Core runtime libraries (development files)
FreeBSD-cron-15.0 Command scheduling facility
FreeBSD-csh-15.0 C shell with file name completion and command line editing
FreeBSD-ctf-15.0 Compact C Type Format (CTF)
FreeBSD-ctf-dev-15.0 Compact C Type Format (CTF) (development files)
FreeBSD-ctf-lib-15.0 Compact C Type Format (CTF) (libraries)
FreeBSD-devd-15.0 Kernel event handling daemon
FreeBSD-devmatch-15.0 Automatically load kernel drivers for attached hardware
FreeBSD-devmatch-dev-15.0 Automatically load kernel drivers for attached hardware (development files)
FreeBSD-dhclient-15.0 Dynamic Host Configuration Protocol (DHCP) client
FreeBSD-diff3-15.0 GNU 3-way file comparison and merge utility
FreeBSD-dma-15.0 DragonFly Mail Agent
FreeBSD-dtrace-15.0 DTrace dynamic tracing framework
FreeBSD-dtrace-dev-15.0 DTrace dynamic tracing framework (development files)
FreeBSD-ee-15.0 Easy Editor
FreeBSD-efi-tools-15.0 Utilities for the Unified Extensible Firmware Interface (UEFI)
FreeBSD-efi-tools-dev-15.0 Utilities for the Unified Extensible Firmware Interface (UEFI) (development files)
FreeBSD-examples-15.0 System interface examples
FreeBSD-fetch-15.0 Retrieve a file from a remote URL
FreeBSD-fetch-dev-15.0 Retrieve a file from a remote URL (development files)
FreeBSD-flua-15.0 Private Lua implementation
FreeBSD-flua-dev-15.0 Private Lua implementation (development files)
FreeBSD-ftp-15.0 File Transfer Protocol (FTP) client
FreeBSD-games-15.0 Games
FreeBSD-gssd-15.0 gssd(8) daemon for kernel GSS-API
FreeBSD-inetd-15.0 Internet super-server
FreeBSD-ipf-15.0 IP Filter (ipf) packet filter management tools
FreeBSD-ipfw-15.0 ipfw (IP firewall) management utilities
FreeBSD-jail-15.0 Jail management tools
FreeBSD-kerberos-15.0 Kerberos client
FreeBSD-kerberos-dev-15.0 Kerberos client (development files)
FreeBSD-kerberos-kdc-15.0 Kerberos key distribution center
FreeBSD-kerberos-lib-15.0 Kerberos client (libraries)
FreeBSD-kernel-man-15.0 Kernel manual pages
FreeBSD-kyua-15.0 Testing framework for infrastructure software
FreeBSD-lib9p-15.0 9P network protocol library
FreeBSD-lib9p-dev-15.0 9P network protocol library (development files)
FreeBSD-libarchive-15.0 Library for reading and writing streaming archives
FreeBSD-libarchive-dev-15.0 Library for reading and writing streaming archives (development files)
FreeBSD-libbegemot-15.0 rpoll(3) interface for event-driven I/O
FreeBSD-libbegemot-dev-15.0 rpoll(3) interface for event-driven I/O (development files)
FreeBSD-libblocksruntime-15.0 LLVM BlocksRuntime library
FreeBSD-libblocksruntime-dev-15.0 LLVM BlocksRuntime library (development files)
FreeBSD-libbsdstat-15.0 Periodic statistics library
FreeBSD-libbsdstat-dev-15.0 Periodic statistics library (development files)
FreeBSD-libcasper-15.0 Casper library
FreeBSD-libcasper-dev-15.0 Casper library (development files)
FreeBSD-libcompat-dev-15.0 Compatibility library (development files)
FreeBSD-libcompiler_rt-dev-15.0 LLVM compiler_rt library (development files)
FreeBSD-libcuse-15.0 Userland character device library
FreeBSD-libcuse-dev-15.0 Userland character device library (development files)
FreeBSD-libdwarf-15.0 DWARF access library
FreeBSD-libdwarf-dev-15.0 DWARF access library (development files)
FreeBSD-libevent1-15.0 Private libevent1 library
FreeBSD-libevent1-dev-15.0 Private libevent1 library (development files)
FreeBSD-libexecinfo-15.0 NetBSD stack backtrace library
FreeBSD-libexecinfo-dev-15.0 NetBSD stack backtrace library (development files)
FreeBSD-libipt-15.0 Intel(R) Processor Trace decoder library
FreeBSD-libipt-dev-15.0 Intel(R) Processor Trace decoder library (development files)
FreeBSD-libldns-15.0 Private LDNS library
FreeBSD-libldns-dev-15.0 Private LDNS library (development files)
FreeBSD-libmagic-15.0 Magic number recognition library
FreeBSD-libmagic-dev-15.0 Magic number recognition library (development files)
FreeBSD-libmilter-15.0 sendmail Mail Filter API library
FreeBSD-libmilter-dev-15.0 sendmail Mail Filter API library (development files)
FreeBSD-libpathconv-15.0 Library for handling relative and absolute pathnames
FreeBSD-libpathconv-dev-15.0 Library for handling relative and absolute pathnames (development files)
FreeBSD-librpcsec_gss-15.0 RPCSEC_GSS library
FreeBSD-librpcsec_gss-dev-15.0 RPCSEC_GSS library (development files)
FreeBSD-librss-15.0 Receive-side scaling library
FreeBSD-librss-dev-15.0 Receive-side scaling library (development files)
FreeBSD-libsqlite3-15.0 Private SQLite library
FreeBSD-libsqlite3-dev-15.0 Private SQLite library (development files)
FreeBSD-libthread_db-15.0 Library for interacting with threaded processes
FreeBSD-libthread_db-dev-15.0 Library for interacting with threaded processes (development files)
FreeBSD-libucl-15.0 Private Universal Configuration Library (UCL) library
FreeBSD-libucl-dev-15.0 Private Universal Configuration Library (UCL) library (development files)
FreeBSD-libvgl-15.0 Video Graphics Library
FreeBSD-libvgl-dev-15.0 Video Graphics Library (development files)
FreeBSD-libvmmapi-15.0 Front-end library for the vmm(4) virtualization driver
FreeBSD-libvmmapi-dev-15.0 Front-end library for the vmm(4) virtualization driver (development files)
FreeBSD-libyaml-15.0 Private YAML library
FreeBSD-libyaml-dev-15.0 Private YAML library (development files)
FreeBSD-lld-15.0 LLVM ELF link loader
FreeBSD-lldb-15.0 LLVM debugger
FreeBSD-lldb-dev-15.0 LLVM debugger (development files)
FreeBSD-local-unbound-15.0 NLnet Labs Unbound DNS resolver
FreeBSD-local-unbound-dev-15.0 NLnet Labs Unbound DNS resolver (development files)
FreeBSD-locales-15.0 Locale definitions
FreeBSD-lp-15.0 Print spooler
FreeBSD-mandoc-15.0 Online manual page reader
FreeBSD-mtree-15.0 Filesystem hierarchy management tool
FreeBSD-natd-15.0 Userland Network Address Translation (NAT) for ipfw
FreeBSD-natd-dev-15.0 Userland Network Address Translation (NAT) for ipfw (development files)
FreeBSD-ncurses-15.0 ncurses terminal control library
FreeBSD-ncurses-dev-15.0 ncurses terminal control library (development files)
FreeBSD-ncurses-lib-15.0 ncurses terminal control library (libraries)
FreeBSD-netmap-15.0 Userland netmap support
FreeBSD-netmap-dev-15.0 Userland netmap support (development files)
FreeBSD-newsyslog-15.0 Create and rotate system log files
FreeBSD-nfs-15.0 NFS client and server utilities
FreeBSD-ntp-15.0 Network Time Protocol (NTP) daemon
FreeBSD-openssl-15.0 OpenSSL Transport Layer Security (TLS) library
FreeBSD-openssl-dev-15.0 OpenSSL Transport Layer Security (TLS) library (development files)
FreeBSD-openssl-lib-15.0 OpenSSL Transport Layer Security (TLS) library (libraries)
FreeBSD-periodic-15.0 Run periodic system functions
FreeBSD-pf-15.0 OpenBSD packet filter
FreeBSD-pf-dev-15.0 OpenBSD packet filter (development files)
FreeBSD-pkg-bootstrap-15.0 pkg(7) bootstrap utility
FreeBSD-pmc-15.0 Support for hardware performance counters
FreeBSD-pmc-dev-15.0 Support for hardware performance counters (development files)
FreeBSD-ppp-15.0 Point-to-Point Protocol (PPP) utilities
FreeBSD-quotacheck-15.0 Filesystem quota consistency checker
FreeBSD-rc-15.0 rc(8) subsystem
FreeBSD-rcmds-15.0 BSD/SunOS remote status commands
FreeBSD-rdma-15.0 Remote Direct Memory Access (RDMA) and InfiniBand utilities
FreeBSD-resolvconf-15.0 A framework for managing multiple DNS configurations
FreeBSD-rip-15.0 RIP routing protocol
FreeBSD-runtime-15.0p1 Core system
FreeBSD-runtime-dev-15.0 Core system (development files)
FreeBSD-sendmail-15.0 sendmail mail transport agent
FreeBSD-set-base-jail-15.0 Base system for jails (metapackage)
FreeBSD-set-devel-15.0 Development tools (metapackage)
FreeBSD-set-minimal-jail-15.0 Basic multi-user jail system (metapackage)
FreeBSD-set-optional-jail-15.0 Optional base system software for jails (metapackage)
FreeBSD-smbutils-15.0 SMB network filesystem utilities
FreeBSD-smbutils-dev-15.0 SMB network filesystem utilities (development files)
FreeBSD-sound-15.0 Audio utilities
FreeBSD-sound-dev-15.0 Audio utilities (development files)
FreeBSD-ssh-15.0 OpenSSH Secure Shell client and server
FreeBSD-ssh-dev-15.0 OpenSSH Secure Shell client and server (development files)
FreeBSD-syslogd-15.0 System logging daemon
FreeBSD-tcpd-15.0 TCP Wrappers access control facility
FreeBSD-tcpd-dev-15.0 TCP Wrappers access control facility (development files)
FreeBSD-telnet-15.0 TELNET client
FreeBSD-toolchain-15.0 Utilities for program development
FreeBSD-toolchain-dev-15.0 Utilities for program development (development files)
FreeBSD-ufs-15.0 UFS filesystem support
FreeBSD-ufs-dev-15.0 UFS filesystem support (development files)
FreeBSD-ufs-lib-15.0 UFS filesystem support (libraries)
FreeBSD-utilities-15.0p1 Non-vital programs and libraries
FreeBSD-utilities-dev-15.0 Non-vital programs and libraries (development files)
FreeBSD-vi-15.0 Text editor
FreeBSD-xz-15.0 LZMA2 data compression
FreeBSD-xz-dev-15.0 LZMA2 data compression (development files)
FreeBSD-xz-lib-15.0 LZMA2 data compression (libraries)
FreeBSD-yp-15.0 Yellow Pages (YP) / Network Information Service (NIS)
FreeBSD-zfs-15.0 ZFS filesystem support
FreeBSD-zfs-dev-15.0 ZFS filesystem support (development files)
FreeBSD-zfs-lib-15.0 ZFS filesystem support (libraries)
FreeBSD-zlib-15.0 DEFLATE (gzip) data compression library
FreeBSD-zlib-dev-15.0 DEFLATE (gzip) data compression library (development files)
FreeBSD-zoneinfo-15.0 Timezone database
ksh-1.0.10 ksh93u+m is the renewed development of ksh93 based on AT&T ksh93u+m (stable)
pkg-2.5.1 Package manager
root@test:/ #
This port has no dependencies.RUN_DEPENDS$ pkg info -d ksh
ksh-1.0.10:
gcc12-devel installiert.$ pkg info -d ksh
ksh-1.0.10:
FreeBSD-clibs-15.0 (libc.so.7)
FreeBSD-clibs-15.0 (libm.so.5)
FreeBSD-runtime-15.0p1 (libmd.so.7)
FreeBSD-runtime-15.0p1 (libutil.so.10)
pkg info -d FreeBSD-acct-15.0
FreeBSD-acct-15.0:
FreeBSD-clibs-15.0 (libc++.so.1)
FreeBSD-clibs-15.0 (libcxxrt.so.1)
FreeBSD-clibs-15.0 (libgcc_s.so.1)
FreeBSD-runtime-15.0p1 (libxo.so.0)
FreeBSD-acct-15.0:
gcc12-devel-12.4.1.s20250702 (libgcc_s.so.1)
pkg info -d FreeBSD-libexecinfo
FreeBSD-libexecinfo-15.0:
FreeBSD-runtime-15.0p1 (libelf.so.2)
$ pkg info -d ksh
ksh-1.0.10:
$ pkg info -d FreeBSD-libexecinfo-15.0
$ pkg info -d FreeBSD-acct-15.0
FreeBSD-acct-15.0:
env["ROOTPASS_ENC"] = ROOTPASS_ENC
env["nonInteractive"] = "YES"
env["BSDINSTALL_CHROOT"] = ROOT_PATH
run(["bsdinstall", "pkgbase", "--jail"], env=env)
export ROOT_PATH=/jails/xyz
mkdir -p ${ROOT_PATH}/usr/share/keys
cp -R /usr/share/keys/pkg ${ROOT_PATH}/usr/share/keys/
cp -R /usr/share/keys/pkgbase-15 ${ROOT_PATH}/usr/share/keys/
pkg -r $ROOT_PATH install -y FreeBSD-set-minimal-jail
echo $ROOTPASS_ENCODED | pw -R $ROOT_PATH usermod root -H 0
