Stevil
- 5.2.1 installiert
- auf 5.3Beta4 geupdated
- cvsup für ports gezogen
- dann:
was vergessen/übersehen?
- dann:
192# cd /usr/ports/
192# make index
Generating INDEX-5 - please wait..perl: not found
===> arabic/ae_fonts_mono failed
*** Error code 1
perl: not found
===> accessibility/at-spi failed
*** Error code 1
2 errors
Before reporting this error, verify that you are running a supported
version of FreeBSD (see http://www.FreeBSD.org/ports/) and that you
have a complete and up-to-date ports collection. (INDEX builds are
not supported with partial or out-of-date ports collections -- in
particular, if you are using cvsup, you must cvsup the "ports-all"
collection, and have no "refuse" files.) If that is the case, then
report the failure to ports@FreeBSD.org together with relevant
details of your ports configuration (including FreeBSD version,
your architecture, your environment, and your /etc/make.conf
settings, especially compiler flags and WITH/WITHOUT settings).
Note: the latest pre-generated version of INDEX may be fetched
automatically with "make fetchindex".
*** Error code 1
Stop in /usr/ports.
*** Error code 1
Stop in /usr/ports.
192#
