mousaka
getting older
Ich kann zur Zeit kdelibs4 nicht bauen:
cmake und qt4-* habe ich bereits neu gebaut, leider ohne Erfolg. Optionen gibts für diese Ports keine die evtl. falsch definiert sein könnten.
Jemand einen Tipp?
mousaka
Hier der ganze Output von make build
CMake Error at cmake/modules/FindKDE4Internal.cmake:1098 (message):
Qt compiled without support for -fvisibility=hidden. This will break
plugins and linking of some applications. Please fix your Qt installation.
Jemand einen Tipp?
mousaka
# make build
===> kdelibs-4.3.1_1 depends on file: /usr/local/lib/libhspell.a - found
===> kdelibs-4.3.1_1 depends on executable: bison - found
===> kdelibs-4.3.1_1 depends on package: qt4-corelib>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-dbus>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-gui>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-network>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-opengl>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-qt3support>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-qtestlib>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-script>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-sql>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-svg>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-xml>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-designer>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-phonon>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-assistant>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-qdbusviewer>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-makeqpf>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-imageformats>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-qmake>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-moc>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-rcc>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on package: qt4-uic>=4.5.2 - found
===> kdelibs-4.3.1_1 depends on executable: pkg-config - found
===> kdelibs-4.3.1_1 depends on file: /usr/local/bin/automoc4 - found
===> kdelibs-4.3.1_1 depends on package: kde4-shared-mime-info>=1 - found
===> kdelibs-4.3.1_1 depends on file: /usr/local/bin/cmake - found
===> kdelibs-4.3.1_1 depends on shared library: searchclient - found
===> kdelibs-4.3.1_1 depends on shared library: soprano.4 - found
===> kdelibs-4.3.1_1 depends on shared library: IlmImf - found
===> kdelibs-4.3.1_1 depends on shared library: aspell - found
===> kdelibs-4.3.1_1 depends on shared library: jasper - found
===> kdelibs-4.3.1_1 depends on shared library: pcre - found
===> kdelibs-4.3.1_1 depends on shared library: avahi-core - found
===> kdelibs-4.3.1_1 depends on shared library: enchant.1 - found
===> kdelibs-4.3.1_1 depends on shared library: ungif.5 - found
===> kdelibs-4.3.1_1 depends on shared library: png.5 - found
===> kdelibs-4.3.1_1 depends on shared library: jpeg - found
===> kdelibs-4.3.1_1 depends on shared library: idn - found
===> kdelibs-4.3.1_1 depends on shared library: utempter - found
===> kdelibs-4.3.1_1 depends on shared library: hal.1 - found
===> kdelibs-4.3.1_1 depends on shared library: lzma.0 - found
===> kdelibs-4.3.1_1 depends on shared library: smbclient.0 - found
===> kdelibs-4.3.1_1 depends on shared library: dns_sd - found
===> kdelibs-4.3.1_1 depends on shared library: intl - found
===> kdelibs-4.3.1_1 depends on shared library: xml2.5 - found
===> kdelibs-4.3.1_1 depends on shared library: xslt.2 - found
===> Configuring for kdelibs-4.3.1_1
/usr/bin/sed -i.bak -e 's|/usr/local|/usr/local|g' -e 's|/usr/X11R6|/usr/local|g' /usr/ports/x11/kdelibs4/work/kdelibs-4.3.1/cmake/modules/*.cmake /usr/ports/x11/kdelibs4/work/kdelibs-4.3.1/ConfigureChecks.cmake /usr/ports/x11/kdelibs4/work/kdelibs-4.3.1/doc/api/doxygen.sh
/usr/bin/sed -i.bak -e '/KDE_DEFAULT_HOME/s|.kde|.kde4|' /usr/ports/x11/kdelibs4/work/kdelibs-4.3.1/CMakeLists.txt
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt-Version 4.5.2 (using /usr/local/bin/qmake-qt4)
-- Looking for XOpenDisplay in /usr/local/lib/libX11.so;/usr/local/lib/libXext.so;/usr/local/lib/libXft.so;/usr/local/lib/libXau.so;/usr/local/lib/libXdmcp.so;/usr/local/lib/libXpm.so
-- Looking for XOpenDisplay in /usr/local/lib/libX11.so;/usr/local/lib/libXext.so;/usr/local/lib/libXft.so;/usr/local/lib/libXau.so;/usr/local/lib/libXdmcp.so;/usr/local/lib/libXpm.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/local/lib/libX11.so
-- Looking for include files CMAKE_HAVE_PTHREAD_H
-- Looking for include files CMAKE_HAVE_PTHREAD_H - found
-- Found Threads: TRUE
-- Found Automoc4: /usr/local/bin/automoc4
-- Found Perl: /usr/bin/perl
-- Building kdelibs...
-- Phonon Version: 4.3.1
-- Found Phonon: /usr/local/lib/qt4/libphonon.so
-- Found Phonon Includes: /usr/local/include/qt4/KDE;/usr/local/include/qt4
-- Performing Test _OFFT_IS_64BIT
-- Performing Test _OFFT_IS_64BIT - Success
-- Performing Test HAVE_FPIE_SUPPORT
-- Performing Test HAVE_FPIE_SUPPORT - Success
-- Performing Test __KDE_HAVE_W_OVERLOADED_VIRTUAL
-- Performing Test __KDE_HAVE_W_OVERLOADED_VIRTUAL - Success
-- Performing Test __KDE_HAVE_GCC_VISIBILITY
-- Performing Test __KDE_HAVE_GCC_VISIBILITY - Success
Call Stack (most recent call first):
CMakeLists.txt:35 (find_package)
-- Configuring incomplete, errors occurred!
*** Error code 1
Stop in /usr/ports/x11/kdelibs4.
salamander# make clean
===> Cleaning for kdelibs-4.3.1_1
