Wenn es bei dir nicht funktioniert ist wohl /usr/ports/Mk/bsd.java.mk nicht vorhanden.javavm(1) schrieb:This selection process is usually achieved through the use of
/usr/ports/Mk/bsd.java.mk. However, if this is not present then javavm
will use its own internal selection process which is designed to behave
almost identically.
man javavm
/usr/local/diablo-jdk1.5.0/bin/java # DiabloCaffe1.5.0
/usr/local/jdk1.5.0/bin/java # FREEBSD-JDK1.5.0
/usr/local/linux-sun-jdk1.5.0/bin/java # Linux-Sun-JDK1.5.0.06
/usr/local/jdk1.4.2/bin/java # FREEBSD-JDK1.4.2
/usr/local/linux-sun-jdk1.4.2/bin/java # Linux-Sun-JDK1.4.2.11
% grep JAVA_PORT_NATIVE_FREEBSD_JDK_1_5 /usr/ports/Mk/*
Der Eintrag ist noch nicht vorhanden, scheint bei mir aber trotzdem zu funktionieren.Maledictus schrieb:Doch, ist vorhanden und aktuell, aber siehe da:
Code:% grep JAVA_PORT_NATIVE_FREEBSD_JDK_1_5 /usr/ports/Mk/* %
also, der Java VM wrapper sucht sich das passende raus....By default, javavm will select the most “native” and up to date version of the Java VM when a given symbolic link is used, invoking and passing the arguments to the matching executable within the chosen Java VM. The choice of Java VM may also be influenced by using environment variables to constrain the version, vendor and operating system of the Java VM...
Wobei, wenn ich das richtig verstanden habe,...ENVIRONMENT
JAVA_HOME
The presence of this variable in the environment when executing javavm will override all other considerations regarding the Java VM to be used and the Java VM located at ${JAVA_HOME}/bin/java will be used.
This variable is set by javavm when executing the actual Java VM and will be available to it and all of its child processes.
JAVA_OS
A space delimited list of operating systems. The selected Java VM must have been created for one of the operating systems in the list.
Currently allowed operating system values are `native' and `linux'
JAVA_VENDOR
A space delimited list of Java VM vendors. The selected Java VM must have been released by one of the vendors in the list.
Currently allowed vendors are `bsdjava' , `freebsd' , `blackdown' , `ibm' and `sun'
JAVA_VERSION
A space delimited list of versions of the Java VM that may be used. By appending a `+' to a version, any Java VM with a version greater than or equal to the given version will be used.
Currently allowed versions are `1.1' , `1.1+' , `1.2' , `1.2+' , `1.3' , `1.3+' , `1.4' , `1.4+' , `1.5' and `1.5+'
JAVA_HOME
JAVA_VERSION
/etc/profile
/etc/csh.cshrc
jdk-1.5.0p3 Java Development Kit 1.5.0
linux-sun-jdk-1.5.0.06,2 Sun Java Development Kit 1.5 for Linux
apache-ant-1.6.5_1
classpath-0.19_1
jakarta-commons-cli-1.0,1
jakarta-commons-collections-3.1
jakarta-commons-lang-2.1
junit-3.8.1
jzip.org-0.2.0
log4j-1.2.13
netscape-java40-1999.11.15
seda-3.0
swt-3.1.1
v4all-2.1.1.9
xerces-j-2.7.1
jakarta-commons-lang-2.1 #da bin ich mir nicht ganz sicher, ob das nicht doch baute
[javadoc] Standard Doclet version 1.5.0-p3
[javadoc] Building tree for all the packages and classes...
[javadoc] Building index for all the packages and classes...
[javadoc] Building index for all classes...
[javadoc] Generating /usr/ports/java/jakarta-commons-lang/work/commons-lang-2.1/dist/docs/api/stylesheet.css...
[javadoc] 14 warnings
BUILD SUCCESSFUL
Total time: 16 seconds
===> Installing for jakarta-commons-lang-2.1
===> jakarta-commons-lang-2.1 depends on file: /usr/local/jdk1.5.0/bin/java - found
===> Generating temporary packing list
>> Installing JAR as /usr/local/share/java/classes/commons-lang.jar... [ DONE ]
>> Installing documentation in /usr/local/share/doc/commons-lang/... [ DONE ]
===> Registering installation for jakarta-commons-lang-2.1
===> Returning to build of jakarta-commons-cli-1.0,1
===> jakarta-commons-cli-1.0,1 depends on file: /usr/local/jdk1.5.0/bin/java - found
===> jakarta-commons-cli-1.0,1 depends on file: /usr/local/bin/ant - found
===> Configuring for jakarta-commons-cli-1.0,1
===> Building for jakarta-commons-cli-1.0,1
Buildfile: build.xml
init:
get-deps:
jar:
[mkdir] Created dir: /usr/ports/java/jakarta-commons-cli/work/commons-cli-1.0/target/classes
[javac] Compiling 18 source files to /usr/ports/java/jakarta-commons-cli/work/commons-cli-1.0/target/classes
[javac] error: error reading /usr/local/share/java/classes/backup_azureus_cvs_updates/config/ConfigBackup2.4.0.2/Azureus2.jar; java.util.zip.ZipException: error in opening zip file
[javac] /usr/ports/java/jakarta-commons-cli/work/commons-cli-1.0/src/java/org/apache/commons/cli/TypeHandler.java:69: warning: [deprecation] org.apache.commons.lang.NumberUtils in org.apache.commons.lang has been deprecated
[javac] import org.apache.commons.lang.NumberUtils;
[javac] ^
[javac] /usr/ports/java/jakarta-commons-cli/work/commons-cli-1.0/src/java/org/apache/commons/cli/TypeHandler.java:178: warning: [deprecation] org.apache.commons.lang.NumberUtils in org.apache.commons.lang has been deprecated
[javac] return NumberUtils.createNumber(str);
[javac] ^
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 1 error
[javac] 2 warnings
BUILD FAILED
/usr/ports/java/jakarta-commons-cli/work/commons-cli-1.0/build.xml:24: Compile failed; see the compiler error output for details.
Total time: 7 seconds
*** Error code 1
Stop in /usr/ports/java/jakarta-commons-cli.
*** Error code 1
Stop in /usr/ports/net-p2p/azureus.
** Command failed [exit code 1]: /usr/bin/script -qa /tmp/portupgrade59220.0 make
** Fix the problem and try again.
** Listing the failed packages (*:skipped / !:failed)
! net-p2p/azureus (azureus-2.4.0.2) (unknown build error)
---> Packages processed: 0 done, 0 ignored, 0 skipped and 1 failed
