unix_dragon
Active Member
mein mplayer will keine Streams abspielen, weder http noch rtsp.
Er verbindet sich mit dem Server und cacht dann auch (zeigt jedenfalls der Traffic an), aber er gibt keinen Ton von sich. Wenn ich etwas lokal abspiele dann haben ich Ton. Habe schon alle Audiotreiber ausprobiert.
Der Output vom mplayer:
Weiß jemand eine Antwort.
MPlayer 1.0pre5-3.4.2 (C) 2000-2004 MPlayer Team
CPU: Intel Pentium 4/Xeon/Celeron Foster 2528 MHz (Family: 8, Stepping: 7)
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection - WARNING - this is not optimal!
To get best performance, recompile MPlayer with --disable-runtime-cpudetection.
Reading config file /usr/local/share/mplayer/mplayer.conf: No such file or direc tory
Reading config file /home/draco/.mplayer/config
Reading /home/draco/.mplayer/codecs.conf: Can't open '/home/draco/.mplayer/codec s.conf': No such file or directory
Reading /usr/local/share/mplayer/codecs.conf: 73 audio & 180 video codecs
font: can't open file: /home/draco/.mplayer/font/font.desc
font: can't open file: /usr/local/share/mplayer/font/font.desc
Using usleep() timing
Input config file /home/draco/.mplayer/input.conf parsed: 53 binds
Playing http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=207&file=filenam e.pls.
Resolving www.shoutcast.com for AF_INET6...
Couldn't resolve name for AF_INET6: www.shoutcast.com
Resolving www.shoutcast.com for AF_INET...
Connecting to server www.shoutcast.com[205.188.234.88]:80 ...
Cache size set to 320 KBytes
Connected to server: www.shoutcast.com
Unknown entry type Version=2
Playing http://129.125.102.209:22.
Resolving 129.125.102.209 for AF_INET6...
Couldn't resolve name for AF_INET6: 129.125.102.209
Connecting to server 129.125.102.209[129.125.102.209]:22 ...
Connected to server: 129.125.102.209
