Problem bei ORBit* Installation
albix
Mein Problem ist folgendes:
cc -DHAVE_CONFIG_H -I. -I. -I../../.. -I. -I../../../include -I../../../include -DORBIT2_INTERNAL_API -Wall -Wunused -Wmissing-prototypes -Wmissing-declarations -DG_DISABLE_DEPRECATED -I../../../linc2/include -I../../../linc2/include -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include    -I/usr/local/include  -O -pipe -march=athlon-xp -c `test -f 'name-client.c' || echo './'`name-client.c
/bin/sh /usr/local/bin/libtool15 --mode=link cc  -O -pipe -march=athlon-xp  -L/usr/local/lib -o name-client-2  name-client.o name-support.o ../../../src/orb/libORBit-2.la libORBitCosNaming-2.la -lm -L/usr/local/lib -lglib-2.0 -liconv
cc -O -pipe -march=athlon-xp -o .libs/name-client-2 name-client.o name-support.o  -L/usr/local/lib ../../../src/orb/.libs/libORBit-2.so ./.libs/libORBitCosNaming-2.so /usr/ports/devel/ORBit2/work/ORBit2-2.10.4/src/orb/.libs/libORBit-2.so -lgmodule-2.0 -lpopt -lgobject-2.0 -lgthread-2.0 -lm -lglib-2.0 -liconv -Wl,--rpath -Wl,/usr/local/lib
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_destroy'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_create'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_init'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_exit'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_equal'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_getschedparam'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_setscope'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_setschedparam'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_setstacksize'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_setschedparam'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_setdetachstate'/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_join'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_cond_timedwait'
/usr/local/lib/libgthread-2.0.so: undefined reference to `pthread_attr_getschedparam'
gmake[5]: *** [name-client-2] Fehler 1
gmake[5]: Leaving directory `/usr/ports/devel/ORBit2/work/ORBit2-2.10.4/src/services/name'
gmake[4]: *** [all] Fehler 2
gmake[4]: Leaving directory `/usr/ports/devel/ORBit2/work/ORBit2-2.10.4/src/services/name'
gmake[3]: *** [all-recursive] Fehler 1
gmake[3]: Leaving directory `/usr/ports/devel/ORBit2/work/ORBit2-2.10.4/src/services'
gmake[2]: *** [all-recursive] Fehler 1
gmake[2]: Leaving directory `/usr/ports/devel/ORBit2/work/ORBit2-2.10.4/src'
gmake[1]: *** [all-recursive] Fehler 1
gmake[1]: Leaving directory `/usr/ports/devel/ORBit2/work/ORBit2-2.10.4'
gmake: *** [all] Fehler 2
*** Error code 2
Stop in /usr/ports/devel/ORBit2.
** Command failed [exit code 1]: /usr/bin/script -qa /tmp/portupgrade9976.0 make
** Fix the problem and try again.
** The following packages were not installed or upgraded (*:skipped / !:failed)
        ! devel/ORBit2 (ORBit2-2.8.3_1) (linker error)
Natürlich weiß ich nicht weiter und bitte euch um Rat.
Vielen Dank.
albix
Hat sich erledigt: Updating von "libtool15" und "glib20" brachte den erwünschten Erfolg.
albix
