orangutanklaus
надеть шляпу, снять шляпу
tach,
nachdem ich ein cvsup der ports durchgefuehrt habe, bekomme ich auf "portsdb -Uu" folgende ausgabe:
das problem liegt offensichtlich im fehlenden port "ruby-flex_rb", aber wie kann ich das loesen?
p.s. ich habe vorher mein system nach freebsd-handbuch von "5.3beta7" auf "5.3stable" upgedatet. was bis dahin auch wunderbar funktioniert hat.
hat jemand eine hilfreiche antwort parat?
cu
Updating the ports index ... Generating INDEX.tmp - please wait..ruby18-cvs-0.2: "/usr/ports/devel/ruby-flex_rb" non-existent -- dependency list incomplete
===> devel/ruby-cvs failed
*** Error code 1
1 error
Before reporting this error, verify that you are running a supported
version of FreeBSD (see [url]http://www.FreeBSD.org/ports/[/url]) and that you
have a complete and up-to-date ports collection. (INDEX builds are
not supported with partial or out-of-date ports collections -- in
particular, if you are using cvsup, you must cvsup the "ports-all"
collection, and have no "refuse" files.) If that is the case, then
report the failure to [email]ports@FreeBSD.org[/email] together with relevant
details of your ports configuration (including FreeBSD version,
your architecture, your environment, and your /etc/make.conf
settings, especially compiler flags and WITH/WITHOUT settings).
Note: the latest pre-generated version of INDEX may be fetched
automatically with "make fetchindex".
*** Error code 1
Stop in /usr/ports.
*** Error code 1
Stop in /usr/ports.
failed to generate INDEX!
portsdb: index generation error
cu
