bsd4me
ich nutze Signal Desktop. Die Version 6.26 lief gut, die neue macht Probleme:
Set Windows Application User Model ID (AUMID) { AUMID: 'org.whispersystems.signal-desktop' }
NODE_ENV production
NODE_CONFIG_DIR /usr/local/share/signal-desktop/resources/app.asar/config
NODE_CONFIG {}
ALLOW_CONFIG_MUTATIONS undefined
HOSTNAME orion
NODE_APP_INSTANCE undefined
SUPPRESS_NO_CONFIG_WARNING undefined
SIGNAL_ENABLE_HTTP undefined
userData: /home/ng/.config/Signal
config/get: Successfully read user config file
config/get: Successfully read ephemeral config file
making app single instance
[2682:1014/090311.657915:ERRORbject_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
{"level":30,"time":"2023-10-14T07:03:11.704Z","msg":"app.ready: hour cycle preference: UnknownPreference"}
{"level":30,"time":"2023-10-14T07:03:11.705Z","msg":"app.ready: preferred system locales: en"}
{"level":30,"time":"2023-10-14T07:03:11.705Z","msg":"locale: Supported locales: af-ZA, ar, az-AZ, bg-BG, bn-BD, bs-BA, ca, cs, da, de, el, en, es, et-EE, eu, fa-IR, fi, fr, ga-IE, gl-ES, gu-IN, he, hi-IN, hr-HR, hu, id, it, ja, ka-GE, kk-KZ, km-KH, kn-IN, ko, ky-KG, lt-LT, lv-LV, mk-MK, ml-IN, mr-IN, ms, my, nb, nl, pa-IN, pl, pt-BR, pt-PT, ro-RO, ru, sk-SK, sl-SI, sq-AL, sr, sv, sw, ta-IN, te-IN, th, tl-PH, tr, ug, uk-UA, ur, vi, yue, zh-CN, zh-HK, zh-Hant"}
{"level":40,"time":"2023-10-14T07:03:11.878Z","msg":"MainSQL: Database log code=11: statement aborts at 23: [\n UPDATE messages\n SET json = JSON_PATCH(json, ?)\n WHERE id = ?\n ] database disk image is malformed"}
{"level":50,"time":"2023-10-14T07:03:11.878Z","msg":"MainSQL: Database startup error: SqliteError: database disk image is malformed\n at [REDACTED]/ts/sql/migrations/89-call-history.js:265:31\n at sqliteTransaction ([REDACTED]/node_modules/@signalapp/better-sqlite3/lib/methods/transaction.js:65:24)\n at updateToSchemaVersion89 ([REDACTED]/ts/sql/migrations/89-call-history.js:309:5)\n at updateSchema ([REDACTED]/ts/sql/migrations/index.js:1759:5)\n at Object.initialize ([REDACTED]/ts/sql/Server.js:414:40)\n at MessagePort.<anonymous> ([REDACTED]/ts/sql/mainWorker.js:73:35)\n at [nodejs.internal.kHybridDispatch] (node:internal/event_target:735:20)\n at exports.emitMessage (node:internal/per_context/messageport:23:28)"}
{"level":30,"time":"2023-10-14T07:03:12.257Z","msg":"got fast theme-setting value dark"}
{"level":50,"time":"2023-10-14T07:03:13.256Z","msg":"sql.initialize was unsuccessful; returning early"}
{"level":30,"time":"2023-10-14T07:03:13.257Z","msg":"close event {\"readyForShutdown\":false,\"shouldQuit\":false}"}
{"level":50,"time":"2023-10-14T07:03:15.948Z","msg":"onDatabaseError: Quitting application"}
Unhandled Promise Rejection: Error: Not initialized
at MainSQL.close (/usr/local/share/signal-desktop/resources/app.asar/ts/sql/main.js:103:13)
at BrowserWindow.<anonymous> (/usr/local/share/signal-desktop/resources/app.asar/app/main.js:678:15)
{"level":50,"time":"2023-10-14T07:03:15.954Z","msg":"Unhandled Promise Rejection: Error: Not initialized\n at MainSQL.close ([REDACTED]/ts/sql/main.js:103:13)\n at BrowserWindow.<anonymous> ([REDACTED]/app/main.js:678:15)"}
{"level":50,"time":"2023-10-14T07:03:17.117Z","msg":"Error occurred in handler for 'sql-channel': {}"}
hat jemand eine Idee, was dahinter stecken könnte??
Danke und Viele Grüsse, Norbert
NODE_ENV production
NODE_CONFIG {}
HOSTNAME orion
