Rosendoktor
Hallo zusammen,
wie ja schon angekündigt, hier mein zweites Problem nach dem 12.1 zu 12.2 Upgrade.
Und zwar startet Xorg nach dem Upgrade gar nicht mehr. Im Logfile steht dies:
Da bin ich völlig ratlos. In der
Was könnte da jetzt kaputt sein? Das Gerät ist ein Lenovo X220 mit Intel Grafik.
[ 81.802]
X.Org X Server 1.20.9
[ 81.802] Build Operating System: FreeBSD 12.1-RELEASE-p10 amd64
[ 81.802] Current Operating System: FreeBSD alkione 12.2-RELEASE FreeBSD 12.2-RELEASE SANDYBRIDGE amd64
[ 81.803] Build Date: 24 October 2020 01:56:28AM
[ 81.808]
[ 81.808] Current version of pixman: 0.40.0
[ 81.808] Before reporting problems, check http://wiki.x.org
[ 81.808] Markers: (--) probed, (**) from config file, (==) default setting,
[ 81.808] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 31 21:59:25 2020
[ 81.809] (==) Using config file: "/usr/local/etc/X11/xorg.conf"
[ 81.809] (==) Using system config directory "/usr/local/share/X11/xorg.conf.d"
[ 81.810] (==) No Layout section. Using the first Screen section.
[ 81.810] (==) No screen section available. Using defaults.
[ 81.811] (**) |-->Screen "Default Screen Section" (0)
[ 81.811] (**) | |-->Monitor "<default monitor>"
[ 81.812] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 81.812] (==) Automatically adding devices
[ 81.812] (==) Automatically enabling devices
[ 81.812] (==) Not automatically adding GPU devices
[ 81.812] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 81.812] (==) FontPath set to:
/usr/local/share/fonts/misc/,
/usr/local/share/fonts/TTF/,
/usr/local/share/fonts/OTF/,
/usr/local/share/fonts/75dpi/,
catalogue:/usr/local/etc/X11/fontpath.d
[ 81.812] (==) ModulePath set to "/usr/local/lib/xorg/modules"
[ 81.812] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 81.812] (II) Loader magic: 0x42e020
[ 81.812] (II) Module ABI versions:
[ 81.812] X.Org ANSI C Emulation: 0.4
[ 81.812] X.Org Video Driver: 24.1
[ 81.812] X.Org XInput driver : 24.1
[ 81.813] X.Org Server Extension : 10.0
[ 81.813] (--) PCI:*(0@0:2:0) 8086:0126:17aa:21da rev 9, Mem @ 0xf0000000/4194304, 0xe0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/65536
[ 81.813] (II) LoadModule: "glx"
[ 81.814] (II) Loading /usr/local/lib/xorg/modules/extensions/libglx.so
[ 81.819] (II) Module glx: vendor="X.Org Foundation"
[ 81.819] compiled for 1.20.9, module version = 1.0.0
[ 81.819] ABI class: X.Org Server Extension, version 10.0
[ 81.819] (==) Matched intel as autoconfigured driver 0
[ 81.819] (==) Matched modesetting as autoconfigured driver 1
[ 81.820] (==) Matched scfb as autoconfigured driver 2
[ 81.820] (==) Matched vesa as autoconfigured driver 3
[ 81.820] (==) Assigned the driver to the xf86ConfigLayout
[ 81.820] (II) LoadModule: "intel"
[ 81.820] (II) Loading /usr/local/lib/xorg/modules/drivers/intel_drv.so
[ 81.821] (II) Module intel: vendor="X.Org Foundation"
[ 81.821] compiled for 1.20.9, module version = 2.99.917
[ 81.821] Module class: X.Org Video Driver
[ 81.821] ABI class: X.Org Video Driver, version 24.1
[ 81.821] (II) LoadModule: "modesetting"
[ 81.822] (II) Loading /usr/local/lib/xorg/modules/drivers/modesetting_drv.so
[ 81.822] (II) Module modesetting: vendor="X.Org Foundation"
[ 81.822] compiled for 1.20.9, module version = 1.20.9
[ 81.822] Module class: X.Org Video Driver
[ 81.822] ABI class: X.Org Video Driver, version 24.1
[ 81.822] (II) LoadModule: "scfb"
[ 81.822] (II) Loading /usr/local/lib/xorg/modules/drivers/scfb_drv.so
[ 81.822] (II) Module scfb: vendor="X.Org Foundation"
[ 81.822] compiled for 1.20.9, module version = 0.0.5
[ 81.822] (II) LoadModule: "vesa"
[ 81.822] (II) Loading /usr/local/lib/xorg/modules/drivers/vesa_drv.so
[ 81.823] (II) Module vesa: vendor="X.Org Foundation"
[ 81.823] compiled for 1.20.9, module version = 2.5.0
[ 81.823] Module class: X.Org Video Driver
[ 81.823] ABI class: X.Org Video Driver, version 24.1
[ 81.823] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 81.824] (II) intel: Driver for Intel(R) HD Graphics
[ 81.824] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 81.824] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 81.824] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 81.824] (II) scfb: driver for wsdisplay framebuffer: scfb
[ 81.824] (II) VESA: driver for VESA chipsets: vesa
[ 81.824] (--) Using syscons driver with X support (version 2.0)
[ 81.824] (--) using VT number 9
[ 81.827] (EE) open /dev/dri/card0: No such file or directory
[ 81.827] (WW) Falling back to old probe method for modesetting
[ 81.827] (WW) Falling back to old probe method for scfb
[ 81.827] scfb trace: probe start
[ 81.827] (II) scfb(1): using default device
[ 81.827] scfb trace: probe done
[ 81.828] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 81.828] (EE) Screen 0 deleted because of no matching config section.
[ 81.828] (II) UnloadModule: "modesetting"
[ 81.828] (EE)
Fatal server error:
[ 81.828] (EE) Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
[ 81.828] (EE)
[ 81.828] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 81.828] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 81.828] (EE)
[ 81.830] (EE) Server terminated with error (1). Closing log file.
xorg.conf
steht lediglich was zur Tastatur, nehme ich das auch noch heraus ändert sich gar nichts.
