Etherboot 5.4.1 gmake Problem
klaus
Active Member
Hallo!
Ich nutze FreeBSD 4.10-RELEASE-p3 und wollte über den aktuellen Etherboot Floppy-Images erstellen. Da der Port nocht nicht aktualliesiert ist, habe ich das Programm von der Webseite runtergalden und ausgepackt.
Wenn ich jetzt unter dem Ordner src z.B. gmake bin/3c509.zpxe dann kommt folgende Meldungen raus:
gcc -DCONFIG_PCI -DCONFIG_ISA -DASK_BOOT=3 -DBOOT_FIRST=BOOT_NIC -DALLOW_ONLY_ENCAPSULATED -DBACKOFF_LIMIT=7 -DCONGESTED -DTAGGED_IMAGE -DELF_IMAGE -DDOWNLOAD_PROTO_TFTP -DPXE_IMAGE -DPXE_EXPORT -Os -ffreestanding -Wall -W -Wno-format  -DPCBIOS -fstrength-reduce -fomit-frame-pointer -march=i386 -malign-jumps=1 -malign-loops=1 -malign-functions=1 -mcpu=i386 -DIMAGE_FREEBSD -DELF_IMAGE -DAOUT_IMAGE -DVERSION_MAJOR=5 -DVERSION_MINOR=4 -DVERSION=\"5.4.1\"  -I include -I arch/i386/include -DARCH=i386 -DINCLUDE_3C509 -o bin/3c509.o -c drivers/net/3c509.c
In file included from include/callbacks.h:31,
                 from include/osdep.h:20,
                 from include/etherboot.h:5,
                 from drivers/net/3c509.c:27:
arch/i386/include/callbacks_arch.h:25: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:29: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:33: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:37: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:42: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:45: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:50: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:53: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:58: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:61: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:66: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:69: warning: unnamed struct/union that defines no instances
arch/i386/include/callbacks_arch.h:219: warning: unnamed struct/union that defines no instances
drivers/net/3c509.c:650: warning: `used' attribute directive ignored
drivers/net/3c509.c:650: warning: `t509_driver' defined but not used
gcc -E -Wp,-Wall -DCONFIG_PCI -DCONFIG_ISA -DASK_BOOT=3 -DBOOT_FIRST=BOOT_NIC -DALLOW_ONLY_ENCAPSULATED -DBACKOFF_LIMIT=7 -DCONGESTED -DTAGGED_IMAGE -DELF_IMAGE -DDOWNLOAD_PROTO_TFTP -DPXE_IMAGE -DPXE_EXPORT -Os -ffreestanding -Wall -W -Wno-format  -DPCBIOS -fstrength-reduce -fomit-frame-pointer -march=i386 -malign-jumps=1 -malign-loops=1 -malign-functions=1 -mcpu=i386 -DIMAGE_FREEBSD -DELF_IMAGE -DAOUT_IMAGE -DVERSION_MAJOR=5 -DVERSION_MINOR=4 -DVERSION=\"5.4.1\"  -I include -I arch/i386/include -DARCH=i386 -Ui386 -D ASSEMBLY arch/i386/core/start32.S | as  -o bin/start32.o
gcc -DCONFIG_PCI -DCONFIG_ISA -DASK_BOOT=3 -DBOOT_FIRST=BOOT_NIC -DALLOW_ONLY_ENCAPSULATED -DBACKOFF_LIMIT=7 -DCONGESTED -DTAGGED_IMAGE -DELF_IMAGE -DDOWNLOAD_PROTO_TFTP -DPXE_IMAGE -DPXE_EXPORT -Os -ffreestanding -Wall -W -Wno-format  -DPCBIOS -fstrength-reduce -fomit-frame-pointer -march=i386 -malign-jumps=1 -malign-loops=1 -malign-functions=1 -mcpu=i386 -DIMAGE_FREEBSD -DELF_IMAGE -DAOUT_IMAGE -DVERSION_MAJOR=5 -DVERSION_MINOR=4 -DVERSION=\"5.4.1\"  -I include -I arch/i386/include -DARCH=i386 -o bin/linuxbios.o -c firmware/linuxbios/linuxbios.c
gcc -DCONFIG_PCI -DCONFIG_ISA -DASK_BOOT=3 -DBOOT_FIRST=BOOT_NIC -DALLOW_ONLY_ENCAPSULATED -DBACKOFF_LIMIT=7 -DCONGESTED -DTAGGED_IMAGE -DELF_IMAGE -DDOWNLOAD_PROTO_TFTP -DPXE_IMAGE -DPXE_EXPORT -Os -ffreestanding -Wall -W -Wno-format  -DPCBIOS -fstrength-reduce -fomit-frame-pointer -march=i386 -malign-jumps=1 -malign-loops=1 -malign-functions=1 -mcpu=i386 -DIMAGE_FREEBSD -DELF_IMAGE -DAOUT_IMAGE -DVERSION_MAJOR=5 -DVERSION_MINOR=4 -DVERSION=\"5.4.1\"  -I include -I arch/i386/include -DARCH=i386 -o bin/bios.o -c arch/i386/firmware/pcbios/bios.c
                 from arch/i386/firmware/pcbios/bios.c:8:
In file included from arch/i386/firmware/pcbios/bios.c:9:
arch/i386/include/realmode.h:14: warning: unnamed struct/union that defines no instances
arch/i386/include/realmode.h:16: warning: unnamed struct/union that defines no instances
arch/i386/firmware/pcbios/bios.c: In function `int15':
arch/i386/firmware/pcbios/bios.c:78: union has no member named `h'
arch/i386/firmware/pcbios/bios.c:79: warning: control reaches end of non-void function
gmake: *** [bin/bios.o] Fehler 1
Ein Kumpel kann unter Linux ein Image zusammenbauen. Scheinbar liegt es irgendwo in den Makefiles oder so der Fehler, wo er FreeBSD nicht ganz unterstützt. Kann mir einen Tipp geben?
