Fehler system_bus_socket
JoShuA_
New Member
Hallo an alle, ich habe ein kleines Problem mit meinem Gnome auf meinem Verteilung OpenBSD 4.6
Ich habe ein Problem, wenn initialistation DBus
(nautilus:10589): GLib-GIO-WARNING **: FAMOpen failed, FAMErrno=0
DBusException: org.freedesktop.DBus.Error.FileNotFound: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
 (Module.py:201)
xauth:  creating new authority file /root/.serverauth.41
X.Org X Server 1.5.3
Release Date: 5 November 2008
Build Operating System: OpenBSD 4.6 i386
Current Operating System: OpenBSD  4.6 GENERIC#58 i386
Build Date: 25 November 2009  02:21:42PM
        Before reporting problems, check http://wiki.x.org
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Nov 26 13:00:43 2009
(==) Using config file: "/etc/X11/xorg.conf"
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
>                   Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Window manager warning: Failed to read saved session file /root/.config/metacity/sessions/103e83251f26290e18125923684753422200000061530016.ms: Failed to open file '/root/.config/metacity/sessions/103e83251f26290e18125923684753422200000061530016.ms': No such file or directory
WARNING: COULD NOT FIND FIREFOX LIBRARIES
WARNING: CONDUIT MAY CRASH UNEXPECTEDLY
WARNING: PLEASE TALK TO THE PERSON WHO PACKAGED CONDUIT
/usr/local/bin/gnome-at-visual[90]: getopts: arguments changed since last call
Initializing trackerd...
Tracker-Message: Checking XDG_DATA_HOME is writable and exists
Tracker-Message:   XDG_DATA_HOME is '(null)'
Tracker-Message:   XDG_DATA_HOME set to '/root/.local/share'
Tracker-Message:   Path is OK
Tracker-Message: Setting up monitor for changes to config file:'/root/.config/tracker/tracker.cfg'
(trackerd:4573): GLib-GIO-WARNING **: FAMOpen failed, FAMErrno=0
Tracker-Message: Loading defaults into GKeyFile...
Tracker-Message: Setting up stopword list for language code:'en'
Tracker-Message: Setting up stemmer for language code:'en'
Tracker-Message: Checking directory exists:'/root/.local/share/tracker/data'
Tracker-Message: Checking directory exists:'/root/.cache/tracker'
Tracker-Message: Registering DBus service...
Starting log:
  File:'/root/.local/share/tracker/trackerd.log'
(trackerd:4573): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(trackerd:4573): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
(gnome-panel:1830): GLib-GIO-WARNING **: FAMOpen failed, FAMErrno=0
Unable to open desktop file epiphany.desktop for panel launcher
[Main                ][INFO   ] Conduit v0.3.15 Installed: True (Main.py:99)
[Main                ][INFO   ] Python: 2.5.4 (r254:67916, Nov 23 2009, 10:44:37)
[GCC 3.3.5 (propolice)] (Main.py:100)
[Main                ][INFO   ] Platform Implementations: GnomeVfs,gtkmozembed,GConf (Main.py:101)
[Main                ][INFO   ] Using UI: gtk (Main.py:131)
** (gnome-panel:1830): WARNING **: Failed to establish a connection with GDM: No such file or directory
[gtkui.Canvas        ][INFO   ] Module Information: goocanvas v(0, 14, 1) (/usr/local/lib/python2.5/site-packages/goocanvasmodule.so) (Canvas.py:25)
[modules.AVConverter ][INFO   ] Module Information: gst v(0, 10, 11) (/usr/local/lib/python2.5/site-packages/gst-0.10/gst/__init__.pyc) (AudioVideoConverterModule.py:23)
[modules.Backpack    ][INFO   ] Module Information: backpack (/usr/local/lib/conduit/modules/BackpackModule/backpack/backpack.pyc) (BackpackModule.py:22)
[modules.Evolution   ][INFO   ] Module Information: evolution v(2, 2, 2) (/usr/local/lib/python2.5/site-packages/gtk-2.0/evolution/__init__.pyc) (EvolutionModule.py:25)
[modules.Facebook    ][INFO   ] Module Information: pyfacebook v0.1 (/usr/local/lib/conduit/modules/FacebookModule/pyfacebook/__init__.pyc) (FacebookModule.py:30)
[modules.Feed        ][INFO   ] RSS Feed support disabled (FeedModule.py:53)
[modules.Flickr      ][INFO   ] Module Information: flickrapi v1.1 (/usr/local/lib/conduit/modules/FlickrModule/flickrapi/__init__.pyc) (FlickrModule.py:26)
[modules.Google      ][INFO   ] Module Information: gdata (/usr/local/lib/conduit/modules/GoogleModule/gdata/__init__.pyc) (GoogleModule.py:45)
[modules.Network     ][INFO   ] Network support enabled (NetworkModule.py:30)
[modules.Network     ][WARNING] Error starting client (Client.py:37)
[modules.Network     ][DEBUG  ] Starting AvahiAdvertiser server (Server.py:35)
[modules.Network     ][WARNING] Error starting AvahiAdvertiser server: org.freedesktop.DBus.Error.FileNotFound: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory (Server.py:52)
[modules.iPod        ][INFO   ] Module Information: gpod v(0, 7, 0) (/usr/local/lib/python2.5/site-packages/gpod/__init__.pyc) (iPodModule.py:43)
[Module              ][WARNING] Error loading the file: /usr/local/lib/conduit/modules/iPodModule/iPodModule.py
Traceback (most recent call last):
  File "/usr/local/lib/python2.5/site-packages/conduit/Module.py", line 194, in _load_modules_in_file
    instance = klass(**kwargs)
  File "/usr/local/lib/python2.5/site-packages/conduit/dataproviders/HalFactory.py", line 13, in __init__
    self.bus = dbus.SystemBus()
  File "/usr/local/lib/python2.5/site-packages/dbus/_dbus.py", line 202, in __new__
    private=private)
  File "/usr/local/lib/python2.5/site-packages/dbus/_dbus.py", line 108, in __new__
    bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
  File "/usr/local/lib/python2.5/site-packages/dbus/bus.py", line 125, in __new__
    bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
 (Module.py:201)
[gtkui.UI            ][INFO   ] Main window constructed  (thread: -2080473088) (UI.py:202)
[SyncSet             ][INFO   ] Restoring Sync Set from /root/.config/conduit/settings.xml (SyncSet.py:195)
[SyncSet             ][DEBUG  ] Restoring FolderTwoWay to (source=True) (SyncSet.py:60)
[Conduit             ][DEBUG  ] Adding twoway dataprovider into source position (Conduit.py:140)
[DBus                ][DEBUG  ] DBus Exported: / (DBus.py:127)
[DBus                ][DEBUG  ] DBus Exported: /syncset/gui (DBus.py:127)
[DBus                ][DEBUG  ] DBus Exported: /syncset/dbus (DBus.py:127)
[DBus                ][DEBUG  ] DBus Message from /syncset/gui: Emmiting DBus signal ConduitAdded (DBus.py:134)
