dmesg ergibt folgendes :
FreeBSD 5.2.1-RELEASE #10: Mon May 17 20:05:45 GMT 2004
Christoph@chris:/usr/obj/usr/src/sys/MYKERNEL
Preloaded elf kernel "/boot/kernel/kernel" at 0xc09bb000.
Preloaded elf module "/boot/kernel/linux.ko" at 0xc09bb21c.
Preloaded elf module "/boot/kernel/if_nv.ko" at 0xc09bb2c8.
mptable_probe: MP Config Table has bad signature:
CPU: AMD Athlon(tm) XP 1800+ (1531.03-MHz 686-class CPU)
Origin = "AuthenticAMD" Id = 0x662 Stepping = 2
Features=0x383fbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE>
AMD Features=0xc0400000<AMIE,DSP,3DNow!>
real memory = 536805376 (511 MB)
avail memory = 511766528 (488 MB)
Pentium Pro MTRR support enabled
npx0: [FAST]
npx0: INT 16 interface
pcibios: BIOS version 2.10
Using $PIR table, 5 entries at 0xc00fdf10
pcib0: <Host to PCI bridge> at pcibus 0 on motherboard
pci0: <PCI bus> on pcib0
agp0: <NVIDIA nForce2 AGP Controller> mem 0xd8000000-0xdbffffff at device 0.0 on pci0
pci0: <memory, RAM> at device 0.1 (no driver attached)
pci0: <memory, RAM> at device 0.2 (no driver attached)
pci0: <memory, RAM> at device 0.3 (no driver attached)
pci0: <memory, RAM> at device 0.4 (no driver attached)
pci0: <memory, RAM> at device 0.5 (no driver attached)
isab0: <PCI-ISA bridge> at device 1.0 on pci0
isa0: <ISA bus> on isab0
pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
ohci0: <OHCI (generic) USB controller> mem 0xe0080000-0xe0080fff irq 12 at device 2.0 on pci0
usb0: SMM does not respond, resetting
usb0: <OHCI (generic) USB controller> on ohci0
usb0: USB revision 1.0
uhub0: (0x10de) OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub0: 3 ports with 3 removable, self powered
ugen0: vendor 0x07b3 600dpi USB Scanner, rev 1.10/5.01, addr 2
ohci1: <OHCI (generic) USB controller> mem 0xe0083000-0xe0083fff irq 10 at device 2.1 on pci0
usb1: OHCI version 1.0, legacy support
usb1: SMM does not respond, resetting
usb1: <OHCI (generic) USB controller> on ohci1
usb1: USB revision 1.0
uhub1: (0x10de) OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub1: 3 ports with 3 removable, self powered
ums0: B16_b_02 USB-PS/2 Optical Mouse, rev 2.00/98.02, addr 2, iclass 3/1
ums0: 7 buttons and Z dir.
pci0: <serial bus, USB> at device 2.2 (no driver attached)
nv0: <NVIDIA nForce MCP2 Networking Adapter> port 0xd000-0xd007 mem 0xe0087000-0xe0087fff irq 11 at device 4.0 on pci0
nv0: Ethernet address 00:30:1b:af:e0:15
miibus0: <MII bus> on nv0
rlphy0: <RTL8201L 10/100 media interface> on miibus0
rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
pci0: <multimedia, audio> at device 5.0 (no driver attached)
pcm0: <Nvidia nForce2> port 0xd800-0xd87f,0xd400-0xd4ff mem 0xe0081000-0xe0081fff irq 12 at device 6.0 on pci0
pcm0: <Avance Logic ALC650 AC97 Codec>
pcib1: <PCIBIOS PCI-PCI bridge> at device 8.0 on pci0
pci1: <PCI bus> on pcib1
atapci0: <nVidia nForce2 UDMA133 controller> port 0xf000-0xf00f at device 9.0 on pci0
ata0: at 0x1f0 irq 14 on atapci0
ata0: [MPSAFE]
ata1: at 0x170 irq 15 on atapci0
ata1: [MPSAFE]
fwohci0: vendor=10de, dev=6e
fwohci0: <1394 Open Host Controller Interface> mem 0xe0085000-0xe008503f,0xe0084000-0xe00847ff irq 3 at device 13.0 on pci0
fwohci0: OHCI version 1.10 (ROM=0)
fwohci0: No. of Isochronous channel is 4.
fwohci0: EUI64 00:30:1b:30:1b:af:e0:79
fwohci0: Phy 1394a available S400, 3 ports.
if_fwe0: Fake Ethernet address: 02:30:1b:af:e0:79
fwohci0: Initiate bus reset
fwohci0: BUS reset
fwohci0: node_id=0xc800ffc0, gen=1, CYCLEMASTER mode
firewire0: bus manager 0 (me)
fwohci0: phy int
pcib2: <PCI-PCI bridge> at device 30.0 on pci0
pci3: <PCI bus> on pcib2
pci3: <display, VGA> at device 0.0 (no driver attached)
orm0: <Option ROMs> at iomem 0xd0000-0xd17ff,0xcc000-0xcffff,0xc0000-0xcb7ff on isa0
pmtimer0 on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x64,0x60 on isa0
atkbd0: <AT Keyboard> flags 0x1 irq 1 on atkbdc0
kbd0 at atkbd0
fdc0: ready for input in output
fdc0: cmd 3 failed at out byte 1 of 3
ppc0: <Parallel port> at port 0x378-0x37f irq 7 on isa0
ppc0: Generic chipset (NIBBLE-only) in COMPATIBLE mode
ppbus0: IEEE1284 device found /NIBBLE/ECP
Probing for PnP devices on ppbus0:
ppbus0: <HEWLETT-PACKARD DESKJET 710C> SCP,VLINK
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
sio0: type 16550A
sio1: port may not be enabled
unknown: <PNP0303> can't assign resources (port)
unknown: <PNP0501> can't assign resources (port)
unknown: <PNP0400> can't assign resources (port)
Timecounter "TSC" frequency 1531025693 Hz quality 800
GEOM: create disk ad0 dp=0xc48e6e60
ad0: 78533MB <IC35L080AVVA07-0> [159560/16/63] at ata0-master UDMA100
GEOM: create disk ad1 dp=0xc48e6b60
ad1: 38166MB <Maxtor 34098H4> [77545/16/63] at ata0-slave UDMA100
acd0: CDRW <ATAPI DVD+RW 4X4X12> at ata1-slave UDMA33
Mounting root from ufs:/dev/ad0s3a
