Copyright (c) 1992-2014 The FreeBSD Project.
FreeBSD 10.1-RELEASE #0 r274426M: Wed Nov 12 13:50:45 CET 2014
support@[zensiert]:/usr/obj/usr/src/sys/GENERIC amd64
FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
CPU: Intel(R) Xeon(R) CPU E3-1240 v3 @ 3.40GHz (3400.07-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
AMD Features2=0x21<LAHF,ABM>
Structured Extended Features=0x2fbb<FSGSBASE,TSCADJ,BMI1,HLE,AVX2,SMEP,BMI2,ERMS,INVPCID,RTM>
VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
TSC: P-state invariant, performance statistics
real memory = 8589934592 (8192 MB)
avail memory = 8233746432 (7852 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <SUPERM SMCI--MB>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
ioapic0 <Version 2.0> irqs 0-23 on motherboard
random: <Software, Yarrow> initialized
module_register_init: MOD_LOAD (vesa, 0xffffffff80d942b0, 0) error 19
kbd1 at kbdmux0
acpi0: <SUPERM SMCI--MB> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> mem 0xf7200000-0xf72fffff,0xf7304000-0xf7307fff irq 16 at device 0.0 on pci1
igb0: Using MSIX interrupts with 9 vectors
igb0: Ethernet address: a0:36:9f:44:34:6e
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
igb0: Bound queue 4 to cpu 4
igb0: Bound queue 5 to cpu 5
igb0: Bound queue 6 to cpu 6
igb0: Bound queue 7 to cpu 7
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> mem 0xf7100000-0xf71fffff,0xf7300000-0xf7303fff irq 17 at device 0.1 on pci1
igb1: Using MSIX interrupts with 9 vectors
igb1: Ethernet address: a0:36:9f:44:34:6f
igb1: Bound queue 0 to cpu 0
igb1: Bound queue 1 to cpu 1
igb1: Bound queue 2 to cpu 2
igb1: Bound queue 3 to cpu 3
igb1: Bound queue 4 to cpu 4
igb1: Bound queue 5 to cpu 5
igb1: Bound queue 6 to cpu 6
igb1: Bound queue 7 to cpu 7
xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xf7600000-0xf760ffff irq 16 at device 20.0 on pci0
xhci0: 32 byte context size.
xhci0: Port routing mask set to 0xffffffff
usbus0 on xhci0
pci0: <simple comms> at device 22.0 (no driver attached)
pci0: <simple comms> at device 22.1 (no driver attached)
ehci0: <Intel Lynx Point USB 2.0 controller USB-B> mem 0xf7614000-0xf76143ff irq 16 at device 26.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
vgapci0: <VGA-compatible display> port 0xe000-0xe07f mem 0xf6000000-0xf6ffffff,0xf7000000-0xf701ffff irq 16 at device 0.0 on pci3
vgapci0: Boot video device
pcib4: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci4: <ACPI PCI bus> on pcib4
igb2: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xd000-0xd01f mem 0xf7500000-0xf757ffff,0xf7580000-0xf7583fff irq 18 at device 0.0 on pci4
igb2: Using MSIX interrupts with 5 vectors
igb2: Ethernet address: 0c:c4:7a:08:e6:ac
igb2: Bound queue 0 to cpu 0
igb2: Bound queue 1 to cpu 1
igb2: Bound queue 2 to cpu 2
igb2: Bound queue 3 to cpu 3
pcib5: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci5: <ACPI PCI bus> on pcib5
igb3: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xc000-0xc01f mem 0xf7400000-0xf747ffff,0xf7480000-0xf7483fff irq 19 at device 0.0 on pci5
igb3: Using MSIX interrupts with 5 vectors
igb3: Ethernet address: 0c:c4:7a:08:e6:ad
igb3: Bound queue 0 to cpu 4
igb3: Bound queue 1 to cpu 5
igb3: Bound queue 2 to cpu 6
igb3: Bound queue 3 to cpu 7
ehci1: <Intel Lynx Point USB 2.0 controller USB-A> mem 0xf7613000-0xf76133ff irq 23 at device 29.0 on pci0
usbus2: EHCI version 1.0
usbus2 on ehci1
isa0: <ISA bus> on isab0
ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0xf020-0xf023,0xf000-0xf01f mem 0xf7612000-0xf76127ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahciem0: <AHCI enclosure management bridge> on ahci0
acpi_button0: <Sleep Button> on acpi0
acpi_button1: <Power Button> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
uart2: <16550 or compatible> port 0x3e8-0x3ef irq 7 on acpi0
ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
ipmi0: KCS mode found at io 0xca2 on acpi
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc9fff,0xca000-0xcafff on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
random: unblocking device.
usbus0: 5.0Gbps Super Speed USB v3.0
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
usbus1: 480Mbps High Speed USB v2.0
usbus2: 480Mbps High Speed USB v2.0
ugen1.1: <Intel> at usbus1
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen0.1: <0x8086> at usbus0
uhub1: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
ugen2.1: <Intel> at usbus2
uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ipmi0: IPMI device rev. 1, firmware rev. 1.42, version 2.0
ipmi0: Number of channels 2
ipmi0: Attached watchdog
ses0 at ahciem0 bus 0 scbus6 target 0 lun 0
ses0: <AHCI SGPIO Enclosure 1.00 0001> SEMB S-E-S 2.00 device
ses0: SEMB SES Device
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <INTEL SSDSC2BW120A4 DC32> ATA-9 SATA 3.x device
ada0: Serial Number CVDA410105PC1207GN
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 114473MB (234441648 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
SMP: AP CPU #1 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #6 Launched!
Timecounter "TSC-low" frequency 1700033418 Hz quality 1000
Root mount waiting for: usbus2 usbus1 usbus0
uhub1: 21 ports with 21 removable, self powered
ugen0.2: <vendor 0x046a> at usbus0
ukbd0: <vendor 0x046a product 0x0011, class 0/0, rev 2.00/1.00, addr 1> on usbus0
kbd0 at ukbd0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus1
ugen2.2: <vendor 0x8087> at usbus2
uhub4: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus2
uhub4: 6 ports with 6 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen0.3: <vendor 0x0000> at usbus0
uhub5: <vendor 0x0000 product 0x0001, class 9/0, rev 2.00/0.00, addr 2> on usbus0
uhub5: 4 ports with 3 removable, self powered
Root mount waiting for: usbus0
ugen0.4: <vendor 0x0557> at usbus0
ukbd1: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 3> on usbus0
kbd2 at ukbd1
Trying to mount root from zfs:system []...
ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 3> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
