# AVM ISDN Fritz Card PCI
options NETGRAPH
device ifpi
device ifpi2
device "i4bq921"
device "i4bq931"
device "i4b"
device "i4btrc"
device "i4bctl"
device "i4brbch"
device "i4btel"
cc -c -O2 -pipe -fno-strict-aliasing -Wall -Wredundant-decls -Wnested-externs -Wstrict-prototypes -Wmissing-prototypes -Wpointer-arith -Winline -Wcast-qual -fformat-extensions -std=c99 -nostdinc -I- -I. -I/usr/src/sys -I/usr/src/sys/contrib/altq -I/usr/src/sys/contrib/ipfilter -I/usr/src/sys/contrib/pf -I/usr/src/sys/contrib/dev/ath -I/usr/src/sys/contrib/dev/ath/freebsd -I/usr/src/sys/contrib/ngatm -I/usr/src/sys/dev/twa -D_KERNEL -DHAVE_KERNEL_OPTION_HEADERS -include opt_global.h -fno-common -finline-limit=8000 --param inline-unit-growth=100 --param large-function-growth=1000 -mno-align-long-strings -mpreferred-stack-boundary=2 -mno-mmx -mno-3dnow -mno-sse -mno-sse2 -ffreestanding -Werror /usr/src/sys/i4b/driver/i4b_rbch.c
/usr/src/sys/i4b/driver/i4b_rbch.c:64: error: `NI4BRBCH' undeclared here (not in a function)
/usr/src/sys/i4b/driver/i4b_rbch.c:64: error: storage size of `rbch_drvr_linktab' isn't known
/usr/src/sys/i4b/driver/i4b_rbch.c:65: error: storage size of `isdn_linktab' isn't known
/usr/src/sys/i4b/driver/i4b_rbch.c:98: error: storage size of `rbch_softc' isn't known
/usr/src/sys/i4b/driver/i4b_rbch.c:64: warning: 'rbch_drvr_linktab' defined but not used
/usr/src/sys/i4b/driver/i4b_rbch.c:65: warning: 'isdn_linktab' defined but not used
/usr/src/sys/i4b/driver/i4b_rbch.c:98: warning: 'rbch_softc' defined but not used
system
ratesfile = /etc/isdn/isdnd.rates
useacctfile = on
acctfile = /var/log/isdnd.acct
acctall = on
entry
name = I4BTEL # name for reference
usrdevicename = tel # ipr, tel, rbch
usrdeviceunit = 0 # unit number
isdncontroller = 0 # controller to use or -1 to use any
isdnchannel = -1 # channel (1/2) to use or 0 or -1 for any
# numbers used to verify at DIAL IN
local-phone-incoming = 396692 # we take calls for this local number
remote-phone-incoming = * # we take calls from this remote machine
local-phone-dialout = 396693 # Durch richtige Telefonnummer ersetzen
remote-phone-dialout = 396693 # ppp(8) will override this
dialin-reaction = ignore # accept, reject, ignore, answer
answerprog = answer # program to use
b1protocol = raw # hdlc, raw
idletime-incoming = 2
Nov 3 21:17:37 proxy kernel: i4b-L1 ifpi_isac_irq: unit 0: CRC error
Nov 3 21:17:37 proxy kernel: i4b-L1 ifpi_isac_irq: unit 0: Receive Aborted error
Nov 3 21:17:57 proxy kernel: i4b-L1 ifpi_isac_irq: RPF, input buffer overflow!
Nov 3 21:17:58 proxy kernel: i4b-L1 ifpi_isac_irq: RPF, input buffer overflow!
# AVM ISDN Fritz Card PCI / ISDN4BSD
options AVM_A1
device ifpi
device "i4bcapi"
# protocol stack
device "i4bq921"
device "i4bq931"
device "i4b"
# control devices
device "i4btrc"
options NI4BTRC=2
device "i4bctl"
device "i4brbch"
options NI4BRBCH=2
device "i4btel"
options NI4BTEL=2
system
useacctfile = on
acctall = on
regexpr = "incoming call" # wir starten ein Script, wenn
regprog = "incomingcall" # jemand anruft
entry
local-phone-dialout = 396692 # Durch richtige Telefonnummer ersetzen
remote-phone-dialout = 396692 # ppp(8) will override this
answerprog = isdntel # program to use
direction = in # only incoming is possible
